Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 07-10-2017, 05:16   #1 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 362
Huawei Rio_L03 can add to repair
Model Settings:
Interface : eMMC
Voltage : 3.3V
Bus Mode : 1
Bus speed : Auto
Connecting...
Device : Samsung eMMC R311MB
Core :
Page size : 512 B
Block size : 512 B
Block count : 2097152
CID Info
CID : 150100523331314D42068ECFC28BC259
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : R311MB
Product revision : 0.6
Product serial number : (hex) 8ECFC28B
Manufacturing date : 12/1999
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.0
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.0 (for MMC v4.0)
Erase block size : 0 Kbytes
Boot1 size : 0 Kbytes
Boot2 size : 0 Kbytes
RPMB size : 0 Kbytes
Partition config : 00000000
Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
Max enhanced data size: 0 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_09_07_2017_23_15_57.bin.
Connect successful.
SW: 1.3.4; FW: 1.16.
Old 07-10-2017, 06:41   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,815
Hello.
As You can see on your Software log, You have not connected eMMC chip correctly or chip is damaged - it is not correct, that eMMC capacity (size) is only 1 GB (1024.00 MB), also Erase block, Boot1, Boot2 and RPMB sizes can't be zero:
Page size : 512 B
Block size : 512 B
Try to make each eMMC wire as short as possible (max. 3-5 CM length) and connect the device again. Try to select lower Bus speed value and connect the device. Try to connect the device with 2.0V Voltage level. If the problem will still remain - most likely, eMMC chip has HW issue and should be replaced.
When eMMC will be connected correctly, try to do "Factory Repair" ("Factory Repair" tab in Software) using original firmware (Press «Repair devices based on Qualcomm CPU’s using XML files (*.xml)» button, elect «rawprogram0.xml» and «patch0.xml» files and write them).
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 07-10-2017, 06:55   #3 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 362
try to connect again but not have xml for repair this model only update but cant write by medusa or you have xml file for repair this model wait for you help
thanks
Old 07-10-2017, 07:13   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,815
Unfortunately, we have no firmware with "*.xml" or SRF for this device at the moment. We will try to find this phone and add support for it in one on the future Software updates.
Old 07-11-2017, 06:22   #5 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 362
team medusa find this soft RIO-L02_M105_Board Software_general_Android 5.1_EMUI 3.1_05021TKA is xml but medusa not enable write xml
wait for you help
model Settings:
Interface : eMMC
Voltage : 3.3V
Bus Mode : 4
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
Block count : 30535680
CID Info
Manufacturing date : 12/2015
CSD Info
CSD structure : CSD version No. 1.2
TRAN speed : 26 MHz
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : 00111000
Boot partition enable : User area (Bus width = 1Bit)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7626752 Kbytes
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_11_07_2017_00_18_07.bin.
Connect successful.
Old 07-11-2017, 06:44   #6 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,815
Yes, writing "*.xml" firmwares currently supported only via USB connection, not via eMMC. We have prepared test Software version for You. Please try to do "Factory Repair" (write "*.xml" firmware) using this test Software version and post the result.
Also please make photo (or scan) of device PCB in high quality, upload it somewhere and post here link, we need it to prepare pinout picture.
Old 07-11-2017, 07:48   #7 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 362
Model Settings:
Interface : eMMC
Voltage : 3.3V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
---------------------------------------------------------------Searching Android build info...Ok
Disk/Image size : a3e00000 bytes
Device sector size : 512 bytes
Partition offset : 2842624
Number of sectors : 5242880
Device Manufacturer : HUAWEI
Device Platform : msm8916
Build ID : HUAWEIRIO-L02
Display Build ID : HL1RIOL02M105
Release ID : 5.1
Device Model : HUAWEI RIO-L02
Device Name : RIO-L02
Architecture ABI : arm64-v8a
Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
Build Description : RIO-L02-user 5.0 GRJ90 C00B105 release-keys
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_11_07_2017_01_46_09.bin.
