09-10-2019, 12:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 408 | j100h dead boot [Solved] Started. Reader #0: Generic Usb Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H (One sim) SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H (ONE SIM)_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211016EE05687320D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 6EE05687 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_10_09_2019_11_59_34.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. Selected pit file: G:/J100H/boot/J13G.pit Erasing. Please wait... Done. SW: 1.7.7; FW: 1.24. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H (One sim) SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H (ONE SIM)_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211016EE05687320D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 6EE05687 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_10_09_2019_12_03_17.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H (ONE SIM)_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing SBOOT partition... Done. Writing SBOOT2 partition... Done. Writing wfixnv1 partition... Done. Writing wfixnv2 partition... Done. Writing tdfixnv1 partition... Done. Writing tdfixnv2 partition... Done. Writing WDSP partition... Done. Writing MODEM partition... Done. Writing MODEM2 partition... Done. Writing TDDSP partition... Done. Writing FOTA_SIG partition... Done. Writing wruntimenv1 partition... Done. Writing wruntimenv2 partition... Done. Writing tdruntimenv1 partition... Done. Writing tdruntimenv2 partition... Done. Writing PARAM partition... Done. Writing efs partition... Done. Writing prodnv partition... Done. Writing RESERVED2 partition... Done. Writing KERNEL partition... Done. Writing RECOVERY partition... Done. Smart Repair is successfully complete. SW: 1.7.7; FW: 1.24. Disconnected. the phone is dead Please full dump j100h working With medusa |
09-14-2019, 11:11 | #2 (permalink) |
Member: 136220 Status: Offline Thanks Meter: 408 | Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB want a complete file DUMP J100H because I have completely erased the EMMC Works with medusa |
09-20-2019, 09:28 | #3 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. According to your Software log your values are: Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
09-21-2019, 13:07 | #4 (permalink) |
Member: 136220 Status: Offline Thanks Meter: 408 | The operation was successful with the help of this post rebainoor's Avatar Join Date: Feb 2006 Posts: 2,192 Member: 231728 Status: Offline Thanks Meter: 1,237 after successefull connected in emmc mode go to EMMC service tab and clic in HW Partitions and do not change any think and clic in write after that you will get this : Code: No General Purpose Partition 1 enhanced attribute is not set write reliablity is set No General Purpose Partition 2 enhanced attribute is not set write reliablity is set No General Purpose Partition 3 enhanced attribute is not set write reliablity is set No General Purpose Partition 4 enhanced attribute is not set write reliablity is set No enhanced user data area write reliablity is not set Creating HW partitions succesfully complete! Welcome to Octoplus Pro JTAG Software version 1.7.7. Started. Reader #0: Generic Usb Smart Card Reader 0 Please disconnect battery and USB cable. Welcome to Octoplus Pro JTAG Software version 1.7.7. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J100H (One sim) SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H (ONE SIM)_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G2b Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A483447326211016EE05687320D Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G2b Product revision : 0.1 Product serial number : (hex) 6EE05687 Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D07F01320F5903FFFFFFFFEF8A4040DB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : e9000000 bytes Device sector size : 512 bytes Partition offset : 616448 Number of sectors : 2129920 Device Manufacturer :samsung Device Platform :sc8830 Build ID :KTU84P Display Build ID :KTU84P.J100HXXS0AQD2 Release ID :4.4.4 Device Model :SM-J100H Device Name :j13gxx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Build Description :j13gxx-user 4.4.4 KTU84P J100HXXS0AQD2 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_20_09_2019_09_46_48.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00400000) 4 MB P01: SBOOT (00400000, 00200000) 2048 KB P02: SBOOT2 (00600000, 00200000) 2048 KB P03: wfixnv1 (00800000, 00100000) 1024 KB P04: wfixnv2 (00900000, 00100000) 1024 KB P05: tdfixnv1 (00A00000, 00100000) 1024 KB P06: tdfixnv2 (00B00000, 00100000) 1024 KB P07: WDSP (00C00000, 00400000) 4 MB P08: MODEM (01000000, 00800000) 8 MB P09: MODEM2 (01800000, 00800000) 8 MB P10: TDDSP (02000000, 00400000) 4 MB P11: FOTA_SIG (02400000, 00100000) 1024 KB P12: wruntimenv1 (02500000, 00100000) 1024 KB P13: wruntimenv2 (02600000, 00100000) 1024 KB P14: tdruntimenv1 (02700000, 00100000) 1024 KB P15: tdruntimenv2 (02800000, 00100000) 1024 KB P16: PARAM (02900000, 00200000) 2048 KB P17: efs (02B00000, 01400000) 20 MB P18: prodnv (03F00000, 00500000) 5 MB P19: RESERVED2 (04400000, 00100000) 1024 KB P20: KERNEL (04500000, 01000000) 16 MB P21: RECOVERY (05500000, 01000000) 16 MB P22: CSC (06500000, 0C800000) 200 MB P23: system (12D00000, 41000000) 1040 MB P24: HIDDEN (53D00000, 02800000) 40 MB P25: userdata (56500000, 91C00000) 2332 MB |
