HTC desire A8183 I have here HTC Desire A8183 PB99210 the phone does not turn on I tried to insert charger at first responded with green light, then no light at all I tried to hold volume down and power on but it does not work! I tried to use RPS but the phone blinks red and green only and does not turn on at all. I'm a newbie with this phone need advice TIA! |
Hello. What is the state of your phone? Have You tried to repair it? Please post here full software log with all of your actions. |
Log started at 2/13/2012 2:01:46 PM ... Welcome to Medusa Box Software version 1.3.5 Selected device model: HTC Desire (PB99200) Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 126 ns, average speed 7936 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 202400E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.48 V CPU : Qualcomm QSD8250 Core ID : 202400E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x0000007F. MI: Detailed server caps: FLASH, CFG, ECC, BASE, WDOG, DWP, SAFEW MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0x0055ECBC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 0000007F Flash device: Samsung 512Mb Flash ID : 00EC55BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. HTC CID : TELST001 IMEI : 359112-03-513*** Connect successful. ECC Mode enabled. Write protection disabled. Rading codes. Please wait... Active lock codes not found. Done Opening "C:\Documents and Settings\Win\My Documents\Downloads\HTC_DESIRE_FullFlash.mf" file... Writting BOOT section. Please wait... Done Writting FIRMWARE section. Please wait... Done Write protection disabled. Repairing CID and IMEI... ERROR[038]: HTC security partition not found or damaged. Disconnected Selected device model: HTC Desire (PB99200) Connecting. Please wait... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 202400E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.52 V CPU : Qualcomm QSD8250 Core ID : 202400E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x0000007F. MI: Detailed server caps: FLASH, CFG, ECC, BASE, WDOG, DWP, SAFEW MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0x0055ECBC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 0000007F Flash device: Samsung 512Mb Flash ID : 00EC55BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. Connect successful. Write protection disabled. Repairing CID and IMEI... ERROR[038]: HTC security partition not found or damaged. Disconnected Selected device model: HTC Desire (PB99200) Connecting. Please wait... MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 202400E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.52 V CPU : Qualcomm QSD8250 Core ID : 202400E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x0000007F. MI: Detailed server caps: FLASH, CFG, ECC, BASE, WDOG, DWP, SAFEW MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0x0055ECBC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 0000007F Flash device: Samsung 512Mb Flash ID : 00EC55BC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. Opening "C:\Documents and Settings\Win\My Documents\Downloads\HTC_DESIRE_Repair.mf" file... Writting BOOT2 section. Please wait... Done Writting HTC2 section. Please wait... Done Writting APPBOOT2 section. Please wait... Done Repairing CID and IMEI... Done Disconnected this is the logs after my actions but still the phone doesn't display anything. Black screen when I try to power on. Using volume down and power button, the indicator blinks orange and green light but black display means no power. Even I use RPS. |
Just want to follow up. Any further solution with my problem with this phone? Is PB99210 really supported and can be flashed with PB99200 like I already did? Is there any option to turn this phone back alive? Any help will be much appreciated. TIA! |
