02-08-2018, 18:23 | #1 (permalink) |
Freak Poster Join Date: May 2016 Location: India,Odisha Age: 27
Member: 2573604 Status: Offline Thanks Meter: 30 | How to use eMMC HW Partition [Answered] I don't understand to use it's Last edited by Medusa Box; 02-09-2018 at 06:05. |
02-09-2018, 06:05 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Please explain what do You want to do exactly? What is your device (eMMC)? Also post here full Software log with device (eMMC) connection, we will check it and write You, what to do the next. |
02-10-2018, 05:22 | #3 (permalink) |
Member: 2573604 Status: Offline Thanks Meter: 30 | Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G1d Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473164040501A26824C1A7 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G1d Product revision : 0.5 Product serial number : (hex) 1A26824 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G1d_10_02_2018_09_50_30.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.3; FW: 1.22. P00: EXT2FS (001F6A00, 00071000) 226 MB P01: EXT2FS (00267A00, 00296000) 1324 MB P02: EXT2FS (00004800, 00005000) 10 MB P03: EXT2FS (00009800, 00005000) 10 MB P04: EXT2FS (0001BA00, 001DB000) 950 MB |
02-10-2018, 10:12 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | OK, this is connection log of device (Hynix eMMC H4G1d). What exactly do You want to do with this device and what is the problem? |
The Following User Says Thank You to Medusa Box For This Useful Post: |
02-10-2018, 12:18 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Unfortunately, we have no "Live Log" with necessary eMMC settings for this device. Try to leave them as is and write original firmware or backups for this device, if you have. |
02-10-2018, 12:34 | #7 (permalink) |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | here is live micromax d321 here is live micromax d321 08/02/2018 2:46:48 PM> EMMC Device Information : 08/02/2018 2:46:48 PM> EMMC CID: 90014A483447316404050BA21DD93232 08/02/2018 2:46:48 PM> EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 08/02/2018 2:46:48 PM> EMMC Manufacture Name: SKHYNIX , EMMC NAME: H4G1d , EMMC NAME (HEX): 483447316400 , S/N: 0BA21DD9 , rev. 0x05 08/02/2018 2:46:48 PM> EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 3/2015 08/02/2018 2:46:48 PM> EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) 08/02/2018 2:46:48 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 08/02/2018 2:46:48 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 08/02/2018 2:46:48 PM> EMMC Permanent Write Protection: No 08/02/2018 2:46:48 PM> EMMC Temporary Write Protection: No 08/02/2018 2:46:48 PM> Extended CSD Information : 08/02/2018 2:46:48 PM> Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) 08/02/2018 2:46:48 PM> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 08/02/2018 2:46:48 PM> Boot Bus Config: 0x00 , width 1bit 08/02/2018 2:46:48 PM> H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled 08/02/2018 2:46:48 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 08/02/2018 2:46:48 PM> Device supports partitioning features 08/02/2018 2:46:48 PM> Device can have enhanced technological features in partitions and user data area 08/02/2018 2:46:48 PM> Device can have extended partitions attribute 08/02/2018 2:46:48 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 08/02/2018 2:46:48 PM> Backup saved: H4G1d_0BA21DD9_20180208_144648.extcsd 08/02/2018 2:46:48 PM> EMMC Init completed. 08/02/2018 2:46:48 PM> 08/02/2018 2:46:48 PM> Scanning soft partitions 08/02/2018 2:46:48 PM> MBR header is found. Analyzing data ... 08/02/2018 2:46:48 PM> EBR detected at address: 000000080000 08/02/2018 2:46:48 PM> Partition: mmcblk0p0 [000000900000 - 000001300000], size: 000000A00000 08/02/2018 2:46:48 PM> Partition: mmcblk0p1 [000001300000 - 000001D00000], size: 000000A00000 08/02/2018 2:46:48 PM> Partition: mmcblk0p2 [000003740000 - 00003ED40000], size: 00003B600000 08/02/2018 2:46:48 PM> Partition: mmcblk0p3 [00003ED40000 - 00004CF40000], size: 00000E200000 08/02/2018 2:46:48 PM> Partition: mmcblk0p4 [00004CF40000 - 00009FB40000], size: 000052C00000 08/02/2018 2:46:48 PM> Partition: mmcblk0p5 [00009FB40000 - 02000007FE00], size: 01FF6053FE00 08/02/2018 2:46:48 PM> MBR header successfully parsed 08/02/2018 2:46:48 PM> 08/02/2018 2:46:48 PM> Get firmware version 08/02/2018 2:46:48 PM> 08/02/2018 2:46:48 PM> Brand = Micromax 08/02/2018 2:46:48 PM> Manufacturer = Micromax 08/02/2018 2:46:48 PM> Model = Micromax D321 08/02/2018 2:46:48 PM> CPU Abi = armeabi-v7a 08/02/2018 2:46:48 PM> Mediatek platform = MT6572 08/02/2018 2:46:48 PM> Android release = 4.4.2 08/02/2018 2:46:48 PM> Firmware version = ALPS.KK1.MP7.V1 08/02/2018 2:46:48 PM> Firmware date = Tue Jul 7 21:04:16 CST 2015 |
The Following User Says Thank You to royalnasim For This Useful Post: |
