05-26-2018, 16:59 | #1 (permalink) |
Insane Poster Join Date: May 2010 Location: iran_khoozestan
Member: 1313184 Status: Offline Thanks Meter: 14 | HTC PN07110 dead boot repair question [Answered] Checking data... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 207150E1, IR Length = 11. JTAG speed : Auto (RTCK). VREF level : 3.55 V CPU : Qualcomm APQ8064T Core ID : 207150E1 ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Checking data... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4F1F0F0F, IR Length = 4. Detected TAP ID: 207150E1, IR Length = 11. JTAG speed : Auto (RTCK). VREF level : 3.55 V CPU : Qualcomm APQ8064T Core ID : 207150E1 ERROR[008]: Unknown flash device. Device No:ID = 0:00000000. ERROR[035]: Target device has been powered off during connect. Last edited by Medusa Box; 05-26-2018 at 18:16. |
05-26-2018, 18:15 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Quote:
Please carefully re-solder all JTAG wires, make each of them as short as possible (max. 3-5 CM length) and try to connect again. To connect the device, do the next steps: 1. Fully charge phone's battery by using external charger, this is important. 2. Power off the device (disconnect the cable, disconnect the battery). 3. Connect JTAG wires and press "Connect" button in Software. 4. Insert the battery and connect the USB cable. Connect cable directly to PC USB port, don't use USB hubs. Try to repeat these operations several times. Try to set (select) different JTAG speeds. If the problem is still the same, most likely, your device has HW problem. | |
05-28-2018, 08:43 | #3 (permalink) |
Member: 1313184 Status: Offline Thanks Meter: 14 | 1. Fully charge phone's battery by using external charger, this is important. 2. Power off the device (disconnect the cable, disconnect the battery). 3. Connect JTAG wires and press "Connect" button in Software. 4. Insert the battery and connect the USB cable. Connect cable directly to PC USB port, don't use USB hubs. but have this erorre Selected device model: HTC One M7 (PN07110) Connecting. Please wait... Checking data... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 4BA00477, IR Length = 4. Detected TAP ID: 207150E1, IR Length = 11. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. JTAG speed : 1000 KHz. VREF level : 3.51 V CPU : Qualcomm APQ8064T Core ID : 207150E1 ERROR[004]: Medusa Device Server did not replied to HELLO command. Report Post |
