04-25-2018, 17:36 | #1 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Earth
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | How to Samsung SM-J5108 eMMC Repair? [Answered] I received a Samsung SM-J5108 In dead Condition, but it detects as Qualcomm 9008 port. So i decided to repair its Emmc.I need your guidance. Removed BGA221 Emmc and Connected Successfully ,What next? Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q313MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331334D42002D48E45633A1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q313MB Product revision : 0.0 Product serial number : (hex) 2D48E456 Manufacturing date : 03/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 5537792 Device Manufacturer :samsung Device Platform :msm8916 Build ID :MMB29M Display Build ID :MMB29M.J5108ZHS1BQG3 Release ID :6.0.1 Device Model :SM-J5108 Device Name :j5xltezh Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j5xltezh-user 6.0.1 MMB29M J5108ZHS1BQG3 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q313MB_25_04_2018_21_53_45.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.6; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: apnhlos (00002000, 00007800) 15 MB P02: modem (00009800, 0001C980) 57.19 MB P03: sbl1 (00026180, 00000400) 512 KB P04: ddr (00026580, 00000040) 32 KB P05: aboot (000265C0, 00001000) 2048 KB P06: rpm (000275C0, 00000400) 512 KB P07: qsee (000279C0, 00000600) 768 KB P08: qhee (00027FC0, 00000400) 512 KB P09: fsg (000283C0, 00001800) 3072 KB P10: sec (00029BC0, 00000020) 16 KB P11: pad (00029BE0, 00005420) 10.52 MB P12: param (0002F000, 00005000) 10 MB P13: efs (00034000, 00007000) 14 MB P14: modemst1 (0003B000, 00001800) 3072 KB P15: modemst2 (0003C800, 00001800) 3072 KB P16: boot (0003E000, 00006800) 13 MB P17: recovery (00044800, 00007800) 15 MB P18: fota (0004C000, 00005FFA) 12 MB P19: backup (00051FFA, 000037EE) 6.991 MB P20: fsc (000557E8, 00001800) 3072 KB P21: ssd (00056FE8, 00000010) 8 KB P22: persist (00056FF8, 00004000) 8 MB P23: persistent (0005AFF8, 00000800) 1024 KB P24: persdata (0005B7F8, 00004808) 9.004 MB P25: system (00060000, 00548000) 2704 MB P26: cache (005A8000, 00064000) 200 MB P27: userdata (0060C000, 0174DFD8) 11.65 GB Last edited by Medusa Box; 04-26-2018 at 04:57. |
04-26-2018, 04:56 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. At first make full backup of the device - read Full flash. To repair the device, try to do the following: 1. Connect the device. 2. Do "Factory Repair" ("Factory repair" tab in Software) using proper PIT file and the latest full Samsung firmware for SM-J5108 (if exist, try to find and use 4-files firmware). 3. Fully charge device's battery and try to put the device into Download (Emergency) Mode (manually or using Samsung JIG cable). 4. Post here the result. |
The Following 3 Users Say Thank You to Medusa Box For This Useful Post: |
04-26-2018, 05:31 | #3 (permalink) |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Hi Team, Googled for hours, couldn't find pit for SM-J5108. Is SM-J5108 Pit file Available in support area? Or can anyone please upload pit File for SM-J5108 ? |
04-26-2018, 05:54 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | We don't have PIT file for this device at the moment also. You can try to find and use PIT for SM-J510F or SM-J510FN, maybe it is compatible. Or try to read PIT from working SM-J5108, if You have. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
04-26-2018, 08:40 | #5 (permalink) |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Hi team, when i click smart report option i got report like below. is this normal? Code: Smart report info: Hash code: 0000000000000000000000000000000000000000000000000000000000000000 Super block size : 0x00000000 Bytes Super page size : 0x00000000 Bytes Optima write size : 0x00000000 Bytes Number of banks : 0 Bank0 init bad block : 0 Bank0 runtime bad block : 0 Bank0 remain reserved block : 0 Max erase count : 0 Min erase count : 0 Avg erase count : 0 Read reclaim count : 0 Optimal trim size : 0x00000000 Bytes Max erase count (SCL) : 0 Min erase count (SCL) : 0 Avg erase count (SCL) : 0 Max erase count (MLC) : 0 Min erase count (MLC) : 0 Avg erase count (MLC) : 0 SW: 1.5.6; FW: 1.23. |
04-26-2018, 09:27 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Please re-connect the device, perform "Smart Report" operation again and post here full Software log with device connection info and with "Smart Report" operation, we will check in details. |
The Following 2 Users Say Thank You to Medusa Box For This Useful Post: |