Connect successful.
SW: 1.4.0; FW: 1.20.
P00: GPT (00000000, 00000022)
P01: sbl1 (00000022, 00000400)
P02: hyp (00000422, 00000400)
P03: sec (00002000, 00000040)
P04: DDR (00002040, 00000040)
P05: rpm (00004000, 00000400)
P06: tz (00004400, 00000400)
P07: aboot (00004800, 00002780)
P08: pad (00006F80, 00000800)
P09: oeminfo (00007780, 00020000)
P10: misc (00027780, 00002000)
P11: modemst1 (00029780, 00002000)
P12: modemst2 (0002B780, 00002000)
P13: fsg (0002E000, 00002000)
P14: modem (00030000, 00064000)
P15: fsc (00094000, 00000002)
P16: ssd (00094002, 00000010)
P17: log (00094012, 00020000)
P18: persist (000B6000, 00020000)
P19: boot (000D6000, 00020000)
P20: recovery (000F6000, 00020000)
P21: erecovery (00116000, 00020000)
P22: cache (00136000, 00080000)
P23: cust (001B6000, 00100000)
P24: system (002B6000, 00500000)
P25: config (007B6000, 00000400)
P26: userdata (007B8000, 01566FDF)
Selected rawprogram XML file: C:/Users/Los Martinez Lozada/Downloads/RIO-L02_M105_Board Software_general_Android 5.1_EMUI 3.1_05021TKA/Software/EXE/factory/factory_verison/HL1RIOL02M105/MSMQCOMV100R001C00B001_Download.xml.
Patch xml file open failed.
Patch Xml file open failed.
Xml file parsing finished.
Selected rawprogram XML file: C:/Users/Los Martinez Lozada/Downloads/RIO-L02_M105_Board Software_general_Android 5.1_EMUI 3.1_05021TKA/Software/EXE/factory/factory_verison/HL1RIOL02M105/fastbootimage/MSMQCOMV100R001C00B001_Download.xml.
maybe filex xml not compatible for write by this method
Old 07-11-2017, 07:52   #8 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,815
Yes, You should use firmwares with "rawprogram.xml". Please post here link to your firmware with "*.xml" file, we will research it.
Old 07-21-2017, 03:13   #9 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 362
hi team, can repair my rio-l03 my emmc is Samsung eMMC R311MB by you new update? see in support but not is same emmc this can repiar my phone
Old 07-21-2017, 06:00   #10 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,815
Hi.
May be not compatible with your device, but You can try and post here the result.
Old 07-23-2017, 23:15   #11 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 362
all write ok but phone not poweron always qualcom mode
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Huawei
Model : G8_RIO-L03
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_G8_RIO-L03_EMMC.srf
Voltage : 3.3V
Bus Mode : 1
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R311MB_20_07_2017_21_26_32.bin.
Connect successful.
Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_G8_RIO-L03_EMMC.srf".
Write data verification is enabled.
Writing GPT partition... Done.
Writing sbl1 partition... Done.
Writing hyp partition... Done.
Writing sec partition... Done.
Writing DDR partition... Done.
Writing rpm partition... Done.
Writing tz partition... Done.
Writing aboot partition... Done.
Writing pad partition... Done.
Writing oeminfo partition... Done.
Writing misc partition... Done.
Writing modemst1 partition... Done.
Writing modemst2 partition... Done.
Writing fsg partition... Done.
Writing modem partition... Done.
Writing fsc partition... Done.
Writing ssd partition... Done.
Writing log partition... Done.
Writing persist partition... Done.
Writing boot partition... Done.
Writing recovery partition... Done.
Writing erecovery partition... Done.
Writing config partition... Done.
Old 07-24-2017, 06:10   #12 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,815
Most likely boot loaders in SRF are not compatible with your phone revision (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to find firmware with "rawprogram.xml" and make "Factory Repair" using it.
Page generated in 0.39473 seconds with 7 queries
