Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 07-13-2012, 10:36   #1 (permalink)
Member: 643517
I9003 Unable to halt core
Medusa JTAG Firmware version 1.1.0.
Medusa JTAG Hardware S64 revision B.
Detected TAP ID: 2B89102F, IR Length = 6.
MI: Found ICEPick TAP Router 2B89102F.
MI: Enabling ARM Cortex core.
ERROR[000]: Unable to halt core.
Old 07-13-2012, 10:43   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Hello.
Please make Repair of this phone in EasyRepair Mode. To make Repair of this phone model You need to create Repair SD card. Have You careateed and use it?
Old 07-13-2012, 11:02   #3 (permalink)
Member: 643517
JTAG speed : 1000 KHz.
VREF level : 1.80 V
CPU : Texas Instruments OMAP3630
Core ID : 0B6D602F
Flash device: Samsung OneNAND KFG4GH6Q4M
Flash ID : 00EC0050
Page size : 4096 bytes
Block size : 64 pages (256 Kb)
Block count: 2048
Flash size : 512 Mb
Write protection disabled.
Opening "C:\Program Files\GsmServer\Medusa\Firmware\SAMSUNG_GTI9003_Re pair.mf" file...
Repair restarted at last fail position.
Writting BOOT section. Please wait...
ERROR[018]: Logical block operation failed at 64 Kb (Hex address 0x00010000). Reason: Connection lost.
Old 07-13-2012, 12:30   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Your device has been disconnected. Please fully charge phone's battery and try again. Try a few times. Also please check soldering of all Jtag wires, make them as more shorter.
Old 07-14-2012, 05:21   #5 (permalink)
Member: 643517
MI: Halting target, attempt 1.
VREF level : 1.80 V
Core ID : 0B6D602F
MI: Loading Medusa Device Server V1.2.
MI: Starting...
MI: Received status 0x0000F00F, cycle 0.
MI: Received server capabilities 0x00000135.
MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL
MI: Watchdog are preconfigured.
MI: Server init.
MI: Received flash ID 0xB0EC0050.
MI: Flash geometry set.
MI: Recheking settings... ok
Server caps : 00000135
Flash ID : 00EC0050
Block count: 2048
Flash size : 512 Mb
Writting BOOT section. Please wait... Done
Writting UPCH section. Please wait... Done
Disconnected
Repair done.
tnx for the help,,but after i flash it in octopus samsung
hang on SAMSUNG GALAXY S super clear LCD,,i used this version,,,I9003DDKB2_DDKA5_ODDKA6.oct,,,
is there any correct version for this galaxy s scl? tnx again
Old 07-14-2012, 08:53   #6 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Hello.
Please try to re-flash with this "i9003XXKA8_XXKA8_SERKA8" firmware with phone's boot.
Old 07-19-2012, 10:13   #7 (permalink)
Member: 643517
hello,
i used this version and this is the log,,
Log file "C:\Program Files\GsmServer\OctopusSamsung\LOG\19-07-2012_16-54-52.log" created (7/19/2012 4:54:56 PM).
INFO : 7/19/2012 4:54:59 PM > Set up system language English (file: English.ini)
INFO : 7/19/2012 4:54:59 PM > Welcome to Octopus Box Samsung software version 1.5.0
INFO : 7/19/2012 4:54:59 PM > -----------------------------------------------------------------------------------
INFO : 7/19/2012 4:54:59 PM > To connect GT-I9003 phone you have to perform the following steps:
INFO : 7/19/2012 4:54:59 PM > 1. Disconnect USB cable from phone.
INFO : 7/19/2012 4:54:59 PM > 2. Go to Menu->Settings->Applications->Development.
INFO : 7/19/2012 4:54:59 PM > 3. Turn on "USB Debugging" option.
INFO : 7/19/2012 4:54:59 PM > 4. When message is appear press "Yes".
INFO : 7/19/2012 4:54:59 PM > 5. Go to dial window.
INFO : 7/19/2012 4:54:59 PM > 6. Enter "*#7284#" number.
INFO : 7/19/2012 4:54:59 PM > 7. Set "USB" radio button to "PDA" value.
INFO : 7/19/2012 4:54:59 PM > 8. Close window.
INFO : 7/19/2012 4:54:59 PM > 9. Press "Read Info" in Octopus Samsung software.
INFO : 7/19/2012 4:56:36 PM > Selected firmware file: i9003XXKA8_XXKA8_SERKA8_2.oct
WARN : 7/19/2012 4:57:23 PM > Please put your phone in download mode and connect to PC.
WARN : 7/19/2012 4:57:23 PM > To put GT-I9003 phone into download mode you have to perform the following steps:
WARN : 7/19/2012 4:57:23 PM > 1. Reconnect phone battery.
WARN : 7/19/2012 4:57:23 PM > 2. Press and hold "Volume - " + "Power" buttons.
INFO : 7/19/2012 4:57:23 PM > Found phone on
INFO : 7/19/2012 4:57:23 PM > Firmware write started.
