10-26-2017, 17:56 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: chile Age: 44
Member: 88102 Status: Offline Thanks Meter: 4 | How write motorola backup .bin? i have sucesfully removed frp to xt1641 but it lost the imei. how is posible write the .bin backups ? log: Welcome to Medusa Pro Software version 1.4.6. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 150100515831334D4207FAFEFC8293A1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) FAFEFC82 Manufacturing date : 09/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QX13MB_23_10_2017_16_33_57.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.6; FW: 1.22. Please select file. Opening C:/Program Files/Medusa Pro Software/Samsung eMMC QX13MB_23_10_2017_16_34_52.bin file... Reading. Please wait... ERROR[011]: Read error. At sector 0 Attempting to read... Canceled... Elapsed time 00:00:15 SW: 1.4.6; FW: 1.22. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : 20 MHz Connecting... Device : Samsung eMMC QX13MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 150100515831334D4207FAFEFC8293A1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QX13MB Product revision : 0.7 Product serial number : (hex) FAFEFC82 Manufacturing date : 09/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 2523136 Number of sectors : 5242880 Device Manufacturer : motorola Device Platform : msm8952 Build ID : NPJ25.93-14-8.1 Release ID : 7.0 Device Model : Moto G (4) Device Name : athene_retail Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QX13MB_23_10_2017_16_36_29.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.6; FW: 1.22. P00: GPT (00000000, 00000100) P01: modem (00000100, 00032000) P02: fsc (00032100, 00000002) P03: ssd (00032102, 00000010) P04: sbl1 (00032112, 00000400) P05: sbl1bak (00032512, 00000400) P06: rpm (00032912, 000001B0) P07: rpmbak (00032D12, 000001B0) P08: tz (00033112, 00000718) P09: tzbak (00033D12, 00000718) P10: hyp (00034912, 000000C0) P11: hypbak (00034D12, 000000C0) P12: dsp (00035112, 00008000) P13: modemst1 (0003D112, 00001000) P14: modemst2 (0003E112, 00001000) P15: DDR (0003F200, 00000040) P16: fsg (0003F240, 00004000) P17: sec (00043240, 00000020) P18: aboot (00043300, 00000BB8) P19: abootbak (00043F00, 00000BB8) P20: logs (00044B00, 00001000) P21: utags (00045B00, 00000400) P22: utagsBackup (00045F00, 00000400) P23: cid (00046300, 00000100) P24: logo (00046400, 00008000) P25: clogo (0004E400, 00008000) P26: metadata (00056400, 00000400) P27: kpan (00056800, 00004000) P28: boot (0005A800, 00008000) P29: recovery (00062800, 000080C8) P30: persist (0006A900, 00010000) P31: misc (0007A900, 00000800) P32: config (0007B100, 00000040) P33: limits (0007B200, 00000040) P34: mota (0007B300, 00000800) P35: devcfg (0007BB00, 00000200) P36: dip (0007BD00, 00000800) P37: syscfg (0007C500, 00000400) P38: cmnlib (0007C900, 00000188) P39: keymaster (0007CB00, 000001B8) P40: frp (0007CD00, 00000400) P41: padC (0007D100, 0000AF00) P42: sp (00088000, 00004000) P43: hw (0008C000, 00004000) P44: customize (00090000, 00010000) P45: oem (000A0000, 00148000) P46: cache (001E8000, 00080000) P47: system (00268000, 00500000) P48: userdata (00768000, 032C5F00) Backuping Gpt partition... Opening C:/Program Files/Medusa Pro Software/Backups/QX13MB_Gpt_0x0_0x100_23_10_2017_16_36_29.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.6; FW: 1.22. Backuping Cid partition... Opening C:/Program Files/Medusa Pro Software/Backups/QX13MB_Cid_0x46300_0x100_23_10_2017_16_36_29.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.6; FW: 1.22. Erasing partition frp... Done. Erasing is finished. SW: 1.4.6; FW: 1.22. Disconnected. |
10-27-2017, 05:44 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
To write GPT partition backup: 1. Connect the device. 2. Select "Custom" option in Software. 3. Select "HEX blocks" value. 4. Set "Start: 0". 5. Set "Length: 100". 5. Press "Write" button, select GPT backup file ("QX13MB_Gpt_0x0_0x100_23_10_2017_16_36_29.bin") and write it. To write CID partition backup: 1. Connect the device. 2. Select "Custom" option in Software. 3. Select "HEX blocks" value. 4. Set "Start: 46300". 5. Set "Length: 100". 5. Press "Write" button, select GPT backup file ("X13MB_Cid_0x46300_0x100_23_10_2017_16_36_29.bin") and write it. | ||
The Following User Says Thank You to Medusa Box For This Useful Post: |
