04-17-2018, 20:07 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: San Fernando La Union Age: 34
Member: 2068959 Status: Offline Thanks Meter: 252 | Huawei Y300-0100 eMMC read only reset successfully DONE the saying emmc read only So I Deside removed Write Protect Using Medusa Pro AFTER Conncet Saccessfully Go To EMMC Tab Tick Remove Write Protect After That Remove Wire And Test DONE No Need Flashing Methode DONE Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC SJS00A Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 150100534A5330304103360837701165 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : SJS00A Product revision : 0.3 Product serial number : (hex) 36083770 Manufacturing date : 01/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFE78A406033 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 1024 Kbytes Boot2 size : 1024 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/SJS00A_17_04_2018_03_05_29.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. P00: FSBL (00000001, 00000028) 20 KB P01: QCSBL (00000029, 00000258) 300 KB P02: FAT32 (00000281, 00041000) 130 MB P03: PART_6A (00042000, 00006000) 12 MB P04: OSBL (00048000, 00002000) 4 MB P05: PART_63 (0004A000, 00002000) 4 MB P06: PART_58 (0004C000, 00001800) 3072 KB P07: MODEM_ST1 (0004E000, 00001800) 3072 KB P08: MODEM_ST2 (00050000, 00001800) 3072 KB P09: APPSBL (00052000, 00002000) 4 MB P10: BOOT (00054000, 00004000) 8 MB P11: PART_60 (00058000, 0000A000) 20 MB P12: PART_6C (00062000, 00002000) 4 MB P13: EXT2FS (00064000, 00060000) 192 MB P14: EXT2FS (000C4000, 00028000) 80 MB P15: EXT2FS (000EC000, 00200000) 1024 MB P16: EXT2FS (002EC000, 00240000) 1152 MB P17: PART_6B (0052C000, 0021C000) 1080 MB Last edited by Medusa Box; 04-18-2018 at 05:00. |
The Following 4 Users Say Thank You to omairlee01 For This Useful Post: |
