11-26-2018, 13:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Rio de Janeiro - Brasil
Member: 797068 Status: Offline Thanks Meter: 75 | How to create a .sfr file? [Answered] |
11-26-2018, 13:40 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello. Quote:
11-26-2018, 13:41 | #3 (permalink) |
Member: 797068 Status: Offline Thanks Meter: 75 | I found this information: Creating of your own Smart Repair File (SRF) is easy, just do the following: 1. Solder all necessary eMMC wires. 2. Connect the device to Box and press "Connect" button in Software. 3. When the device will be connected successfully, press "Constructor" button in Software to run SRF constructor. 4. Select necessary partitions, which will be available in SRF. 5. Fill "Author", "Brand", "Model" fields. 6. Set pinout picture and logo picture (if You have appropriate pictures). 7. Press "Create" button to create SRF. But I need to know which partitions I need to bookmark to create a good sfr file! |
11-26-2018, 14:21 | #5 (permalink) |
Member: 797068 Status: Offline Thanks Meter: 75 | Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100515831334D420778FDB2ED34F3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) 78FDB2ED Manufacturing date : 03/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QX13MB_26_11_2018_11_21_21.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.0; FW: 1.23. P00: GPT (00000000, 00000100) 128 KB P01: sbl1 (00000100, 00000400) 512 KB P02: rpm (00000500, 00000200) 256 KB P03: tz (00000900, 00000E00) 1792 KB P04: devcfg (00001900, 00000100) 128 KB P05: aboot (00001B00, 00000C00) 1536 KB P06: cmnlib (00002700, 00000200) 256 KB P07: cmnlib64 (00002900, 00000200) 256 KB P08: keymaster (00002B00, 00000200) 256 KB P09: prov (00002D00, 00000180) 192 KB P10: sbl1bak (00002F00, 00000400) 512 KB P11: rpmbak (00003300, 00000200) 256 KB P12: tzbak (00003700, 00000E00) 1792 KB P13: devcfgbak (00004700, 00000100) 128 KB P14: abootbak (00004900, 00000C00) 1536 KB P15: cmnlibbak (00005500, 00000200) 256 KB P16: cmnlib64bak (00005700, 00000200) 256 KB P17: keymasterbak (00005900, 00000200) 256 KB P18: provbak (00005B00, 00000180) 192 KB P19: modem (00005D00, 00032000) 100 MB P20: fsc (00037D00, 00000002) 1024 b P21: ssd (00037D02, 00000010) 8 KB P22: dsp (00037D12, 00008000) 16 MB P23: DDR (0003FE00, 00000040) 32 KB P24: sec (0003FE40, 00000020) 16 KB P25: utags (0003FF00, 00000400) 512 KB P26: utagsBackup (00040300, 00000400) 512 KB P27: modemst1 (00040700, 00001000) 2048 KB P28: modemst2 (00041700, 00001000) 2048 KB P29: fsg (00042700, 00004000) 8 MB P30: persist (00046700, 00010000) 32 MB P31: frp (00056700, 00000400) 512 KB P32: cid (00056B00, 00000100) 128 KB P33: logo (00056C00, 00008000) 16 MB P34: carrier (0005EC00, 00008000) 16 MB P35: metadata (00066C00, 00000400) 512 KB P36: kpan (00067000, 00004000) 8 MB P37: boot (0006B000, 00008000) 16 MB P38: recovery (00073000, 000080C8) 16.1 MB P39: misc (0007B100, 00000800) 1024 KB P40: limits (0007B900, 00000040) 32 KB P41: mota (0007BA00, 00000400) 512 KB P42: dip (0007BE00, 00000800) 1024 KB P43: syscfg (0007C600, 00000400) 512 KB P44: logs (0007CA00, 00001000) 2048 KB P45: apdp (0007DA00, 00000200) 256 KB P46: msadp (0007DC00, 00000200) 256 KB P47: dpo (0007DE00, 00000010) 8 KB P48: padA (0007DF00, 00002100) 4.125 MB P49: sp (00080000, 00004000) 8 MB P50: hw (00084000, 00004000) 8 MB P51: oem (00088000, 00148000) 656 MB P52: cache (001D0000, 00080000) 256 MB P53: system (00250000, 006C0000) 3456 MB P54: userdata (00910000, 0312DFDF) 24.59 GB Backuping Gpt partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_Gpt_0x0_0x100_26_11_2018_11_21_21.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.0; FW: 1.23. Backuping Cid partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QX13MB_Cid_0x56b00_0x100_26_11_2018_11_21_21.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.6.0; FW: 1.23. |
11-26-2018, 15:00 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,388 | Also upload somewhere and post here link to "QX13MB_Gpt_0x0_0x100_26_11_2018_11_21_21.bin" file, we will prepare custom GPT for your SRF. |
11-26-2018, 15:07 | #7 (permalink) | |
Member: 797068 Status: Offline Thanks Meter: 75 | i upload in my onedrive Quote:
https://1drv.ms/u/s!AkCTfp7Y14IEgVrhzdBcSVVkTwOP | |
11-26-2018, 15:51 | #8 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | OK, now to create SRF, connect the device again, press "Constructor" button, select all partitions, except following: gpt, cid, modemst1, modemst2, cache, system, userdata. Then click on "Add custom partition" and select this custom GPT (https://drive.google.com/open?id=1lb...XJdZdjZXu6-vL6) and create SRF. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
04-19-2019, 16:45 | #10 (permalink) |
Freak Poster Join Date: Apr 2011 Location: Santa Clatra Cuba
Member: 1550712 Status: Offline Thanks Meter: 17 | Hello, it is important to keep in mind when creating an SRF for a device the android verification, or editing this file you can write it to a device that has any android verifications |
