04-15-2019, 23:36 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | LG D295F Device: Unknown eMMC M MOR [Answered] Any solution for this error "Device : Unknown eMMC M MOR" ? Bad EMMC ? I have some phones D295F with this error. Code: Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : D295F SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_D295F_BY_LEANDRO_GRILO.SRF Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC M MOR Page size : 512 B Block size : 512 B Block count : 3848192 Size : 1879.00 MB --------------------------------------------------------------- CID Info CID : 65646F4D204D4F52128100000615444D Manufacturer ID : 0X65 Device/BGA : Device (removable) OEM/Application ID : 0X6F Product name : M MOR Product revision : 8.1 Product serial number : (hex) 615 Manufacturing date : 04/2017 --------------------------------------------------------------- CSD Info CSD : D07FFF320F59007FF6DB80001E40001D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : NO PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x78) 01111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 131072 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/M MOR_15_04_2019_19_31_00.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.6; FW: 1.24. Factory Format will erase all eMMC data! Do you want to continue? Yes. Formating...Done. SW: 1.7.6; FW: 1.24. Disconnected. SW: 1.7.6; FW: 1.24. Error writing EXT_CSD! Disconnected. |
04-16-2019, 00:38 | #2 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | I already tried these options below: 1 - Set 1.8v to 2.2v too 2 - Repair by USB Code: Model Settings: Interface : USB Brand : LG Model : D295 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_D295_USB.SRF Core : Qualcomm MSM8x12 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. |
04-16-2019, 10:37 | #5 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Unfortunately, we don't have or support any adapters for eMMC chips. All what You can find on a market we officially not supporting, so it may work not properly or doesn't work at all |
