Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 03-16-2018, 16:14   #1 (permalink)
Member: 2548753
Thanks Meter: 256
Smile LG D631 McAfee account reset question [Solved]
hello team i need to remove McAfee account here logs
Welcome to Medusa Pro Software version 1.5.5.
Started.
Reader #0: Generic EMV Smartcard Reader 0
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : LG
Model : D631
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_D631_EMMC.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Brand : LG
Model : D631
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Toshiba eMMC 008GE0
Page size : 512 B
Block size : 512 B
Block count : 15269888
Size : 7.28 GB (7456.00 MB)
CID Info
CID : 1101003030384745300019E1039251EF
Manufacturer ID : 0X11
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 008GE0
Product revision : 0.0
Product serial number : (hex) 19E10392
Manufacturing date : 05/2014
CSD Info
CSD : D05E00320F5903FFFFFFFFEF924000D3
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 5 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 3817472 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : d2000000 bytes
Device sector size : 512 bytes
Partition offset : 704512
Number of sectors : 4194304
Device Manufacturer :lge
Device Platform :msm8226
Build ID :LRX22G
Display Build ID :LRX22G
Release ID :5.0.2
Device Model :LG-D631
Device Name :b2l_att_us
Architecture ABI :armeabi-v7a
Architecture ABI2 :armeabi
Architecture ABI List :armeabi-v7a,armeabi
Build Description :b2l_att_us-user 5.0.2 LRX22G 151562013570b release-keys
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/008GE0_16_03_2018_15_10_11.bin.
Connect successful.
SW: 1.5.5; FW: 1.23.
P00: GPT (00000000, 00004000) 8 MB
P01: modem (00004000, 00020000) 64 MB
P02: sbl1 (00024000, 00000800) 1024 KB
P03: rpm (00024800, 00000400) 512 KB
P04: tz (00024C00, 00000400) 512 KB
P05: sdi (00025000, 00000400) 512 KB
P06: aboot (00025400, 00001000) 2048 KB
P07: rpmb (00026400, 00000400) 512 KB
P08: tzb (00026800, 00000400) 512 KB
P09: abootb (00026C00, 00001000) 2048 KB
P10: pad (00027C00, 00001000) 2048 KB
P11: modemst1 (00028C00, 00001800) 3072 KB
P12: modemst2 (0002A400, 00001800) 3072 KB
P13: misc (0002BC00, 00008000) 16 MB
P14: persist (00034000, 00010000) 32 MB
P15: laf (00044000, 0000B000) 22 MB
P16: boot (00050000, 0000B000) 22 MB
P17: recovery (0005B000, 0000B000) 22 MB
P18: fsg (00066000, 00001800) 3072 KB
P19: fsc (00068000, 00000400) 512 KB
P20: ssd (00068400, 00000400) 512 KB
P21: DDR (0006C000, 00000400) 512 KB
P22: encrypt (00070000, 00000400) 512 KB
P23: rct (00070400, 00000400) 512 KB
P24: drm (00074000, 00004000) 8 MB
P25: sns (00078000, 00004000) 8 MB
P26: factory (0007C000, 0000A000) 20 MB
P27: fota (00086000, 00010000) 32 MB
P28: sbl1b (00098000, 00000800) 1024 KB
P29: mpt (00098800, 00010000) 32 MB
P30: eksst (000A8800, 00000400) 512 KB
P31: system (000AC000, 00400000) 2048 MB
P32: cache (004AC000, 001C2000) 900 MB
P33: userdata (0066E000, 00810400) 4.032 GB
P34: grow (00E80000, 0000FFDF) 31.98 MB
Please select file.
Switched to boot area partition 1.
Opening C:/Users/SIMO/Desktop/Toshiba eMMC 008GE0_16_03_2018_15_10_43.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:01
Switched to boot area partition 2.
Opening C:/Users/SIMO/Desktop/Toshiba eMMC 008GE0_16_03_2018_15_11_00.bin file...
