11-02-2012, 16:51 | #3 (permalink) |
Freak Poster Join Date: May 2009
Member: 1035393 Status: Offline Thanks Meter: 81 | @ yeshil You need to use EasyRepair mode, have external SD card reader with a list 2 Gb free space. http://forum.gsmhosting.com/vbb/f664...0/#post8884987 - here is your answer. |
11-02-2012, 17:14 | #6 (permalink) |
Member: 1035393 Status: Offline Thanks Meter: 81 | @ yeshil Card must be connected into external Smart-Card reader. in the first. It must be fully erased and in first step in easy repair mode to the card will be written repair firmware. Then card must be inserted into phone and proceed repair procedure. ERROR[000]: Unable to halt core. This situation occurs when JTAG connection is bad. Try to lower JTAG speed and check connection of JTAG and your target device (TRST, TCK, TMS, TDI, TDO are the most important pins. If that does not help and you sure that connection is correct then You probably have device with JTAG disabled by hardware. |
