Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 05-31-2012, 09:51   #1 (permalink)
zaskar's Avatar
Member: 60746
Huaweii E173Eu-1 problem ??
Hello
I have a lot of that modems with simlock
1. I have backup full flash from (locked) modem no1 - lets name "locked 173eu1.bin"
2. then i unlock modem no1 with other tools
3. i have backup full flash from unlocked modem no1 - lets name "unlocked 173eu1.bin"
Now i have 2 backup: ""locked 173eu1.bin"" , "unlocked 173eu1.bin" from the same modem.
I'd like to ask why when i write locked backup from modem no1 to another modem its no problem - modem alive, but when i write unlocked backup from the same modem no1 to another - modem is dead?
Old 05-31-2012, 10:09   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Hello.
Have You read out Full flash from your unlocked modem with ECC (with selected "ECC Mode")? Note, You need to read Full flash with ECC.
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 05-31-2012, 10:41   #3 (permalink)
zaskar's Avatar
Member: 60746
Log started at 2012-05-25 15:49:23 ...
Welcome to Medusa Box Software version 1.4.7
Selected device model: Huawei E173Eu-1
Connecting. Please wait...
ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz.
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision B.
Detected TAP ID: 301C00E1, IR Length = 4.
MI: Halting target, attempt 1.
JTAG speed : 1000 KHz.
VREF level : 2.59 V
CPU : Qualcomm MSM6290
Core ID : 301C00E1
MI: Loading Medusa Device Server V1.2.
MI: Starting...
MI: Received status 0x0000F00F, cycle 0.
MI: Received server capabilities 0x00000035.
MI: Detailed server caps: FLASH, ECC, WDOG, DWP
MI: Watchdog are preconfigured.
MI: Server init.
MI: Received flash ID 0xA0AD00A1.
MI: Flash geometry set.
MI: Recheking settings... ok
Server caps : 00000035
Flash device: Hynix H8ACSOPL0MCR
Flash ID : 00AD00A1
Page size : 2048 bytes
Block size : 64 pages (128 Kb)
Block count: 1024
Flash size : 128 Mb
Write protection disabled.
Connect successful.
ECC Mode enabled.
Opening "C:\Program Files\GsmServer\Medusa\MOJE\E173eu-1 unlocked\boot\Huawei E173Eu-1 Boot 25-05-2012 15_55_00.bin" file...
Reading BOOT section. Please wait... Done
Opening "C:\Program Files\GsmServer\Medusa\MOJE\E173eu-1 unlocked\full\Huawei E173Eu-1 FullFlash 25-05-2012 15_56_08.bin" file...
I see that was ecc enabled.....
Reading FIRMWARE section. Please wait... Done
Disconnected
Old 05-31-2012, 10:51   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Ok, now please post here full software log of writing Full flash from unlocked device ("Huawei E173Eu-1 FullFlash 25-05-2012 15_56_08.bin") into another locked one.
Old 05-31-2012, 10:55   #5 (permalink)
zaskar's Avatar
Member: 60746
MI: RTCK reaction time 126 ns, average speed 7936 KHz.
JTAG speed : Auto (RTCK).
VREF level : 2.62 V
Core ID : 301C00E1
MI: Starting...
MI: Server init.
Flash ID : 00AD00A1
Block count: 1024
Flash size : 128 Mb
Connect successful.
ECC Mode enabled.
Writting BOOT section. Please wait... Done
Writting FIRMWARE section. Please wait... Done
Old 05-31-2012, 12:19   #6 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
And what is the state of this modem now?
Old 05-31-2012, 12:31   #7 (permalink)
zaskar's Avatar
Member: 60746
When I put it to usb port - nothing is happen - it's totally dead
Old 05-31-2012, 12:33   #8 (permalink)
zaskar's Avatar
Member: 60746
I tried ones more read-write procedure BUT THE SAME EFFECT
here is log:
VREF level : 2.64 V
Core ID : 301C00E1
Flash ID : 00AD00A1
Block count: 1024
Flash size : 128 Mb
Connect successful.
ECC Mode enabled.
Disconnected
VREF level : 2.64 V
Core ID : 301C00E1
Flash ID : 00AD00A1
Block count: 1024
Flash size : 128 Mb
Connect successful.
ECC Mode enabled.
Opening "C:\Program Files\GsmServer\Medusa\Full Flash\E173eu1 - with ecc WO SIMLOCK\Huawei E173Eu-1 FullFlash 31-05-2012 11_36_27.bin" file...
Disconnected
VREF level : 2.63 V
Core ID : 301C00E1
Flash ID : 00AD00A1
Block count: 1024
Flash size : 128 Mb
Connect successful.
ECC Mode enabled.
Disconnected
Old 05-31-2012, 13:07   #9 (permalink)
zaskar's Avatar
Member: 60746
After write full backup (simlocked) - modem fully working but still there is a simlock .......
VREF level : 2.63 V
Core ID : 301C00E1
Flash ID : 00AD00A1
Block count: 1024
Flash size : 128 Mb
Connect successful.
ECC Mode enabled.
Opening "C:\Program Files\GsmServer\Medusa\Full Flash\E173eu-1\Huawei E173 FullFlash 03-02-2012 11_11_29z simlockiem.bin" file...
Disconnected
Old 05-31-2012, 13:45   #10 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Yes, sorry, I thought you have Huawei E173 modem (not E173u-1). Such situation (phone is in not working state) arise because the security of E173u-1 has binding to HW (simple E173 model has the sucurity that not binding to HW).
The best way to unlock your E173u-1 is to write back origilal (locked) Full flash from this modem, to make it working again, then re-flash it using Octopus Suite software 1.0.6 with the firmware "E173-11.126.16.04.174_unlocked" from the support area and unlock it for 0 credits. Please look here for more details: Octopus Suite v1.0.6 - public discussion thread.
Old 05-31-2012, 14:28   #11 (permalink)
zaskar's Avatar
Member: 60746
ok - what is the user and pass?
Welcome to Octopus Suite version 1.0.6
Platform: Huawei Qualcomm
Selected model: E173
Selected diagnostic port: COM68
Selected modem port: COM55
Found diagnostic port: COM68
Found modem port: COM55
Reading info...OK
Mode: Normal
Model ID: KPRBL
Firmware compiled date: Sep 21 2011
Firmware compiled time: 09:29:48
Firmware released date: Sep 21 2011
Firmware released time: 09:29:48
SW Version: 11.126.16.04.174
IMEI: 867767-00-549679-5
Detected manufacturer: huawei
Detected model name: E173
Firmware version: 11.126.16.04.174
Reading info...OK
Mode: Normal
Model ID: KPRBL
Connecting to server...OK
Username:
Authorizing...Failed!
Login error: Wrong username!
Old 05-31-2012, 15:02   #12 (permalink)
zaskar's Avatar
Member: 60746
Thx a lot
I tried too many times with other user/pass and now i have
Connecting to server...Failed!
Your IP is in black list!
could you fixed it for me please ?
Old 06-01-2012, 05:29   #13 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Please check your PM for Username/Password.
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-19-1999 17:41
Page generated in 0.39300 seconds with 11 queries
