Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 04-25-2018, 17:36   #1 (permalink)
.::TEAM CCS::.'s Avatar
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
How to Samsung SM-J5108 eMMC Repair? [Answered]
Hi team,
I received a Samsung SM-J5108 In dead Condition, but it detects as Qualcomm 9008 port. So i decided to repair its Emmc.I need your guidance.
Removed BGA221 Emmc and Connected Successfully ,What next?
Model Settings:
Interface : eMMC
Voltage   : 1.8V
Bus Mode  : 1 bit
Bus speed : Auto
Connecting...
Device       : Samsung eMMC Q313MB
Page size    : 512 B
Block size   : 512 B
Block count  : 30777344
Size         : 14.68 GB (15028.00 MB)
CID Info
CID                   : 150100513331334D42002D48E45633A1
Manufacturer ID       : 0X15
Device/BGA            : BGA (Discrete embedded)
OEM/Application ID    : 0X00
Product name          : Q313MB
Product revision      : 0.0
Product serial number : (hex) 2D48E456
Manufacturing date    : 03/2016
CSD Info
CSD                   : D02701320F5903FFF6DBFFEF8E40400D
CSD structure         : CSD version No. 1.2
SPEC version          : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
                        4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed            : 26 MHz
READ block length     : 512 Bytes
WP group enable       : YES
PERM_WRITE_PROTECT    : NO
TMP_WRITE_PROTECT     : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size      : 512 Kbytes
Boot1 size            : 4096 Kbytes
Boot2 size            : 4096 Kbytes
RPMB size             : 4096 Kbytes
Partition config      : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK              : No boot acknowledge sent (default)
Boot bus conditions   : (0x00) 00000000
Boot bus width        : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions   : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode             : Use single data rate + backward compatible timings in boot operation (default)
RST_n function        : (0x01) RST_n signal is permanently enabled
Partitioning support  : Device supports partitioning features
Enhanced attribute    : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7692288 Kbytes
Partitions attribute  : 0x0
Part setting completed: 0x0
GP partition 1 size   : 0 b
GP partition 2 size   : 0 b
GP partition 3 size   : 0 b
GP partition 4 size   : 0 b
Enhanced area size    : (0x0) 0 b
Enhanced area start   : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size       : ab400000 bytes
Device sector size    : 512 bytes
Partition offset      : 393216
Number of sectors     : 5537792
Device Manufacturer   :samsung
Device Platform       :msm8916
Build ID              :MMB29M
Display Build ID      :MMB29M.J5108ZHS1BQG3
Release ID            :6.0.1
Device Model          :SM-J5108
Device Name           :j5xltezh
Architecture ABI      :armeabi-v7a
Architecture ABI2     :armeabi
Architecture ABI List :armeabi-v7a,armeabi
Build Description     :j5xltezh-user 6.0.1 MMB29M J5108ZHS1BQG3 release-keys
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q313MB_25_04_2018_21_53_45.bin.
Connect successful.
SW: 1.5.6; FW: 1.23.
P00: GPT              (00000000, 00002000)	4 MB
P01: apnhlos          (00002000, 00007800)	15 MB
P02: modem            (00009800, 0001C980)	57.19 MB
P03: sbl1             (00026180, 00000400)	512 KB
P04: ddr              (00026580, 00000040)	32 KB
P05: aboot            (000265C0, 00001000)	2048 KB
P06: rpm              (000275C0, 00000400)	512 KB
P07: qsee             (000279C0, 00000600)	768 KB
P08: qhee             (00027FC0, 00000400)	512 KB
P09: fsg              (000283C0, 00001800)	3072 KB
P10: sec              (00029BC0, 00000020)	16 KB
P11: pad              (00029BE0, 00005420)	10.52 MB
P12: param            (0002F000, 00005000)	10 MB
P13: efs              (00034000, 00007000)	14 MB
P14: modemst1         (0003B000, 00001800)	3072 KB
P15: modemst2         (0003C800, 00001800)	3072 KB
P16: boot             (0003E000, 00006800)	13 MB
P17: recovery         (00044800, 00007800)	15 MB
P18: fota             (0004C000, 00005FFA)	12 MB
P19: backup           (00051FFA, 000037EE)	6.991 MB
P20: fsc              (000557E8, 00001800)	3072 KB
P21: ssd              (00056FE8, 00000010)	8 KB
P22: persist          (00056FF8, 00004000)	8 MB
P23: persistent       (0005AFF8, 00000800)	1024 KB
P24: persdata         (0005B7F8, 00004808)	9.004 MB
P25: system           (00060000, 00548000)	2704 MB
P26: cache            (005A8000, 00064000)	200 MB
P27: userdata         (0060C000, 0174DFD8)	11.65 GB
Old 04-26-2018, 04:56   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hi.
At first make full backup of the device - read Full flash.
To repair the device, try to do the following:
1. Connect the device.
2. Do "Factory Repair" ("Factory repair" tab in Software) using proper PIT file and the latest full Samsung firmware for SM-J5108 (if exist, try to find and use 4-files firmware).
3. Fully charge device's battery and try to put the device into Download (Emergency) Mode (manually or using Samsung JIG cable).
4. Post here the result.
The Following 3 Users Say Thank You to Medusa Box For This Useful Post:
Old 04-26-2018, 05:31   #3 (permalink)
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
Hi Team,
Googled for hours, couldn't find pit for SM-J5108. Is SM-J5108 Pit file Available in support area?
Or can anyone please upload pit File for SM-J5108 ?
Old 04-26-2018, 05:54   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
We don't have PIT file for this device at the moment also. You can try to find and use PIT for SM-J510F or SM-J510FN, maybe it is compatible. Or try to read PIT from working SM-J5108, if You have.
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 04-26-2018, 08:40   #5 (permalink)
Member: 1766494
Sonork: 100.1649672
Thanks Meter: 325
Hi team,
when i click smart report option i got report like below.
is this normal?
Smart report info:
Hash code: 0000000000000000000000000000000000000000000000000000000000000000
Super block size              : 0x00000000 Bytes
Super page size               : 0x00000000 Bytes
Optima write size             : 0x00000000 Bytes
Number of banks               : 0
Bank0 init bad block          : 0
Bank0 runtime bad block       : 0
Bank0 remain reserved block   : 0
Max erase count               : 0
Min erase count               : 0
Avg erase count               : 0
Read reclaim count            : 0
Optimal trim size             : 0x00000000 Bytes
Max erase count (SCL)         : 0
Min erase count (SCL)         : 0
Avg erase count (SCL)         : 0
Max erase count (MLC)         : 0
Min erase count (MLC)         : 0
Avg erase count (MLC)         : 0
Old 04-26-2018, 09:27   #6 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Please re-connect the device, perform "Smart Report" operation again and post here full Software log with device connection info and with "Smart Report" operation, we will check in details.
The Following 2 Users Say Thank You to Medusa Box For This Useful Post:
Page generated in 0.19378 seconds with 9 queries