The Following 2 Users Say Thank You to Medofficiel For This Useful Post:
Old 03-16-2018, 16:19   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hello.
Please read out "misc" partition to binary file, upload somewhere and post here link.
Old 03-17-2018, 13:14   #3 (permalink)
Member: 2548753
Thanks Meter: 256
Originally Posted by Medusa Box View Post
Please read "misc" partition into binary ("*.bin") file, not into "*.srf". To read partitions into binary files do the following: connect the device, press "Partition manager" button in Software, select necessary partitions, check (select) «Read each partition into separate binary («*.bin») file» option in the software and press "Read".
here sir
https://www.4shared.com/file/gjmC-F8..._2018_11_.html
Old 03-17-2018, 13:52   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
OK, we will patch it and will send You here to You write pathed "misc" partition back into the phone. Please read out Full flash from your device (connect the device, select "Full" option in Software and press "Read" button), it is better always to have full backup.
Old 03-17-2018, 14:57   #5 (permalink)
Member: 2548753
Thanks Meter: 256
full backup done waiting you ^^
Old 03-17-2018, 16:00   #6 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
OK, here is the patched "misk" partition for You: https://drive.google.com/file/d/1pw4...28pqn8fIp/view.
Accordingly to Software log, the start address of "misk" partition on flash chip is 0002BC00 and length - 00008000.
So, to write "misk" partition, do the next:
1. Connect the device.
2. Select "Custom" option in Software.
3. Select "Hex block" type of data.
4. Set "Start: 0002BC00".
5. Set "Length: 00008000".
6. Press "Write" button, select "misk" partition file and write it.
After writing of the patched "misk" partition, You shouldn't power the phone ON! If You will power on the phone, "misk" partition will be rebuilded by phone and Mcafee account will remain. So after writing the patched "misk" partition, You need to put the phone into Download (Emergency) Mode manually and re-flash it with the same firmware version, which is in the phone now, or with higher firmware version. After writing firmware, check, whether Mcafee account was removed.
Old 03-17-2018, 16:16   #7 (permalink)
Member: 2548753
Thanks Meter: 256
can't find custom option in software
Old 03-17-2018, 16:49   #8 (permalink)
Member: 2548753
Thanks Meter: 256
done download mode ok
but cant find the higher firmware please help
Platform: LG Qualcomm
Selected port: COM11
Selected model: D631
Reading info...
Model ID: LG-D631
IMEI: 014087-00-087394-4
Android version: 5.0.2
Battery level: 89%
SW Version: D63120d
Mode: Emergency
Initializing flash...OK
SW version: LGD631AT-00-V20d-ATT-US-JUN-05-2015+0
LAF Version: 1.1
Product ID: CT65S140824002126
Target operator: ATT
Hardware: rev_10
Performed by 2.8.0 Software version.
The Following User Says Thank You to Medofficiel For This Useful Post:
Old 03-17-2018, 21:33   #9 (permalink)
Member: 2548753
Thanks Meter: 256
Solved kill switch disabled done first in the world
Old 08-13-2018, 22:26   #10 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 65
Link deleted, please reupload, i need patched misc partition
Old 08-14-2018, 04:24   #11 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
You can't use "misc" partition from another phone, this may lead to damage your device. Please read out "misc" partition and post here link, we will patch it and send You to write it.
Old 09-04-2018, 15:43   #12 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 65
Misc Partition
Here its my Misc partition...
https://mega.nz/#!FZImjAbD!ypZ6I2ifI...CHkooPX6fOkpnI
Thanks
Old 09-07-2018, 08:34   #13 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Please, check your PM.
The Following User Says Thank You to Medusa Box For This Useful Post:
Old 01-23-2019, 18:05   #14 (permalink)
Member: 2450214
Thanks Meter: 106
patch this misc for me:
https://drive.google.com/file/d/1qFy...ew?usp=sharing
Old 01-24-2019, 10:47   #15 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,413
Hello.
Page generated in 0.28378 seconds with 8 queries
