![]() | #5 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2008 Location: COLOMBIA
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | Bro excueme, but then what mean this: http://forum.gsmhosting.com/vbb/f664...-done-2433086/ Hello. Unfortunately not all of necessary pins for eMMC (ISP) connection are present on this device PCB (we searched them, but have not found on PCB), so it is necessary to remove eMMC chip from PCB for repairing. Remove eMMC form PCB, connect it via soldering necessary wires to chip contacts or use proper eMMC adapter and do "Factory Repair" using the latest original LG firmware for this device model. Then solder eMMC chip back to PCB. (Remove eMMC form PCB, connect it via soldering necessary wires to chip contacts) My cuestion is where is that pinout? Br. Medusa Box Last edited by Hacker84; 08-06-2019 at 14:51. |
![]() | #6 (permalink) | |
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | Quote:
Support i alrerady reached to connect emmc with Medusa Box: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420D2E4796C0446D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) 2E4796C0 Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 6324224 Device Manufacturer :lge Device Platform :mt6755 Build ID :MXB48T Display Build ID :MXB48T Release ID :6.0.1 Device Model :LGLS755 Device Name :mk6p55_spr_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :mk6p55_spr_us-user 6.0.1 MXB48T 1629108498241 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_06_08_2019_18_45_37.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: proinvo (00000400, 00001800) 3072 KB P02: misc2 (00001C00, 00004000) 8 MB P03: ftm (00005C00, 00004000) 8 MB P04: nvram (00009C00, 00002800) 5 MB P05: spare1 (0000C400, 00003C00) 7.5 MB P06: protect1 (00010000, 00004000) 8 MB P07: protect2 (00014000, 00004000) 8 MB P08: lk (00018000, 00000800) 1024 KB P09: lk2 (00018800, 00000800) 1024 KB P10: laf (00019000, 0000E000) 28 MB P11: lafbak (00027000, 0000E000) 28 MB P12: para (00035000, 00000400) 512 KB P13: boot (00035400, 00008000) 16 MB P14: recovery (0003D400, 00008000) 16 MB P15: recoverybak (00045400, 00008000) 16 MB P16: logo (0004D400, 00004000) 8 MB P17: lo_bak_go (00051400, 00004000) 8 MB P18: expdb (00055400, 00005000) 10 MB P19: spare2 (0005A400, 00001C00) 3584 KB P20: seccfg (0005C000, 00004000) 8 MB P21: oemkeystore (00060000, 00004000) 8 MB P22: secro (00064000, 00003000) 6 MB P23: keystore (00067000, 00004000) 8 MB P24: tee1 (0006B000, 00002800) 5 MB P25: tee2 (0006D800, 00002800) 5 MB P26: eksst (00070000, 00000400) 512 KB P27: encrypt (00070400, 00000400) 512 KB P28: persist_lg (00070800, 00004000) 8 MB P29: mpt (00074800, 0000B000) 22 MB P30: lgfota (0007F800, 00005000) 10 MB P31: rct (00084800, 00000800) 1024 KB P32: factory (00085000, 0000E000) 28 MB P33: persist (00093000, 00018000) 48 MB P34: efuse (000AB000, 00000400) 512 KB P35: nvcfg (000AB400, 00004000) 8 MB P36: spare4 (000AF400, 00000800) 1024 KB P37: nvdata (000AFC00, 00010000) 32 MB P38: metadata (000BFC00, 00010000) 32 MB P39: md1img (000CFC00, 0000C000) 24 MB P40: md1dsp (000DBC00, 00002000) 4 MB P41: md1arm7 (000DDC00, 00001800) 3072 KB P42: md3img (000DF400, 00002800) 5 MB P43: carrier (000E1C00, 00014000) 40 MB P44: spare3 (000F5C00, 00002400) 4.5 MB P45: frp (000F8000, 00004000) 8 MB P46: system (000FC000, 00608000) 3088 MB P47: cache (00704000, 001C4000) 904 MB P48: userdata (008C8000, 0144EC00) 10.15 GB P49: flashinfo (01D16C00, 00008000) 16 MB But when try to repiar via factory repair (LS755ZV9_02.tot) i get error: W: 1.7.7; FW: 1.24. Opening C:/PRUEBA/RASCACIELOS/LS755ZV9_02.tot file... Signature OK. Signature 2 OK. Open file "C:/PRUEBA/RASCACIELOS/LS755ZV9_02.tot". Write data verification is enabled. Writing. Please wait... Writing partition preloader... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. Please can you support me to repair the phone? | |
