10-26-2017, 16:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: india
Member: 2097870 Status: Offline Sonork: FINDING.... Thanks Meter: 65 | Htc op6b650 boot repair problem MY PHONE INFO Model Settings: Interface : eMMC Brand : HTC Model : One_M8 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/HTC_ONE_M8_EMMC_HBG4E.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : 2 MHz Connecting... Device : Hynix eMMC HAG4d Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 90014A4841473464040501C53C454125 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4d Product revision : 0.5 Product serial number : (hex) 1C53C45 Manufacturing date : 04/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/HAG4d_26_10_2017_08_35_24.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.7; FW: 1.22. Last edited by Medusa Box; 10-27-2017 at 05:00. |
10-27-2017, 05:46 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
