Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 07-06-2013, 16:29   #1 (permalink)
Member: 57712
Thanks Meter: 28
HTC Desire C (PL01100)
HTC Desire C (PL01100) - added Unlock (via Read Codes), Repair CID, Repair IMEI,
i have phone working need change CID
no detect the phone
Welcome to Medusa Box Software version 1.8.8
Selected device model: HTC Desire C (PL01100)
Connecting. Please wait...
VREF = 0.0V is less than required level. Please check target device power supply.
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision C.
ERROR[045]: Scan chain is too long or damaged. Scanned TAP ID's list:
0x000000C1
0x00000000
0x00000000
0x00000000
0x00000000
0x00000000
0x00000007
0x00000000
MI: Medusa JTAG init failed.
Old 07-08-2013, 06:16   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 20,992
Hello.
Most likely, You soldered some Jtag wires incorrectly. Please check soldering of all Jtag wires and try again. Don't forget to fully charge phone's battery. To power your device use fully charged battery and USB cable. We have tried with our device and Connect was successfully:
Detected TAP ID: 106010E1, IR Length = 4.
JTAG speed : Auto (RTCK).
VREF level : 1.79 V
CPU : Qualcomm MSM7225A
Core ID : 106010E1
Storage Device: Samsung eMMC SJS00A
Device ID : 00150001
Block size : 512 bytes
Blocks : 4751360
Storage size : 2320 Mb
Connect successful.
Old 08-06-2013, 22:22   #3 (permalink)
Member: 145175
Thanks Meter: 21
mr supporter
can u add phone jtag picture
ı have desire c but not connect cpu
Can u help me please
Old 08-15-2013, 09:36   #4 (permalink)
clone's Avatar
Member: 19327
Thanks Meter: 45
I have the same problem ...
I would like to "repair imei" on a working phone , but can't connect to the board .. Yes,i checked the soldered wires - i tried two different wires -as you can see in the pictures in my comment.(that you couldn't see : the reset wire is soldered too on the backside) Yes, the battery is fully charged,and i use charger or usb wire too.
By RTCK selection - the result is the same,like the first poster(expect the VREF -it is 1.75V)
By 100kHz manual mode the result is the following :
JTAG speed : 100 KHz.
VREF level : 1.75 V
Core ID : 106010E1
ERROR[004]: Medusa Device Server did not replied to HELLO command.
Could you suggest me any other thing ,that i have never tried ?
http://forum.gsmhosting.com/vbb/atta...1&d=1376555543
Old 08-15-2013, 11:09   #5 (permalink)
Member: 1146942
Sonork: 100.1587278
Hello.
Please try to connect your phone in Auto Mode (select "Manufacturer: Auto", "Device model: MSM72xx/MSM76xx", "JTAG speed: Auto (RTCK)") and post here log.
Also please use both - fully charged battery and USB cable at the same time for powering the device.
Old 08-15-2013, 11:18   #6 (permalink)
clone's Avatar
Member: 19327
Thanks Meter: 45
Unfortunately it is the same situation .. And of course i try it with usb and battery power at the same time. It isn't my first jtag "project"
http://forum.gsmhosting.com/vbb/atta...1&d=1376561833
In RTCK mode :
Selected device model: Qualcomm MSM72xx/MSM76xx
In : 100 kHz manual mode :
Old 08-16-2013, 10:10   #7 (permalink)
Member: 1146942
Sonork: 100.1587278
Also please try to connect the phone by the next way:
1. Disconnect phone's battery, mictro USB cable and Jtag wires.
2. Connect soldered Jtag wires to Box and press "Connect" button in Software.
3. Connect fully charged battery and press "Power On" button.
4. If the phone not connects, You can (should) try to connect it a few times by the same way.
Currently we have no this device in our hands, so we cant check whether can be the problem with your device exactly. We have tested now on HTC Explorer (with the same CPU) and the mentioned above connectin procedure works OK.
Old 08-16-2013, 10:25   #8 (permalink)
clone's Avatar
Member: 19327
Thanks Meter: 45
I have done all steps but the result is exactly the same Not the first phone,that i couldn't done with the medusa - tomorrow i'll make one more try with an other PC , but today i have no more time for it .
Old 11-09-2013, 01:12   #9 (permalink)
richiricherd's Avatar
Member: 594580
Thanks Meter: 134
Im facing exactly same situation with same phone
Old 11-09-2013, 08:04   #10 (permalink)
Member: 1146942
Sonork: 100.1587278
Hello.
Please post here full software log and describe all of your actions step by step how You connect the device.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 11-10-2013, 02:06   #11 (permalink)
Member: 594580
Thanks Meter: 134
Originally Posted by Octopus box View Post
Hello.
Ok Sir, Ive check very well solder points and all are ok but I have same problem, cant conect the phone.. Here is log:
Selected device model: Auto
Medusa JTAG Hardware S256 revision C.
VREF level : 1.74 V
Core ID : 106010E1
0x000010E1
0x00000000
0x00000000
0x00000000
0x0000001F
0x00000000
0x0000000F
0x0000000F
Ive tried HTC Decire C model and Auto model and same result, Ive tried diferent Jtag speed and only with 100 Khz I get this:
VREF level : 1.74 V
Core ID : 106010E1
But if I select directly CPU type Qualcom MSM72xx/MSM76xx and 100 Khz speed I get this:
VREF level : 1.74 V
Core ID : 106010E1
Storage Device: Hynix eMMC XINYH
Device ID : 00904A01
Blocks : 4702208
Storage size : 2296 Mb
Connect successful.
But there are not options for repair IMEI Sir.. What can I do next??
The Following User Says Thank You to richiricherd For This Useful Post:
Old 11-10-2013, 07:16   #12 (permalink)
Member: 1146942
Sonork: 100.1587278
Hello.
To make Repair IMEI, You need to connect the device as HTC Desire C (PL01100).
To connect the device try to do the next steps:
Old 11-13-2013, 20:31   #13 (permalink)
Member: 594580
Thanks Meter: 134
Ok Sir I think that I found the problem, and Im sorry cause my mistake, this phone is HTC Desire C ( PL01130 ) not ( PL01100 ) as you support that Desire C only..
Im very ashame sir..
Old 01-17-2014, 18:41   #14 (permalink)
Member: 594580
Thanks Meter: 134
Sir please add support for Desire C PL01130, I think is equal than PL01100 but your software refuses it because not exactly same number but same hardware.. Only diference in hardware is 3G Bands frecuency..
Old 11-30-2014, 15:01   #15 (permalink)
Member: 1473248
Sonork: Tecnico
Thanks Meter: 4
A doubt desiree htc PL01130, I selected the model of octoplus jtag PL01100 to repair imei?
Una duda, el htc desiree PL01130, debo de seleccionar el modelo en jtag de octoplus PL01100 para poder reparar el imei?
Page generated in 0.46023 seconds with 8 queries
