Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Aug 2008 Location: UZB Age: 42
Member: 830735 Status: Offline Thanks: 18
| Help repair samsung SHV-E110S Selected device model: Auto Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. ERROR[016]: Selected device CPU ID mismatch. Core ID = 106A10E1, expected ID = 07926F0F. |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks: 880
| Hello. Please select correct device (SHV-E110S) - Select "Manufacturer: Samsung", "Device Model: Samsung SHV-W110A" and try to connect. Then post here FULL software log with the procedure of connection. |
| | #3 (permalink) | |
| Quote:
Thanks! | |
| | #5 (permalink) |
| yes so log Log started at 07.08.2012 12:35:52 ... Добро пожаловать в Medusa Box Software версии 1.5.0.1 Выбраная модель: Samsung SHV-E110S Соединение... Недостаточный уровень напряжения VREF = 0.0V. Пожалуйста, перепроверьте состояние питания устройства. ERROR[034]: Сигнал RTCK не отвечает. Переключение на фиксированную частоту 1 МГц. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Найдено ЦПУ ID: 106A10E1, длинна IR=11. MI: Halting target, attempt 1. Скорость JTAG : 1000 KHz. Уровень VREF : 1.76 V ЦПУ : Qualcomm APQ8060 ID ЦПУ : 106A10E1 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Ошибка загрузки Medusa Device Server. Выбраная модель: Samsung SHV-E110S Соединение... Недостаточный уровень напряжения VREF = 0.0V. Пожалуйста, перепроверьте состояние питания устройства. ERROR[034]: Сигнал RTCK не отвечает. Переключение на фиксированную частоту 1 МГц. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Найдено ЦПУ ID: 106A10E1, длинна IR=11. MI: Halting target, attempt 1. MI: Halting target, attempt 2. MI: Halting target, attempt 3. Скорость JTAG : 1000 KHz. Уровень VREF : 1.76 V ЦПУ : Qualcomm APQ8060 ID ЦПУ : 106A10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0xFFFFFFFF, cycle 0. MI: Received status 0xFFFFFFFF, cycle 1. MI: Received status 0xFFFFFFFF, cycle 2. MI: Failed to start Medusa Device Server. ERROR[004]: Нет ответа от Medusa Device Server на комманду "HELLO". ERROR[035]: При попытке соединения целевое устройство было отключено. Выбраная модель: Samsung SHV-E110S Соединение... Недостаточный уровень напряжения VREF = 0.0V. Пожалуйста, перепроверьте состояние питания устройства. ERROR[034]: Сигнал RTCK не отвечает. Переключение на фиксированную частоту 1 МГц. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Найдено ЦПУ ID: 106A10E1, длинна IR=11. MI: Halting target, attempt 1. Скорость JTAG : 1000 KHz. Уровень VREF : 1.76 V ЦПУ : Qualcomm APQ8060 ID ЦПУ : 106A10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0xFFFFFFFF, cycle 0. MI: Received status 0x00000000, cycle 1. MI: Received status 0xFFFFFFFF, cycle 2. MI: Failed to start Medusa Device Server. |
| | #7 (permalink) |
| To power your device You need to use BOTH - fully charged battery (or stable external power supply) AND USB cable at the same time! |
| The Following User Says Thank You to Medusa Box For This Useful Post: |
| | #8 (permalink) |
| click "repair" a few times a record is sometimes, but it turns out the error 018 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0xFFFFFFFF, cycle 0. MI: Received status 0xFFFFFFFF, cycle 1. MI: Received status 0xFFFFFFFF, cycle 2. MI: Failed to start Medusa Device Server. ERROR[004]: Medusa Device Server did not replied to HELLO command. ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 1.76 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000000D, cycle 0. MI: Received status 0x0000F00F, cycle 1. MI: Received server capabilities 0x00000191. MI: Detailed server caps: FLASH, WDOG, A64, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xE0150001. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000191 Storage Device: Samsung eMMC KYL00M Device ID : 00150001 Block size : 512 bytes Blocks : 30777344 Storage size : 14.7 Gb Opening "C:\Documents and Settings\M\Рабочий стол\SAMSUNG_SHVE110S_Repair.mf" file... Writting PARTITION section. Please wait... Done Writting BOOT section. Please wait... MI: Server status 0x0000000F (not STAT_IDLE). ERROR[018]: Logical block operation failed at 103840 Kb (Hex address 0x06568200). Reason: Command failed. ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. MI: Halting target, attempt 1. MI: Halting target, attempt 2. JTAG speed : 1000 KHz. VREF level : 1.76 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0xFFFFFFFF, cycle 0. MI: Received status 0xFFFFFFFF, cycle 1. MI: Received status 0xFFFFFFFF, cycle 2. MI: Failed to start Medusa Device Server. ERROR[004]: Medusa Device Server did not replied to HELLO command. Please connect the target device and power it on... ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 106A10E1, IR Length = 11. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 1.76 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 MI: Loading Medusa Device Server V1.2. MI: Failed to load. ERROR[002]: Failed to load Medusa Device Server to target RAM. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 106A10E1, IR Length = 11. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 1.76 V CPU : Qualcomm APQ8060 Core ID : 106A10E1 Last edited by myu; 08-08-2012 at 08:44. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| HELP!!! BACKGROUND SCREEN LOGO | Michael Go | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-25-2011 23:56 |
| Eeprom dump lost, help needed. | CAMILO | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 11-29-2010 18:04 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 06-25-1999 08:21 |
