Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 09-10-2019, 12:18   #1 (permalink)
allttar's Avatar
Member: 136220
Thanks Meter: 89
Smile j100h dead boot [Solved]
Welcome to Octoplus Pro JTAG Software version 1.7.7.
Started.
Reader #0: Generic Usb Smart Card Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J100H (One sim)
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H (ONE SIM)_EMMC.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Hynix eMMC H4G2b
Page size : 512 B
Block size : 512 B
Block count : 7634944
CID Info
CID : 90014A483447326211016EE05687320D
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H4G2b
Product revision : 0.1
Product serial number : (hex) 6EE05687
Manufacturing date : 03/2015
CSD Info
CSD : D07F01320F5903FFFFFFFFEF8A4040DB
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 80 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.6 (for MMC v4.5, v4.51)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 1908736 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_10_09_2019_11_59_34.bin.
Connect successful.
SW: 1.7.7; FW: 1.24.
Selected pit file: G:/J100H/boot/J13G.pit
Erasing. Please wait... Done.
Disconnected.
Model Settings:
Interface : eMMC
Brand : Samsung
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_10_09_2019_12_03_17.bin.
Connect successful.
Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J100H (ONE SIM)_EMMC.srf".
Write data verification is enabled.
Switched to boot area partition 1.
Writing BOOT1 partition... Done.
Switched to user area.
Writing GPT partition... Done.
Writing SBOOT partition... Done.
Writing SBOOT2 partition... Done.
Writing wfixnv1 partition... Done.
Writing wfixnv2 partition... Done.
Writing tdfixnv1 partition... Done.
Writing tdfixnv2 partition... Done.
Writing WDSP partition... Done.
Writing MODEM partition... Done.
Writing MODEM2 partition... Done.
Writing TDDSP partition... Done.
Writing FOTA_SIG partition... Done.
Writing wruntimenv1 partition... Done.
Writing wruntimenv2 partition... Done.
Writing tdruntimenv1 partition... Done.
Writing tdruntimenv2 partition... Done.
Writing PARAM partition... Done.
Writing efs partition... Done.
Writing prodnv partition... Done.
Writing RESERVED2 partition... Done.
Writing KERNEL partition... Done.
Writing RECOVERY partition... Done.
Smart Repair is successfully complete.
Disconnected.
the phone is dead Please full dump j100h working With medusa
Old 09-14-2019, 11:11   #2 (permalink)
allttar's Avatar
Member: 136220
Thanks Meter: 89
Page size : 512 B
Block size : 512 B
want a complete file DUMP J100H because I have completely erased the EMMC
Works with medusa
Old 09-20-2019, 09:28   #3 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,832
Hello.
According to your Software log your values are:
(Bus width = 1Bit)
Please, set Boot partition enable: Boot partiotion1, after repeat Smart Repair operation again, after check if DM works, post here full Software log
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 09-21-2019, 13:07   #4 (permalink)
allttar's Avatar
Member: 136220
Thanks Meter: 89
The operation was successful with the help of this post
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,237
after successefull connected in emmc mode go to EMMC service tab and clic in HW Partitions and do not change any think and clic in write
after that you will get this :
No General Purpose Partition 1
enhanced attribute is not set
write reliablity is set
No General Purpose Partition 2
No General Purpose Partition 3
No General Purpose Partition 4
No enhanced user data area
write reliablity is not set
Creating HW partitions succesfully complete!
Started.
Started.
Reader #0: Generic EMV Smartcard Reader 0
Model Settings:
Interface : eMMC
Brand : Samsung
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
Partition config : (0x08) 00001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Part setting completed: 0x1
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : e9000000 bytes
Device sector size : 512 bytes
Partition offset : 616448
Number of sectors : 2129920
Device Manufacturer :samsung
Device Platform :sc8830
Build ID :KTU84P
Display Build ID :KTU84P.J100HXXS0AQD2
Release ID :4.4.4
Device Model :SM-J100H
Device Name :j13gxx
Architecture ABI :armeabi-v7a
Architecture ABI2 :armeabi
Build Description :j13gxx-user 4.4.4 KTU84P J100HXXS0AQD2 release-keys
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G2b_20_09_2019_09_46_48.bin.
Connect successful.
P00: GPT (00000000, 00400000) 4 MB
P01: SBOOT (00400000, 00200000) 2048 KB
P02: SBOOT2 (00600000, 00200000) 2048 KB
P03: wfixnv1 (00800000, 00100000) 1024 KB
P04: wfixnv2 (00900000, 00100000) 1024 KB
P05: tdfixnv1 (00A00000, 00100000) 1024 KB
P06: tdfixnv2 (00B00000, 00100000) 1024 KB
P07: WDSP (00C00000, 00400000) 4 MB
P08: MODEM (01000000, 00800000) 8 MB
P09: MODEM2 (01800000, 00800000) 8 MB
P10: TDDSP (02000000, 00400000) 4 MB
P11: FOTA_SIG (02400000, 00100000) 1024 KB
P12: wruntimenv1 (02500000, 00100000) 1024 KB
P13: wruntimenv2 (02600000, 00100000) 1024 KB
P14: tdruntimenv1 (02700000, 00100000) 1024 KB
P15: tdruntimenv2 (02800000, 00100000) 1024 KB
P16: PARAM (02900000, 00200000) 2048 KB
P17: efs (02B00000, 01400000) 20 MB
P18: prodnv (03F00000, 00500000) 5 MB
P19: RESERVED2 (04400000, 00100000) 1024 KB
P20: KERNEL (04500000, 01000000) 16 MB
P21: RECOVERY (05500000, 01000000) 16 MB
P22: CSC (06500000, 0C800000) 200 MB
P23: system (12D00000, 41000000) 1040 MB
P24: HIDDEN (53D00000, 02800000) 40 MB
P25: userdata (56500000, 91C00000) 2332 MB
Page generated in 0.29570 seconds with 7 queries
