Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 05-25-2020, 14:01   #1 (permalink)
Pastime_GSM's Avatar
Member: 1798174
Sonork: 100.114149
Thanks Meter: 1,047
j400f binary u5 FRP removed done but still locked [Answered]
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J400F
SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J400F_BY PIJUSH DAS.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC QE63MB
Page size : 512 B
Block size : 512 B
Block count : 30777344
Size : 14.68 GB (15028.00 MB)
CID Info
CID : 150100514536334D420069799B728539
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : QE63MB
Product revision : 0.0
Product serial number : (hex) 69799B72
Manufacturing date : 08/2018
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 16384 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 4Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x01) 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7692288 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : ab400000 bytes
Device sector size : 512 bytes
Partition offset : 475136
Number of sectors : 5128192
Device Manufacturer : samsung
Build ID : PPR1.180610.011
Display Build ID : PPR1.180610.011.J400FXXS5BTC3
Release ID : 9
Device Model : SM-J400F
Device Name : j4ltejx
Architecture ABI : armeabi-v7a
Architecture ABI2 : armeabi
Architecture ABI List : armeabi-v7a,armeabi
Build Description : j4ltejx-user 9 PPR1.180610.011 J400FXXS5BTC3 release-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_25_05_2020_13_53_08.bin.
Connect successful.
SW: 2.0.9; FW: 1.24.
P00: GPT (00000000, 00002000) 4 MB
P01: BOTA0 (00002000, 00002000) 4 MB
P02: BOTA1 (00004000, 00002000) 4 MB
P03: EFS (00006000, 0000A000) 20 MB
P04: CPEFS (00010000, 00004000) 8 MB
P05: m9kefs1 (00014000, 00002000) 4 MB
P06: m9kefs2 (00016000, 00002000) 4 MB
P07: m9kefs3 (00018000, 00002000) 4 MB
P08: NAD_REFER (0001A000, 00000800) 1024 KB
P09: PARAM (0001A800, 00004000) 8 MB
P10: BOOT (0001E800, 00010000) 32 MB
P11: RECOVERY (0002E800, 00013000) 38 MB
P12: RADIO (00041800, 0002C000) 88 MB
P13: PERSISTENT (0006D800, 00000400) 512 KB
P14: STEADY (0006DC00, 00002000) 4 MB
P15: MISC (0006FC00, 00000800) 1024 KB
P16: DTBO (00070400, 00001000) 2048 KB
P17: RESERVED2 (00071400, 00002C00) 5.5 MB
P18: SYSTEM (00074000, 004E4000) 2504 MB
P19: VENDOR (00558000, 00078000) 240 MB
P20: ODM (005D0000, 00098000) 304 MB
P21: CACHE (00668000, 00030000) 96 MB
P22: OMR (00698000, 0000A000) 20 MB
P23: CP_DEBUG (006A2000, 00002800) 5 MB
P24: NAD_FW (006A4800, 0000A000) 20 MB
P25: USERDATA (006AE800, 016A8000) 11.33 GB
Backuping EFS partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_EFS_0x6000_0xa000_25_05_2020_13_53_08.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:08
Backuping FRP data...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FRP_0x82800_0x400_25_05_2020_13_53_25.bin file...
Elapsed time 00:00:00
Removing FRP. Please wait... Done.
Old 05-25-2020, 14:24   #2 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 900
Try to format persistent partition and it will solve ya
The Following User Says Thank You to starkrimes For This Useful Post:
Old 05-25-2020, 14:38   #3 (permalink)
Member: 1798174
Sonork: 100.114149
Thanks Meter: 1,047
thank you pro, please can you give me more details i'm new to dealing with isp jtag and emmc
Old 05-25-2020, 15:56   #4 (permalink)
Member: 1798174
Sonork: 100.114149
Thanks Meter: 1,047
this is exynos phone, i'm afraid format persistent partition prospect kill phone
Old 05-25-2020, 15:56   #5 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J400F
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Ok
Release ID : 9
Connect successful.
In Android 9 Or Later FRP Store In Persistent Partition ..In Some Devices Still U Found FRP Partition...If FRP There Erase FRP If Not Erase Persistent. Hope Team Will Add This In SW GUI FRP Reset Button Soon.
