11-08-2017, 14:46 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. What is the state of your device? Why do You want to create dump? Dump of which partitions you want to create? If You connected the phone, please post here full Software log with the connecting operation. |
11-08-2017, 15:02 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | My phone only power on in fastboot, bootloader is locked, oem not active and cant write any firmware, have other good phone maybe read dump and write un bad phone solved my problem |
11-10-2017, 07:11 | #4 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
If You connected the phone, please post here full Software log with the connecting operation. | |
11-10-2017, 07:21 | #5 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 150100515831334D4207298CE496743D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 298CE496 Manufacturing date : 07/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QX13MB_29_10_2017_07_10_53.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.6; FW: 1.22. P00: GPT (00000000, 00000100) P01: sbl1 (00000100, 00000400) P02: rpm (00000500, 00000200) P03: tz (00000900, 00000E00) P04: devcfg (00001900, 00000080) P05: aboot (00001B00, 00000C00) P06: cmnlib (00002700, 00000200) P07: cmnlib64 (00002900, 00000200) P08: keymaster (00002B00, 00000200) P09: prov (00002D00, 00000180) P10: sbl1bak (00002F00, 00000400) P11: rpmbak (00003300, 00000200) P12: tzbak (00003700, 00000E00) P13: devcfgbak (00004700, 00000080) P14: abootbak (00004900, 00000C00) P15: cmnlibbak (00005500, 00000200) P16: cmnlib64bak (00005700, 00000200) P17: keymasterbak (00005900, 00000200) P18: provbak (00005B00, 00000180) P19: modem (00005D00, 00032000) P20: fsc (00037D00, 00000002) P21: ssd (00037D02, 00000010) P22: dsp (00037D12, 00008000) P23: DDR (0003FE00, 00000040) P24: sec (0003FE40, 00000020) P25: utags (0003FF00, 00000400) P26: utagsBackup (00040300, 00000400) P27: modemst1 (00040700, 00001000) P28: modemst2 (00041700, 00001000) P29: fsg (00042700, 00004000) P30: persist (00046700, 00010000) P31: frp (00056700, 00000400) P32: cid (00056B00, 00000100) P33: logo (00056C00, 00008000) P34: carrier (0005EC00, 00008000) P35: metadata (00066C00, 00000400) P36: kpan (00067000, 00004000) P37: boot (0006B000, 00008000) P38: recovery (00073000, 0000A0C8) P39: misc (0007D100, 00000800) P40: limits (0007D900, 00000040) P41: mota (0007DA00, 00000400) P42: dip (0007DE00, 00000800) P43: syscfg (0007E600, 00000400) P44: logs (0007EA00, 00001000) P45: apdp (0007FA00, 00000200) P46: msadp (0007FC00, 00000200) P47: dpo (0007FE00, 00000010) P48: padA (0007FF00, 00000100) P49: sp (00080000, 00004000) P50: hw (00084000, 00004000) P51: oem (00088000, 00148000) P52: cache (001D0000, 00080000) P53: system (00250000, 006C0000) P54: userdata (00910000, 0312DFDF) Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QX13MB_Gpt_0x0_0x100_29_10_2017_07_10_53.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.6; FW: 1.22. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QX13MB_Cid_0x56b00_0x100_29_10_2017_07_10_53.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.6; FW: 1.22. Disconnected. Please disconnect battery and USB cable. |
11-10-2017, 08:24 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Make backup of all partitions except big ones - cache, system, userdata (create "*.mpt" file). Then connect the phone, into which You want to write boot loaders, make backup of all partitions (read "*.mpt" with all partitions and read full flash also to have full backup) and try to write "*.mpt" from first phone (write all partitions, which You have read out except Gpt, sbl1, Cid, modemst1, modemst2) and check phone. Note, all operation You do at your own risk, because You can damage your device by writing unsupported data! |
