Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 07-18-2013, 16:11   #1 (permalink)
Member: 509151
HTC Droid Incredible 2 error
Ask for help in reading the lock code, the net!
Selected device model: HTC Droid Incredible 2 (ADR6350)
Connecting. Please wait...
Resetting target. Please wait...
VREF = 0.0V is less than required level. Please check target device power supply.
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision C.
Detected TAP ID: 17B360E1, IR Length = 5.
JTAG speed  : Auto (RTCK).
VREF level  : 1.81 V
CPU         : Qualcomm MSM8655
Core ID     : 105800E1
ERROR[008]: Unknown flash device. Device No:ID = 0:00000000.
ERROR[035]: Target device has been powered off during connect.
As HTC Incredible S
Selected device model: HTC Incredible S (PG32130)
VREF level  : 1.81 V
Core ID     : 105800E1
Storage Device: Samsung eMMC M4G2DE
Device ID     : 00150001
 Block size   : 512 bytes
 Blocks       : 4407296
 Storage size : 2152 Mb
HTC CID     : VZW__001
IMEI        : 358897-04-828542
Connect successful.
Reading codes. Please wait...
HTC: Unable to read key.
ERROR[038]: HTC security partition not found or damaged. Please make sure that You selected correct device model, do EasyRepair to rebuild security.
ERROR[028]: Target device has been disconnected ...
Disconnected
(RTCK) tried to manually set
Old 07-18-2013, 16:45   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 20,931
Hello.
What is your HTC Droid Incredible 2 revision exactly? ADR6350?
Old 07-18-2013, 19:21   #3 (permalink)
Member: 509151
Hello.
HTC Droid Incredible 2 ADR6350VW
Old 07-19-2013, 07:12   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Ok, please try to connect the device as HTC Droid Incredible 2 (ADR6350) using new test software version we have sent You into your PM and then post the result here.
Old 07-19-2013, 08:02   #5 (permalink)
Member: 509151
Here's the log. Codes do not read. There is support for this model?
VREF level  : 1.81 V
Core ID     : 105800E1
 Blocks       : 4407296
HTC CID     : VZW__001
Connect successful.
Disconnected
Old 07-19-2013, 10:41   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
Seems, ADR6350VW is an another revision of HTC Droid Incredible 2 than ADR6350. Please, read out 128 MB custom flash, upload it somewhere and post here link, we will research and try to prepare new test version for You.
Old 07-19-2013, 21:02   #7 (permalink)
Member: 509151
Thank you
HTC Droid Incredible 2 (ADR6350) Custom 19-07-2013 21_21_04.rar ? Yandex.Disk
Old 07-22-2013, 07:39   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Sorry, to add this revision, we need to have your device in our hands to get some info from it... It is impossible to do this remotely.
The Following User Says Thank You to Octopus box For This Useful Post:
Page generated in 0.24235 seconds with 7 queries