The Following 2 Users Say Thank You to hitech care For This Useful Post:
Old 05-25-2020, 15:58   #6 (permalink)
Member: 1798174
Sonork: 100.114149
Thanks Meter: 1,047
Old 05-25-2020, 19:11   #7 (permalink)
Member: 1798174
Sonork: 100.114149
Thanks Meter: 1,047
phone dead now after frp reset ERROR in 53%
please who have dump file j400f u5
Old 05-25-2020, 20:30   #8 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 1,100
SAMSUNG_SM-J400F_J400FXXS5BTC3_ISP.srf
The Following 2 Users Say Thank You to Pijush Das For This Useful Post:
Old 05-25-2020, 21:00   #9 (permalink)
Member: 1798174
Sonork: 100.114149
Thanks Meter: 1,047
Originally Posted by Pijush Das View Post
Thank you very much, i will try with this file tomorrow
Old 05-26-2020, 09:38   #10 (permalink)
Member: 1798174
Sonork: 100.114149
Thanks Meter: 1,047
problem solved with your file and FRP removed
Welcome to Medusa Pro Software version 2.0.9.
Started.
Reader #0: FT SCR2000 0
Reader #1: FT SCR2000 1
Reader #2: Generic EMV Smartcard Reader 0
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J400F
Cannot open output file.
Invalid file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J400F_BY PIJUSH DAS.srf.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J400F
SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J400F_EMMC.SRF
Voltage : 2.2V
Bus Mode : 1 bit
Bus speed : 20 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Ok
Release ID : 9
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_26_05_2020_08_48_43.bin.
Connect successful.
P01: bota0 (00002000, 00002000) 4 MB
P02: bota1 (00004000, 00002000) 4 MB
P03: efs (00006000, 0000A000) 20 MB
P04: cpefs (00010000, 00004000) 8 MB
P08: nad_refer (0001A000, 00000800) 1024 KB
P09: param (0001A800, 00004000) 8 MB
P10: boot (0001E800, 00010000) 32 MB
P11: recovery (0002E800, 00013000) 38 MB
P12: radio (00041800, 0002C000) 88 MB
P13: persistent (0006D800, 00000400) 512 KB
P14: steady (0006DC00, 00002000) 4 MB
P15: misc (0006FC00, 00000800) 1024 KB
P16: dtbo (00070400, 00001000) 2048 KB
P17: reserved2 (00071400, 00002C00) 5.5 MB
P18: system (00074000, 004E4000) 2504 MB
P19: vendor (00558000, 00078000) 240 MB
P20: odm (005D0000, 00098000) 304 MB
P21: cache (00668000, 00030000) 96 MB
P22: omr (00698000, 0000A000) 20 MB
P23: cp_debug (006A2000, 00002800) 5 MB
P24: nad_fw (006A4800, 0000A000) 20 MB
P25: userdata (006AE800, 016A9800) 11.33 GB
Backuping efs partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_efs_0x6000_0xa000_26_05_2020_08_48_43.bin file...
Elapsed time 00:00:11
Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J400F_J400FXXS5BTC3_ISP.srf".
Write data verification is enabled.
Switched to boot area partition 1.
Writing BOOT1 partition... Done.
Switched to boot area partition 2.
Writing BOOT2 partition... Done.
Switched to user area.
Writing GPT partition... Done.
Writing PARAM partition... Done.
Writing BOOT partition... Done.
Writing RECOVERY partition... Done.
Writing RADIO partition... Done.
Writing PERSISTENT partition... Done.
Smart Repair is successfully complete.
Disconnected.
Started.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-J400F
Voltage : 2.2V
Bus Mode : 1 bit
Bus speed : 20 MHz
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Ok
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE63MB_26_05_2020_09_10_22.bin.
Connect successful.
P20: ODM (005D0000, 00068000) 208 MB
P21: CACHE (00638000, 00030000) 96 MB
P22: OMR (00668000, 0000A000) 20 MB
P23: CP_DEBUG (00672000, 00002800) 5 MB
P24: NAD_FW (00674800, 0000A000) 20 MB
P25: HIDDEN (0067E800, 00032000) 100 MB
P26: USERDATA (006B0800, 016A6000) 11.32 GB
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/QE63MB_EFS_0x6000_0xa000_26_05_2020_09_10_22.bin file...
Selected pit file: C:/Users/huawei/Desktop/j400f/J4LTE_MEA_OPEN.pit
Open file "C:/Users/huawei/Desktop/j400f/BL_J400FXXS5BTA2_CL16827271_QB28501398_REV00_user_ low_ship.tar.md5".
Writing MBR...Done.
Writing primary GPT...Done.
Writing secondary GPT...Done.
Writing PIT
Writing. Please wait...
Writing partition BOOTLOADER... from 0 to 60C Done.
Writing partition CM... from 0 to A3 Done.
Writing partition PARAM... from 1A800 to 4D5 Done.
Writing is finished.
The Following 3 Users Say Thank You to Pastime_GSM For This Useful Post:
Old 05-26-2020, 11:45   #11 (permalink)
Pijush Das's Avatar
Member: 1902789
Thanks Meter: 1,100
Thanks for Successful Report
Page generated in 0.29442 seconds with 8 queries
