07-23-2017, 16:17 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1867244 Status: Offline Thanks Meter: 63 | Sony E5633 dead boot repair [Solved] i have a E5633 dead after flash in my hand but i can not find any dump file for this besides is this chipset in normal condition ? Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 016G72 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 110100303136473732009FC9A7EA5247 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 016G72 Product revision : 0.0 Product serial number : (hex) 9FC9A7EA Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 01010000 Boot partition enable : Boot partition 2 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 24952832 Number of sectors : 5549056 Device Manufacturer : alps Device Platform : mt6795 Build ID : 30.1.B.1.55 Display Build ID : 30.1.B.1.55 Release ID : 5.1 Device Model : E5633 Device Name : Xperia M5 Dual Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : hollyds-user 5.1 2.0.J.0.0 1457498714 test-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/016G72_23_07_2017_19_45_10.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.0; FW: 1.20. P00: GPT (00000000, 00000400) P01: ta (00000400, 00001000) P02: proinfo (00001400, 00001800) P03: nvram (00002C00, 00002800) P04: protect1 (00005400, 00005000) P05: protect2 (0000A400, 00005000) P06: seccfg (0000F400, 00000400) P07: lk (0000F800, 00000800) P08: ltalabel (00010000, 00008000) P09: fotakernel (00018000, 00014000) P10: boot (0002C000, 00014000) P11: secro (00040000, 00003000) P12: para (00043000, 00000400) P13: logo (00043400, 00004000) P14: expdb (00047400, 00005000) P15: tee1 (0004C400, 00002800) P16: tee2 (0004EC00, 00002800) P17: metadata (00051400, 00010000) P18: gen (00061400, 00000800) P19: apps_log (00064000, 00008000) P20: diag (0006C000, 00008000) P21: oem (00074000, 00094000) P22: cache (00108000, 00064000) P23: userdata (0016C000, 01660000) P24: system (017CC000, 0054AC00) P25: flashinfo (01D16C00, 00008000) Backuping TA partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/016G72_TA_0x400_0x1000_23_07_2017_19_45_10.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.0; FW: 1.20. Analyzing Trim Area (TA)... Ok TA IMEI: sfsf Lock status: locked if u any one have dump file i would be appriciated to share it with me i need both ROM 2 ROM 3 dump files Last edited by Medusa Box; 07-25-2017 at 06:16. |
07-24-2017, 06:00 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Try to do "Factory Repair" using original Sony firmware in "*.FTF" or "*.SIN_FILE_SET" format. Post here the result. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
07-24-2017, 10:29 | #3 (permalink) |
Member: 1867244 Status: Offline Thanks Meter: 63 | the phone just work fine after repair . i write only rom 3 partition and flash with the latest firmware here is the log Welcome to Medusa Pro Software version 1.4.0. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 016G72 Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB --------------------------------------------------------------- CID Info CID : 110100303136473732009FC9A7EA5247 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 016G72 Product revision : 0.0 Product serial number : (hex) 9FC9A7EA Manufacturing date : 05/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 01010000 Boot partition enable : Boot partition 2 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7696384 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 24952832 Number of sectors : 5549056 Device Manufacturer : alps Device Platform : mt6795 Build ID : 30.1.B.1.55 Display Build ID : 30.1.B.1.55 Release ID : 5.1 Device Model : E5633 Device Name : Xperia M5 Dual Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : hollyds-user 5.1 2.0.J.0.0 1457498714 test-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/016G72_23_07_2017_21_59_24.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.0; FW: 1.20. P00: GPT (00000000, 00000400) P01: ta (00000400, 00001000) P02: proinfo (00001400, 00001800) P03: nvram (00002C00, 00002800) P04: protect1 (00005400, 00005000) P05: protect2 (0000A400, 00005000) P06: seccfg (0000F400, 00000400) P07: lk (0000F800, 00000800) P08: ltalabel (00010000, 00008000) P09: fotakernel (00018000, 00014000) P10: boot (0002C000, 00014000) P11: secro (00040000, 00003000) P12: para (00043000, 00000400) P13: logo (00043400, 00004000) P14: expdb (00047400, 00005000) P15: tee1 (0004C400, 00002800) P16: tee2 (0004EC00, 00002800) P17: metadata (00051400, 00010000) P18: gen (00061400, 00000800) P19: apps_log (00064000, 00008000) P20: diag (0006C000, 00008000) P21: oem (00074000, 00094000) P22: cache (00108000, 00064000) P23: userdata (0016C000, 01660000) P24: system (017CC000, 0054AC00) P25: flashinfo (01D16C00, 00008000) Backuping TA partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/016G72_TA_0x400_0x1000_23_07_2017_21_59_24.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.4.0; FW: 1.20. Analyzing Trim Area (TA)... Ok TA IMEI: asdasdasd Lock status: locked Switched to boot area partition 2. Opening C:/Users/Omid/Desktop/Sony_E5633_mt6795_mmcblk0boot1_ROM3.bin file... Write data verification is enabled. Writing. Please wait... Done. SW: 1.4.0; FW: 1.20. Disconnected. |
The Following 2 Users Say Thank You to mastershex For This Useful Post: |
