Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 06-24-2018, 09:54   #1 (permalink)
Member: 310155
Thanks Meter: 1,313
KMR820001M-B609 BGA -211 need recover content [Answered]
read full dump but error................................
Welcome to Medusa Pro Software version 1.6.2.
Started.
Reader #0: FT SCR2000 0
Reader #1: FT SCR2000 1
Reader #2: Generic EMV Smartcard Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC R821MB
Page size : 512 B
Block size : 512 B
Block count : 30535680
Size : 14.56 GB (14910.00 MB)
CID Info
CID : 150100523832314D42007A15D0775225
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : R821MB
Product revision : 0.0
Product serial number : (hex) 7A15D077
Manufacturing date : 05/2015
CSD Info
CSD : D02701320F5903FFF6DBFFEF9240606D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : YES
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 5087232 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R821MB_24_06_2018_14_49_43.bin.
Connect successful.
SW: 1.6.2; FW: 1.24.
Opening C:/Program Files/Medusa Pro Software/Samsung eMMC R821MB_24_06_2018_14_49_45.bin file...
Reading. Please wait...
ERROR[011]: Read error.
At sector 22504
Attempting to read...
Disconnected.
Now search content but no content found.................
how fixed this ????
Started.
#red
Model Settings:#blue
Interface : eMMC
#greenVoltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
#blueDevice : Samsung eMMC R821MB
#greenPage size : 512 B
#greenBlock size : 512 B
#greenBlock count : 30535680
#greenSize : 14.56 GB (14910.00 MB)
#green---------------------------------------------------------------
CID Info
#blueCID : 150100523832314D42007A15D0775225
CSD Info
#blueCSD : D02701320F5903FFF6DBFFEF9240606D
TRAN speed : 26 MHz
EXTCSD Info
#blueRevision 1.7 (for MMC v5.0, v5.01)
#greenBoot1 size : 4096 Kbytes
#greenBoot2 size : 4096 Kbytes
#greenRPMB size : 4096 Kbytes
#green
#greenBoot partition enable : Boot partition 1
#green(Bus width = 1Bit)
#blueBoot ACK : Boot acknowledge sent during boot operation Bit
#green
#greenBoot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
#greenReset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
#greenBoot mode : Use single data rate + backward compatible timings in boot operation (default)
#green
#green
#greenEnhanced attribute : Device can have enhanced technological features in partitions and user data area.
#greenMax enhanced data size: 5087232 Kbytes
#greenPartitions attribute : 0x0
#greenPart setting completed: 0x0
#greenGP partition 1 size : 0 b
#greenGP partition 2 size : 0 b
#greenGP partition 3 size : 0 b
#greenGP partition 4 size : 0 b
#greenEnhanced area size : (0x0) 0 b
#greenEnhanced area start : (0x0) 0 b
#green
Not found#red
Connect successful.
#blueWhole proccess time: .
Reading. Please wait... #blue
#redAt sector 22504
Disconnected.
#red
#red
Interface : eMMC
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
#green
#green
#green
#green
#green
Not found#red
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/R821MB_24_06_2018_14_50_32.bin.
Connect successful.
Parsing device...
Image size in bytes: 2749366272
Warning: Unknown file system type.
Details: Sector offset: 0
Parse finished.
Whole proccess time: 1 seconds : 0 ms.
Parsing contacts........done. No contacts found.
Parsing SMSs........done. No SMS info found.
Old 06-24-2018, 10:01   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
As You can see from Software log:
This warning means, that there is unsupported or encrypted file system in your device, or FS structure is damaged, so Software couldn't analyze it.
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 06-25-2018, 09:40   #3 (permalink)
Member: 310155
Thanks Meter: 1,313
what about read full dump ??
At sector 22504
Disconnected.
Old 06-25-2018, 09:59   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Try to set higher Voltage level (try 2.0V-2.4V) and different Bus Speed values and repeat the operation again. If the the same error will still arrise while reading data, probably eMMC has HW problems.
Page generated in 0.16597 seconds with 8 queries