INFO : 7/19/2012 4:57:23 PM > Writing PIT section...
INFO : 7/19/2012 4:57:28 PM > PIT section has been written successfully.
INFO : 7/19/2012 4:57:28 PM > Writing NORMALBOOT section...
INFO : 7/19/2012 4:57:31 PM > NORMALBOOT section has been written successfully.
INFO : 7/19/2012 4:57:31 PM > Writing RECOVERY section...
INFO : 7/19/2012 4:57:34 PM > RECOVERY section has been written successfully.
INFO : 7/19/2012 4:57:34 PM > Writing IBL+PBL section...
INFO : 7/19/2012 4:57:37 PM > IBL+PBL section has been written successfully.
INFO : 7/19/2012 4:57:37 PM > Writing SBL section...
INFO : 7/19/2012 4:57:39 PM > SBL section has been written successfully.
INFO : 7/19/2012 4:57:39 PM > Writing PARAM section...
INFO : 7/19/2012 4:57:41 PM > PARAM section has been written successfully.
INFO : 7/19/2012 4:57:41 PM > Writing SYSTEM section...
INFO : 7/19/2012 4:59:40 PM > SYSTEM section has been written successfully.
INFO : 7/19/2012 4:59:40 PM > Writing CACHE section...
INFO : 7/19/2012 4:59:42 PM > CACHE section has been written successfully.
INFO : 7/19/2012 4:59:42 PM > Writing USERDATA section...
INFO : 7/19/2012 4:59:44 PM > USERDATA section has been written successfully.
INFO : 7/19/2012 4:59:44 PM > Writing MODEM section...
INFO : 7/19/2012 4:59:50 PM > MODEM section has been written successfully.
INFO : 7/19/2012 4:59:50 PM > Writing CACHE section...
INFO : 7/19/2012 4:59:54 PM > CACHE section has been written successfully.
INFO : 7/19/2012 4:59:54 PM > Writing HIDDEN section...
INFO : 7/19/2012 5:00:48 PM > HIDDEN section has been written successfully.
ERROR : 7/19/2012 5:00:58 PM > Writing Firmware Failed
WARN : 7/19/2012 5:09:18 PM > Please put your phone in download mode and connect to PC.
WARN : 7/19/2012 5:09:18 PM > To put GT-I9003 phone into download mode you have to perform the following steps:
WARN : 7/19/2012 5:09:18 PM > 1. Reconnect phone battery.
WARN : 7/19/2012 5:09:18 PM > 2. Press and hold "Volume - " + "Power" buttons.
INFO : 7/19/2012 5:09:18 PM > Found phone on
INFO : 7/19/2012 5:09:18 PM > Firmware write started.
INFO : 7/19/2012 5:09:18 PM > Writing PIT section...
INFO : 7/19/2012 5:09:23 PM > PIT section has been written successfully.
INFO : 7/19/2012 5:09:23 PM > Writing NORMALBOOT section...
INFO : 7/19/2012 5:09:27 PM > NORMALBOOT section has been written successfully.
INFO : 7/19/2012 5:09:27 PM > Writing RECOVERY section...
INFO : 7/19/2012 5:09:30 PM > RECOVERY section has been written successfully.
INFO : 7/19/2012 5:09:30 PM > Writing IBL+PBL section...
INFO : 7/19/2012 5:09:32 PM > IBL+PBL section has been written successfully.
INFO : 7/19/2012 5:09:32 PM > Writing SBL section...
INFO : 7/19/2012 5:09:34 PM > SBL section has been written successfully.
INFO : 7/19/2012 5:09:34 PM > Writing PARAM section...
INFO : 7/19/2012 5:09:36 PM > PARAM section has been written successfully.
INFO : 7/19/2012 5:09:37 PM > Writing SYSTEM section...
INFO : 7/19/2012 5:11:38 PM > SYSTEM section has been written successfully.
INFO : 7/19/2012 5:11:38 PM > Writing CACHE section...
INFO : 7/19/2012 5:11:40 PM > CACHE section has been written successfully.
INFO : 7/19/2012 5:11:40 PM > Writing USERDATA section...
INFO : 7/19/2012 5:11:43 PM > USERDATA section has been written successfully.
INFO : 7/19/2012 5:11:43 PM > Writing MODEM section...
INFO : 7/19/2012 5:11:48 PM > MODEM section has been written successfully.
INFO : 7/19/2012 5:11:48 PM > Writing CACHE section...
INFO : 7/19/2012 5:11:53 PM > CACHE section has been written successfully.
INFO : 7/19/2012 5:11:53 PM > Writing HIDDEN section...
INFO : 7/19/2012 5:12:46 PM > HIDDEN section has been written successfully.
ERROR : 7/19/2012 5:12:57 PM > Writing Firmware Failed
failed.
Old 07-20-2012, 08:27   #8 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Try again, try to write another firmware. Try to write firmware using original Samsung flasher. If the problem will be the same - this can be the problem with phones' flash chip.
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 0.34280 seconds with 11 queries
