03-23-2019, 21:00 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Dhaka,Bangladesh Age: 40
Member: 1505853 Status: Offline Thanks Meter: 19 | Huawei T1-701u emergency calls only..... |
03-23-2019, 21:46 | #2 (permalink) |
Freak Poster Join Date: Jul 2018 Location: Your sisterīs room
Member: 2854680 Status: Offline Thanks Meter: 63 | We need logs to look what is going in you phone, please leave repair operation log here, also, please show screenshot of phone info as Bluetooth adress, Mac adress, and IMEI (you can hide) |
03-24-2019, 05:10 | #4 (permalink) |
Member: 1505853 Status: Offline Thanks Meter: 19 | here is repair log.................Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Huawei Model : T1-701U SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_T1-701U_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FNX2MB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100464E58324D4206DC41F2A1B35F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FNX2MB Product revision : 0.6 Product serial number : (hex) DC41F2A1 Manufacturing date : 11/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 1452032 Number of sectors : 3145728 Device Manufacturer :Huawei Device Platform :sc8830 Build ID :HuaweiMediaPad Display Build ID :T1-701uV100R001C209B103 Release ID :4.4.2 Device Model :T1 7.0 Device Name :MediaPad Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :MediaPad-user 4.4.2 HuaweiMediaPad C209B103 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/FNX2MB_24_03_2019_00_35_14.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. P00: GPT (00000000, 00000800) 1024 KB P01: ptable (00000800, 00000800) 1024 KB P02: prodnv (00001000, 00002800) 5 MB P03: miscdata (00003800, 00000800) 1024 KB P04: wmodem (00004000, 00005000) 10 MB P05: wdsp (00009000, 00001800) 3072 KB P06: wfixnv1 (0000A800, 00000800) 1024 KB P07: wfixnv2 (0000B000, 00000800) 1024 KB P08: wruntimenv1 (0000B800, 00000800) 1024 KB P09: wruntimenv2 (0000C000, 00000800) 1024 KB P10: wcnmodem (0000C800, 00000800) 1024 KB P11: wcnfixnv1 (0000D000, 00000800) 1024 KB P12: wcnfixnv2 (0000D800, 00000800) 1024 KB P13: wcnruntimenv1 (0000E000, 00000800) 1024 KB P14: wcnruntimenv2 (0000E800, 00000800) 1024 KB P15: misc (0000F000, 00001000) 2048 KB P16: splnormal (00010000, 00002000) 4 MB P17: ubootnormal (00012000, 00002000) 4 MB P18: nvm (00014000, 00001000) 2048 KB P19: oeminfo (00015000, 00020000) 64 MB P20: logo (00035000, 00001800) 3072 KB P21: fbootlogo (00036800, 00001800) 3072 KB P22: sysinfo (00038000, 00002800) 5 MB P23: log (0003A800, 00020000) 64 MB P24: cust (0005A800, 00100000) 512 MB P25: boot (0015A800, 00008000) 16 MB P26: system (00162800, 00300000) 1536 MB P27: cache (00462800, 00080000) 256 MB P28: recovery (004E2800, 00008000) 16 MB P29: userdata (004EA800, 009A17DF) 4.815 GB Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/HUAWEI_T1-701U_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing ptable partition... Done. Writing prodnv partition... Done. Writing miscdata partition... Done. Writing wmodem partition... Done. Writing wdsp partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing wcnmodem partition... Done. Writing wcnfixnv1 partition... Done. Writing wcnfixnv2 partition... Done. Writing wcnruntimenv1 partition... Done. Writing wcnruntimenv2 partition... Done. Writing misc partition... Done. Writing splnormal partition... Done. Writing ubootnormal partition... Done. Writing nvm partition... Done. Writing oeminfo partition... Done. Writing logo partition... Done. Writing fbootlogo partition... Done. Writing sysinfo partition... Done. Writing log partition... Done. Writing cust partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Smart Repair is successfully complete. SW: 1.7.6; FW: 1.24. Disconnected. |
03-24-2019, 23:03 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | I think you must repair imei then check for network to be displayed |
The Following User Says Thank You to gulshan-iqbal For This Useful Post: |
