01-24-2018, 13:06 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Pakistan Hyderabad Age: 40
Member: 117640 Status: Offline Sonork: 100.1580505 Thanks Meter: 62 | LG D321 secure boot repair done Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G1d Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473164040501A14291415F Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G1d Product revision : 0.5 Product serial number : (hex) 1A14291 Manufacturing date : 04/2014 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H4G1d_24_01_2018_16_10_24.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.2; FW: 1.22. P00: GPT (00000000, 00002000) 4 MB P01: modem (00002000, 00020000) 64 MB P02: sbl1 (00022000, 00000800) 1024 KB P03: rpm (00022800, 00000400) 512 KB P04: tz (00022C00, 00000400) 512 KB P05: sdi (00023000, 00000400) 512 KB P06: aboot (00023400, 00001000) 2048 KB P07: rpmb (00024400, 00000400) 512 KB P08: tzb (00024800, 00000400) 512 KB P09: abootb (00024C00, 00001000) 2048 KB P10: pad (00025C00, 00001000) 2048 KB P11: modemst1 (00026C00, 00001800) 3072 KB P12: modemst2 (00028400, 00001800) 3072 KB P13: misc (00029C00, 00008000) 16 MB P14: persist (00032000, 00010000) 32 MB P15: laf (00042000, 0000B000) 22 MB P16: boot (0004E000, 0000B000) 22 MB P17: recovery (00059000, 0000B000) 22 MB P18: fsg (00064000, 00001800) 3072 KB P19: fsc (00066000, 00000400) 512 KB P20: ssd (00066400, 00000400) 512 KB P21: DDR (00068000, 00000400) 512 KB P22: encrypt (0006A000, 00000400) 512 KB P23: rct (0006A400, 00000400) 512 KB P24: drm (0006C000, 00004000) 8 MB P25: sns (00070000, 00004000) 8 MB P26: factory (00074000, 0000A000) 20 MB P27: fota (0007E000, 00010000) 32 MB P28: sbl1b (0008E000, 00000800) 1024 KB P29: mpt (0008E800, 00010000) 32 MB P30: eksst (0009E800, 00000400) 512 KB P31: system (000A0000, 00307000) 1550 MB P32: cache (003A7000, 00096000) 300 MB P33: userdata (0043D000, 00300C00) 1538 MB P34: grow (0073E000, 00009FDF) 19.98 MB Opening C:/Users/Niaz Hussain/Desktop/New folder/L70/Cricket LG Optimus L70 D321 Firmware/LGD321AT-01-V10c-310-150-APR-06-2014+0.tot file... Signature OK. Signature 2 OK. Open file "C:/Users/Niaz Hussain/Desktop/New folder/L70/Cricket LG Optimus L70 D321 Firmware/LGD321AT-01-V10c-310-150-APR-06-2014+0.tot". Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition sbl1... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition aboot... Done. Writing partition rpmb... Done. Writing partition tzb... Done. Writing partition abootb... Done. Writing partition misc... Done. Writing partition persist... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition rct... Done. Writing partition sbl1b... Done. Writing is finished. SW: 1.5.2; FW: 1.22. Disconnected. |
The Following 2 Users Say Thank You to Niaz Hussain For This Useful Post: |
