Huaweii E173Eu-1 problem ?? Hello I have a lot of that modems with simlock 1. I have backup full flash from (locked) modem no1 - lets name "locked 173eu1.bin" 2. then i unlock modem no1 with other tools 3. i have backup full flash from unlocked modem no1 - lets name "unlocked 173eu1.bin" Now i have 2 backup: ""locked 173eu1.bin"" , "unlocked 173eu1.bin" from the same modem. I'd like to ask why when i write locked backup from modem no1 to another modem its no problem - modem alive, but when i write unlocked backup from the same modem no1 to another - modem is dead? |
Hello. Have You read out Full flash from your unlocked modem with ECC (with selected "ECC Mode")? Note, You need to read Full flash with ECC. |
Log started at 2012-05-25 15:49:23 ... Welcome to Medusa Box Software version 1.4.7 Selected device model: Huawei E173Eu-1 Connecting. Please wait... ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 301C00E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.59 V CPU : Qualcomm MSM6290 Core ID : 301C00E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000035. MI: Detailed server caps: FLASH, ECC, WDOG, DWP MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0xA0AD00A1. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000035 Flash device: Hynix H8ACSOPL0MCR Flash ID : 00AD00A1 Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 1024 Flash size : 128 Mb Write protection disabled. Connect successful. ECC Mode enabled. Opening "C:\Program Files\GsmServer\Medusa\MOJE\E173eu-1 unlocked\boot\Huawei E173Eu-1 Boot 25-05-2012 15_55_00.bin" file... Reading BOOT section. Please wait... Done Opening "C:\Program Files\GsmServer\Medusa\MOJE\E173eu-1 unlocked\full\Huawei E173Eu-1 FullFlash 25-05-2012 15_56_08.bin" file... Reading BOOT section. Please wait... Done I see that was ecc enabled..... Reading FIRMWARE section. Please wait... Done Disconnected |
Ok, now please post here full software log of writing Full flash from unlocked device ("Huawei E173Eu-1 FullFlash 25-05-2012 15_56_08.bin") into another locked one. |
Selected device model: Huawei E173Eu-1 Connecting. Please wait... MI: RTCK reaction time 126 ns, average speed 7936 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 301C00E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.62 V CPU : Qualcomm MSM6290 Core ID : 301C00E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000035. MI: Detailed server caps: FLASH, ECC, WDOG, DWP MI: Watchdog are preconfigured. MI: Server init. MI: Received flash ID 0xA0AD00A1. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000035 Flash device: Hynix H8ACSOPL0MCR Flash ID : 00AD00A1 Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 1024 Flash size : 128 Mb Write protection disabled. Connect successful. ECC Mode enabled. Opening "C:\Program Files\GsmServer\Medusa\MOJE\E173eu-1 unlocked\full\Huawei E173Eu-1 FullFlash 25-05-2012 15_56_08.bin" file... Writting BOOT section. Please wait... Done Writting FIRMWARE section. Please wait... Done |
And what is the state of this modem now? |
When I put it to usb port - nothing is happen - it's totally dead :( |
I tried ones more read-write procedure BUT THE SAME EFFECT here is log: Medusa JTAG Hardware S64 revision B. Detected TAP ID: 301C00E1, IR Length = 4. JTAG speed : 1000 KHz. VREF level : 2.64 V CPU : Qualcomm MSM6290 Core ID : 301C00E1 Flash device: Hynix H8ACSOPL0MCR Flash ID : 00AD00A1 Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 1024 Flash size : 128 Mb Write protection disabled. Connect successful. ECC Mode enabled. Disconnected Selected device model: Huawei E173Eu-1 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 301C00E1, IR Length = 4. JTAG speed : 1000 KHz. VREF level : 2.64 V CPU : Qualcomm MSM6290 Core ID : 301C00E1 Flash device: Hynix H8ACSOPL0MCR Flash ID : 00AD00A1 Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 1024 Flash size : 128 Mb Write