11-18-2017, 16:42 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Armenia
Member: 448264 Status: Offline Thanks Meter: 78 | Help me unbrick LG K330 [Solved] Phone dead after flash K33010h_00.kdz firmware Model Settings: Interface : eMMC Brand : LG Model : K330 SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_K330_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 90014A48384731650508057A24F3837B Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.8 Product serial number : (hex) 57A24F3 Manufacturing date : 08/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H8G1e_18_11_2017_19_31_47.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.8; FW: 1.22. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 00020000) 64 MB P02: sbl1 (00024000, 00000400) 512 KB P03: tz (00024400, 00000800) 1024 KB P04: rpm (00024C00, 00000400) 512 KB P05: aboot (00025000, 00001000) 2048 KB P06: sbl1bak (00026000, 00000400) 512 KB P07: tzbak (00026400, 00000800) 1024 KB P08: rpmbak (00026C00, 00000400) 512 KB P09: abootbak (00027000, 00001000) 2048 KB P10: modemst1 (00028000, 00000C00) 1536 KB P11: modemst2 (00028C00, 00000C00) 1536 KB P12: ssd (00029800, 00000400) 512 KB P13: DDR (00029C00, 00000400) 512 KB P14: fsg (0002A000, 00000C00) 1536 KB P15: fsc (0002AC00, 00000400) 512 KB P16: sec (0002B000, 00000400) 512 KB P17: keystore (0002B400, 00000400) 512 KB P18: encrypt (0002B800, 00000400) 512 KB P19: eksst (0002BC00, 00000400) 512 KB P20: devinfo (0002C000, 00000800) 1024 KB P21: config (0002C800, 00000400) 512 KB P22: spare1 (0002CC00, 00003400) 6.5 MB P23: fota (00030000, 00003000) 6 MB P24: rct (00033000, 00000400) 512 KB P25: spare2 (00033400, 00000C00) 1536 KB P26: raw_resources (00034000, 00000800) 1024 KB P27: raw_resourcesbak (00034800, 00000800) 1024 KB P28: drm (00035000, 00003000) 6 MB P29: sns (00038000, 00003000) 6 MB P30: misc (0003B000, 00005000) 10 MB P31: persist (00040000, 00004000) 8 MB P32: laf (00044000, 00008000) 16 MB P33: boot (0004C000, 00008000) 16 MB P34: recovery (00054000, 00008000) 16 MB P35: factory (0005C000, 0000C000) 24 MB P36: mpt (00068000, 00004000) 8 MB P37: system (0006C000, 004EE000) 2524 MB P38: cache (0055A000, 00064000) 200 MB P39: userdata (005BE000, 008CE000) 4.402 GB P40: grow (00E8C000, 00003FDF) 7.984 MB Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_K330_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing rpm partition... Done. Writing aboot partition... Done. Writing sbl1bak partition... Done. Writing tzbak partition... Done. Writing rpmbak partition... Done. Writing abootbak partition... Done. Writing ssd partition... Done. Writing DDR partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing sec partition... Done. Writing keystore partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing devinfo partition... Done. Writing config partition... Done. Writing spare1 partition... Done. Writing fota partition... Done. Writing rct partition... Done. Writing spare2 partition... Done. Writing raw_resources partition... Done. Writing raw_resourcesbak partition... Done. Writing drm partition... Done. Writing sns partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing factory partition... Done. Writing mpt partition... Done. Writing grow partition... Done. Smart Repair is successfully complete. SW: 1.4.8; FW: 1.22. Disconnected. But phone still dead only Qualcomm HS-USB QDLoader 9008 Last edited by Medusa Box; 11-21-2017 at 15:21. |
11-19-2017, 13:00 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Accordingly to your Software log, "Smart Repair" operation was performed successfully and correctly. Here can be two main reasons of this problem (why the phone doesn't go into Download Mode) - device has HW issue or boot loaders in SRF "LG_K330_EMMC.srf", which You have used for repairing could be not suitable (not compatible) with your phone (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to perform "Factory Repair" operation ("Factory repair" tab in Software) using the latest original LG firmware for this phone model. |
11-20-2017, 12:27 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to find the latest original firmware (the same or higher version, that was in the phone before downgrading) and do "Factory Repair" using it. |
11-21-2017, 13:56 | #5 (permalink) | |
Member: 448264 Status: Offline Thanks Meter: 78 | Quote:
K33010h_00.kdz K33010i_00_1021.kdz K33010j_00_1118.kdz K33010k_00_0125.kdz K33010l_00_0405.kdz i try full erase emmc then write but phone still dead | |
11-21-2017, 14:06 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to write V11f (K33011f_00_0126) for LGK330TNGO1. |
The Following 2 Users Say Thank You to Medusa Box For This Useful Post: |
02-08-2018, 06:10 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Pinout picture is inside of proper SFR (Smart Repair File). To look at pinout picture, do the following: 1. Install the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Download and install SRF (Smart Repair File) "LG_K330_EMMC.srf" form the Support Area ("Download *.srf" button in Software). 3. Select "eMMC" options interface. 4. Select LG K330 in the Software list (model will appear in Software list after SFR installation). 5. Press "Pinout" button in Software. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
