05-02-2020, 20:16 | #2 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | open the phone and look at PCB if it's LND-AL20/30/40 if yes then just fellow those step and u r ok 1-open huawei tool and select the model was written on PCB 2-download board firmware for your model was written on PCB from support 3- write firmware and uncheck modem 1 & 2 and oem info 4-when phone bootup successfully do as the bellow picture after that phone bootup again make connect and you'll see 2nd imei calculated go repair tab and write 2nd imei and make repair after repair done download full OTA dependes on your region Europe : africa+middle east : Now extract the firmware and flash APP via fastboot after phone bootup then work done & Enjoy |
The Following User Says Thank You to starkrimes For This Useful Post: |
05-03-2020, 08:40 | #3 (permalink) |
Freak Poster Join Date: May 2019 Location: Gujranwala
Member: 2909174 Status: Offline Sonork: 100.650600 Thanks Meter: 77 | My dead brother you is too good man but sir i face this probleme i tried many times but always sending loader failed i try change many loaders but not succeced now i decied flash with isp pinouts but i could not found isp points octoplus huawei logs are here below Welcome to Octoplus Huawei Software v.1.1.6.1 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2: COM49 Qualcomm HS-USB Diagnostics 9006 3: COM5 USB Serial Port 2020-04-30 12:38:47 GMT ------------------------------------------------- Starting Reset FRP (Test Point) Selected phone model: LDN-TL10 Initializing remote service connection... Connecting to phone.. Please, reconnect battery, connect USB cable with attached Test Point on your phone! Phone connect successfully Sending loader Qualcomm MSM8937V.0.mbn... Error: Sending loader failed! Initializing remote service connection... Error: Cant get bootloader file from remote... Reset FRP (Test Point) failed. Performed by 1.1.6.1 Software version. Selected file: C:/Users/UMAIR SAHIL/Music/Firehose LDN.mbn Selected file: C:/Users/UMAIR SAHIL/Downloads/Compressed/Huawei Y7 Prime 2018 LDN-XXX_Dead Boot Repair_BY_Smart_Solutions/rawprogram0_qcfire.xml Selected file: C:/Users/UMAIR SAHIL/Downloads/Compressed/Huawei Y7 Prime 2018 LDN-XXX_Dead Boot Repair_BY_Smart_Solutions/patch0_qcfire.xml 2020-04-30 12:43:04 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Searching Fastboot devices... Error: Fastboot devices not found Read Info (Fastboot Mode) failed. Performed by 1.1.6.1 Software version. Selected file: C:/Users/UMAIR SAHIL/Music/Firehose LDN.mbn Selected file: C:/Users/UMAIR SAHIL/Downloads/Compressed/Huawei Y7 Prime 2018 LDN-XXX_Dead Boot Repair_BY_Smart_Solutions/rawprogram0_qcfire.xml Selected file: C:/Users/UMAIR SAHIL/Downloads/Compressed/Huawei Y7 Prime 2018 LDN-XXX_Dead Boot Repair_BY_Smart_Solutions/patch0_qcfire.xml Selected phone model: LDN-TL10 2020-04-30 12:44:03 GMT ------------------------------------------------- Starting Write Firmware Warning: Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don’t turn off phone and don’t disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage Connecting to phone.. Please, reconnect battery, connect USB cable with attached Test Point on your phone! Phone connect successfully Sending loader Firehose LDN.mbn... Error: Sending loader failed! Write Firmware failed. Performed by 1.1.6.1 Software version. Selected file: C:/Users/UMAIR SAHIL/Music/LDN-AL10-BD_1.0.0.28_Download.obf Selected phone model: LDN-TL10 Selected 'Easy downgrade' mode 2020-04-30 12:44:25 GMT ------------------------------------------------- Starting Write Firmware Warning: Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don’t turn off phone and don’t disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage Connecting to phone.. Please, reconnect battery, connect USB cable with attached Test Point on your phone! Phone connect successfully Sending loader tmp.obf... Error: Sending loader failed! Write Firmware failed. Performed by 1.1.6.1 Software version. Selected file: C:/Users/UMAIR SAHIL/Music/LDN-AL10-BD_1.0.0.37_Download.obf Selected phone model: LDN-TL10 Note! If write nvme and oeminfo partitions in Bord Firmware mode, to your device will record default Imei, SN and other calibration settings, the original IMEI, SN and calibration will be corrupted and you will have to restore through another mode. Press 'Easy downgrade' button if you want to write without erasing the security and NV Press 'Full Repair' button if you want to write all partitions include NV Selected 'Full Repair' mode 2020-04-30 12:45:13 GMT ------------------------------------------------- Starting Write Firmware Warning: Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don’t turn off phone and don’t disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage Connecting to phone.. Please, reconnect battery, connect USB cable with attached Test Point on your phone! Phone connect successfully Sending loader tmp.obf... Error: Sending loader failed! Write Firmware failed. Performed by 1.1.6.1 Software version. |
05-03-2020, 21:09 | #4 (permalink) |
Member: 1191316 Status: Offline Thanks Meter: 900 | what's the phone states? if still startup you need to write board firmware as your models on PCB if loader still not working then you need to check CLK & CMD resistors cause also if they are damaged loader won't work |
05-05-2020, 08:03 | #6 (permalink) |
Member: 2909174 Status: Offline Sonork: 100.650600 Thanks Meter: 77 | Thanks for reply but i try many time dub-lx1 loader but always failed please can you tell me CLK & CMD ppints because i am unable to find this |
