05-04-2018, 11:32 | #1 (permalink) |
Freak Poster Join Date: Oct 2017
Member: 2773088 Status: Offline Thanks Meter: 24 | K330 eMMC to LS675 question [Answered] thank you very much Last edited by Medusa Box; 05-04-2018 at 11:50. |
05-04-2018, 11:36 | #2 (permalink) | |
Member: 2773088 Status: Offline Thanks Meter: 24 | Quote:
Is it first erase the emmc then write the firmware of the phone that i want to fix or something else that i have to do? thanks | |
05-04-2018, 11:49 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. At first connect both of eMMC from K330 and LS675 and post here full Software log with the connecting info, we will check. Also, if the connection will be success, read out Full flash from both eMMC chips. Probably, your "bad" eMMC can be connected and full flash can be read out. |
05-04-2018, 13:28 | #4 (permalink) | |
Interface : eMMC Brand : LG Model : LS675 SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_LS675_EMMC.srf Voltage : 2.4V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473165050756903CEEC25F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.7 Product serial number : (hex) 56903CEE Manufacturing date : 12/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H8G1e_02_05_2018_18_29_02.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. Please select file. Remove write protect successfully completed. Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS675 SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_LS675_EMMC.srf Voltage : 2.4V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473165050756903CEEC25F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.7 Product serial number : (hex) 56903CEE Manufacturing date : 12/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H8G1e_02_05_2018_18_29_20.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. Opening C:/Users/HASHHASH/Desktop/LS675ZVA_07.tot file... Signature OK. Signature 2 OK. Open file "C:/Users/HASHHASH/Desktop/LS675ZVA_07.tot". Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Read/write verification error. Possible reasons: damaged or write protected eMMC. Disconnected. log for ls 675 | |
05-04-2018, 13:46 | #6 (permalink) |
Member: 2773088 Status: Offline Thanks Meter: 24 | Welcome to Octoplus Pro JTAG Software version 1.5.5. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4838473165050703037513C2A7 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.7 Product serial number : (hex) 3037513 Manufacturing date : 12/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 442368 Number of sectors : 4931584 Device Manufacturer :MetroPCS Device Platform :msm8909 Build ID :LMY47V Display Build ID :LMY47V Release ID :5.1.1 Device Model :LGMS330 Device Name :m1_mpcs_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :m1_mpcs_us-user 5.1.1 LMY47V 153571544a5ad release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/H8G1e_04_05_2018_15_45_42.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 00020000) 64 MB P02: sbl1 (00024000, 00000400) 512 KB P03: tz (00024400, 00000800) 1024 KB P04: rpm (00024C00, 00000400) 512 KB P05: aboot (00025000, 00001000) 2048 KB P06: sbl1bak (00026000, 00000400) 512 KB P07: tzbak (00026400, 00000800) 1024 KB P08: rpmbak (00026C00, 00000400) 512 KB P09: abootbak (00027000, 00001000) 2048 KB P10: modemst1 (00028000, 00000C00) 1536 KB P11: modemst2 (00028C00, 00000C00) 1536 KB P12: ssd (00029800, 00000400) 512 KB P13: DDR (00029C00, 00000400) 512 KB P14: fsg (0002A000, 00000C00) 1536 KB P15: fsc (0002AC00, 00000400) 512 KB P16: sec (0002B000, 00000400) 512 KB P17: keystore (0002B400, 00000400) 512 KB P18: encrypt (0002B800, 00000400) 512 KB P19: eksst (0002BC00, 00000400) 512 KB P20: devinfo (0002C000, 00000800) 1024 KB P21: config (0002C800, 00000400) 512 KB P22: spare1 (0002CC00, 00003400) 6.5 MB P23: fota (00030000, 00003000) 6 MB P24: rct (00033000, 00000400) 512 KB P25: spare2 (00033400, 00000C00) 1536 KB P26: raw_resources (00034000, 00000800) 1024 KB P27: raw_resourcesbak (00034800, 00000800) 1024 KB P28: drm (00035000, 00003000) 6 MB P29: sns (00038000, 00003000) 6 MB P30: misc (0003B000, 00005000) 10 MB P31: persist (00040000, 00004000) 8 MB P32: laf (00044000, 00008000) 16 MB P33: boot (0004C000, 00008000) 16 MB P34: recovery (00054000, 00008000) 16 MB P35: factory (0005C000, 0000C000) 24 MB P36: mpt (00068000, 00004000) 8 MB P37: system (0006C000, 004B4000) 2408 MB P38: cache (00520000, 00064000) 200 MB P39: userdata (00584000, 00908000) 4.516 GB P40: grow (00E8C000, 00003FDF) 7.984 MB |
05-04-2018, 13:57 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | As I see from your Software logs, necessary eMMC settings of your working eMMC chip is the same as on damaged eMMC, so You can try to do "Factory Repair" using your firmware ZVA, which You have. But note, if your "dead" LS675 device earlier had higher firmware version than ZVA before it became "dead", this will be not possible to repair it using ZVA firmware. If this case, You need to use higher (than ZVA) firmware version (or write full flash from the working LS775 with higher firmware version). |
05-04-2018, 14:01 | #8 (permalink) | |
05-04-2018, 15:01 | #11 (permalink) |
Member: 2773088 Status: Offline Thanks Meter: 24 | i repaired it when the emmc was not on the board i soldered it to the board now its connecting as qhusb should i repair it when its connected to the board again and erase everything before repairing or what ? thanks |
05-05-2018, 08:13 | #12 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | This doesn't matter, whether You repair eMMC directly or via ISP connection (when eMMC is on PCB). At first, check, whether You have soldered eMMC chip correctly on PCB. Also try to repair it again, try to do erase (not format) before repairing. Post here the result. |