protection disabled. Connect successful. ECC Mode enabled. Opening "C:\Program Files\GsmServer\Medusa\Full Flash\E173eu1 - with ecc WO SIMLOCK\Huawei E173Eu-1 FullFlash 31-05-2012 11_36_27.bin" file... Reading BOOT section. Please wait... Done Reading FIRMWARE section. Please wait... Done Disconnected Selected device model: Huawei E173Eu-1 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 301C00E1, IR Length = 4. JTAG speed : 1000 KHz. VREF level : 2.63 V CPU : Qualcomm MSM6290 Core ID : 301C00E1 Flash device: Hynix H8ACSOPL0MCR Flash ID : 00AD00A1 Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 1024 Flash size : 128 Mb Write protection disabled. Connect successful. ECC Mode enabled. Opening "C:\Program Files\GsmServer\Medusa\Full Flash\E173eu1 - with ecc WO SIMLOCK\Huawei E173Eu-1 FullFlash 31-05-2012 11_36_27.bin" file... Writting BOOT section. Please wait... Done Writting FIRMWARE section. Please wait... Done Disconnected |
After write full backup (simlocked) - modem fully working but still there is a simlock ....... Selected device model: Huawei E173Eu-1 Connecting. Please wait... Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S64 revision B. Detected TAP ID: 301C00E1, IR Length = 4. JTAG speed : Auto (RTCK). VREF level : 2.63 V CPU : Qualcomm MSM6290 Core ID : 301C00E1 Flash device: Hynix H8ACSOPL0MCR Flash ID : 00AD00A1 Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 1024 Flash size : 128 Mb Write protection disabled. Connect successful. ECC Mode enabled. Opening "C:\Program Files\GsmServer\Medusa\Full Flash\E173eu-1\Huawei E173 FullFlash 03-02-2012 11_11_29z simlockiem.bin" file... Writting BOOT section. Please wait... Done Writting FIRMWARE section. Please wait... Done Disconnected |
Yes, sorry, I thought you have Huawei E173 modem (not E173u-1). Such situation (phone is in not working state) arise because the security of E173u-1 has binding to HW (simple E173 model has the sucurity that not binding to HW). The best way to unlock your E173u-1 is to write back origilal (locked) Full flash from this modem, to make it working again, then re-flash it using Octopus Suite software 1.0.6 with the firmware "E173-11.126.16.04.174_unlocked" from the support area and unlock it for 0 credits. Please look here for more details: http://forum.gsmhosting.com/vbb/f699...hread-1483661/. |
ok - what is the user and pass? Welcome to Octopus Suite version 1.0.6 -------------------------------------------------------------------------------- Platform: Huawei Qualcomm Selected model: E173 Selected diagnostic port: COM68 Selected modem port: COM55 Found diagnostic port: COM68 Found modem port: COM55 Reading info...OK Mode: Normal Model ID: KPRBL Firmware compiled date: Sep 21 2011 Firmware compiled time: 09:29:48 Firmware released date: Sep 21 2011 Firmware released time: 09:29:48 SW Version: 11.126.16.04.174 IMEI: 867767-00-549679-5 Detected manufacturer: huawei Detected model name: E173 Firmware version: 11.126.16.04.174 IMEI: 867767-00-549679-5 -------------------------------------------------------------------------------- Platform: Huawei Qualcomm Selected model: E173 Selected diagnostic port: COM68 Selected modem port: COM55 Found diagnostic port: COM68 Found modem port: COM55 Reading info...OK Mode: Normal Model ID: KPRBL Firmware compiled date: Sep 21 2011 Firmware compiled time: 09:29:48 Firmware released date: Sep 21 2011 Firmware released time: 09:29:48 SW Version: 11.126.16.04.174 IMEI: 867767-00-549679-5 Detected manufacturer: huawei Detected model name: E173 Firmware version: 11.126.16.04.174 IMEI: 867767-00-549679-5 Connecting to server...OK Username: Authorizing...Failed! Login error: Wrong username! |
Thx a lot I tried too many times with other user/pass and now i have Connecting to server...Failed! Your IP is in black list! could you fixed it for me please ? :) |
Please check your PM for Username/Password. |
