10-17-2017, 18:22 | #5 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
To repair SM-G530FZ, try to do the following: 1. Install the latest version of Medusa Pro Software (http://medusabox.com/eng/download/software). 2. Download and install SRF (Smart Repair File) for SM-G530H "SAMSUNG_SM-G530H_EMMC_P1J95K.srf" from the Support Area (via "Download *.srf" button in Software). 3. Select "eMMC" option in Software. 4. Select Samsung SM-G530H in Software's list (model will appear in Software's list after SRF installation). 5. Solder all necessary eMMC wires accordingly to Software manual ("Help" or "Pinout" button in Software). EMMC pinout of SM-G530FZ should be similar (or the same) as for SM-G530H. 6. Press "Connect" button in Software. 7. When device will be connected successfully, do "Factory Repair" ("Factory repair" tab in Software) using proper PIT file and the latest Samsung firmware for SM-G530FZ. 8. Post here the result. Also please make backup (read Full flash) before to do repairing. | ||
10-19-2017, 12:39 | #6 (permalink) |
Freak Poster Join Date: Nov 2014 Location: madrid
Member: 2296854 Status: Offline Sonork: 100.1680516 Thanks Meter: 89 | Model Settings: Interface : eMMC Brand : Samsung Model : SM-G530H SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G530H_EMMC_P1J95K.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Micron eMMC P1J95K Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : FE014E50314A39354B1336456F3222CF Manufacturer ID : 0XFE Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4E Product name : P1J95K Product revision : 1.3 Product serial number : (hex) 36456F32 Manufacturing date : 02/2015 --------------------------------------------------------------- CSD Info CSD : D06E01320F5913FFFFFFFFEF92400071 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 6 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 8192 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 2048 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 376832 Number of sectors : 3063808 Device Manufacturer : samsung Device Platform : msm8916 Build ID : LRX22G Display Build ID : LRX22G.G530FZXXU1BQD2 Release ID : 5.0.2 Device Model : SM-G530FZ Device Name : grandprimeltexx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : grandprimeltexx-user 5.0.2 LRX22G G530FZXXU1BQD2 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/P1J95K_19_10_2017_13_37_04.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.6; FW: 1.22. P00: GPT (00000000, 00002000) P01: apnhlos (00002000, 00007800) P02: modem (00009800, 0001CB80) P03: sbl1 (00026380, 00000400) P04: ddr (00026780, 00000040) P05: aboot (000267C0, 00001000) P06: rpm (000277C0, 00000400) P07: qsee (00027BC0, 00000400) P08: qhee (00027FC0, 00000400) P09: fsg (000283C0, 00001800) P10: sec (00029BC0, 00000020) P11: pad (00029BE0, 00005420) P12: param (0002F000, 00005000) P13: efs (00034000, 00007000) P14: modemst1 (0003B000, 00001800) P15: modemst2 (0003C800, 00001800) P16: boot (0003E000, 00006800) P17: recovery (00044800, 00007800) P18: fota (0004C000, 00002802) P19: backup (0004E802, 000037EE) P20: fsc (00051FF0, 00001800) P21: ssd (000537F0, 00000010) P22: persist (00053800, 00004000) P23: persdata (00057800, 00004800) P24: system (0005C000, 002EC000) P25: cache (00348000, 00096000) P26: hidden (003DE000, 00005000) P27: userdata (003E3000, 00AACFD8) Selected pit file: E:/g530fz/Nueva carpeta/GRANDPRIMELTE_EUR_OPEN.pit Open file "E:/g530fz/G530FZXXU1BOJ2_G530FZWIN1BOI1_5.0.2_ITALY_HOME/G530FZXXU1BOJ2_G530FZWIN1BOI1_G530FZXXU1BOI2_HOME. tar.md5". Writing MBR...Done. Writing primary GPT... ERROR[012]: Write error. At sector 8. Disconnected. |
10-19-2017, 14:00 | #7 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | As You can see from your Software log, there is a problem with eMMC chip - Software can't write data to it: Quote:
