10-04-2017, 09:38 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Repairing of LG D290TR is not supported at the moment, but supported repairing of D290N via USB and eMMC (ISP). You can try to connect this phone as D290N and then do "Factory Repair" using the latest original firmware for D290TR (in "*.dz", "*.kdz" and "*.tot"). To repair phone via USB, do the following: 1. Install the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Download and install SRF "LG_D290N_USB.srf" from the Support Area (via "Download *.srf" button in Software). 3. Select "USB" Interface in Software. 4. Select LG D290N in the Software list (it will appear in the list after installation of proper SRF). 5. If necessary, connect TP in your D290TR and connect USB cable - new "Qualcomm..." device should appear in PC Device Manager. 6. Release TP. 7. Press "Connect" button in Software to connect the device. 8. When device will be connected, go to "Factory Repair" tab in the Software. 9. Press "Repair LG devices..." button. 10. Select the latest original LG firmware for D290TR and press "Write partitions" button. 11. Post here full Software log and say the result. To repair phone via eMMC, try to do the following: 1. Install the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Download and install SRF "LG_D290N_EMMC_H4G1D.srf" from the Support Area (via "Download *.srf" button in Software). 3. Select "eMMC" Interface in Software. 4. Select LG D290N in the Software list (it will appear in the list after installation of proper SRF). 5. Press "Pinout" button to look at eMMC pinout picture and solder all necessary eMMC wires. 6. Connect (plug) the device to Box. 7. Press "Connect" button in Software to connect the device. 8. When device will be connected successfully, go to "Factory Repair" tab in the Software. 9. Press "Repair LG devices..." button. 10. Select the latest original firmware LG for D320F8 and press "Write partitions" button. 11. Post here full Software log and say the result. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
