11-11-2013, 13:43 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | HTC Rhyme (PI46100) USB Boot Done But Cid Not Change Connecting. Please wait... Interface : USB CPU : Qualcomm MSM8x55 Storage Device: ******* eMMC SEM04G Device ID : 00450001 Block size : 512 bytes Blocks : 5144576 Storage size : 2512 Mb HTC CID : HTC__622 IMEI : 35XX71-0X-6XXXXX Opening "D:\Medusa Files\HTC\HTC Ryhme\HTC_RHYME_USB_Repair.mf" file... Writing BOOT section. Please wait... Done Writing APPBOOT section. Please wait... Done Repairing CID and IMEI... Done Disconnected Repair done. Boot Repair Ok But Super Cid and IMEI Repair Fail Same as Before Any Help Even Bootloader Still Unlocked Custome CWM Still Inside Main Version Still Same I Need Solution Please Help If Any One Know About this Problem Thanks , ..::Rizwan::.. |
11-12-2013, 10:45 | #3 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | We have tested on our device - CID and IMEI were successfully repaired. Please make Repair CID and IMEI again, then read out 256 MB of flash, upload it somewhere and post here link, we will check where is the problem with your device. |
11-13-2013, 11:52 | #4 (permalink) |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | OK i will upload after read today please check what happen why my side cid main version imei even custome recovry and bootloader unlocked still Like Before |
11-13-2013, 12:39 | #5 (permalink) |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | i think its write protected chip coz not accept any custome rom also not able to relock bootloader thats why also not able to change cid or imei in advance repair i have one option disable write protection but after 2 times check with this option nothing change just software said connection disconnect successfully i m reading full flash and will upload soon please check and give me any solution and also if u can please uplaod full dump of rhyme on support erea thanks |
04-12-2014, 10:03 | #7 (permalink) |
Registered User Join Date: Mar 2011 Location: dubai
Member: 1545797 Status: Offline Sonork: 1596859 Thanks Meter: 91 | htc rhyme boot repair problam concet gnd point mobile concet only zeus flash device driver only plz help me whhat iss the problam Last edited by Octopus box; 04-14-2014 at 06:22. |
04-14-2014, 09:42 | #10 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Re-install manually drivers from the folder "c:\Program Files\GsmServer\Medusa\Driver\QHSUSB\" and repeat Repair procedure again. |
04-15-2014, 16:02 | #11 (permalink) | |
Member: 1545797 Status: Offline Sonork: 1596859 Thanks Meter: 91 | Quote:
sir i try this butt again same error | |
04-15-2014, 16:07 | #12 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | You have not installed correct drivers. Uninstall zeus drivers and install correct drivers manually from the folder "c:\Program Files\GsmServer\Medusa\Driver\QHSUSB\. |
04-15-2014, 18:57 | #13 (permalink) |
Member: 1545797 Status: Offline Sonork: 1596859 Thanks Meter: 91 | sir thanks driver iss install butt see new error Welcome to Medusa Box Software version 2.1.6 Selected device model: HTC Rhyme (PI46100) USB Connecting. Please wait... Canceled... Selected device model: HTC Rhyme (PI46100) USB Connecting. Please wait... Interface : USB CPU : Qualcomm MSM8x55 Storage Device: ******* eMMC SEM04G Device ID : 00450001 Block size : 512 bytes Blocks : 131077 Storage size : 65538.5 Kb Opening "D:\All Flash file\Mudsa\Rhyme\HTC_RHYME_USB_Repair.mf\HTC_RHYME _USB_Repair.mf" file... Writing BOOT section. Please wait... ERROR[018]: Logical block operation failed at 0 Kb (Hex address 0x00000000). Reason: Command failed. |
04-16-2014, 06:24 | #15 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Try to perform the operation several times. If always arise the the same error: Quote:
