03-16-2018, 16:14 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: HUAWEI
Member: 2548753 Status: Offline Thanks Meter: 256 | LG D631 McAfee account reset question [Solved] Welcome to Medusa Pro Software version 1.5.5. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : D631 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_D631_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : D631 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_D631_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 008GE0 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 1101003030384745300019E1039251EF Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 008GE0 Product revision : 0.0 Product serial number : (hex) 19E10392 Manufacturing date : 05/2014 --------------------------------------------------------------- CSD Info CSD : D05E00320F5903FFFFFFFFEF924000D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 5 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 704512 Number of sectors : 4194304 Device Manufacturer :lge Device Platform :msm8226 Build ID :LRX22G Display Build ID :LRX22G Release ID :5.0.2 Device Model :LG-D631 Device Name :b2l_att_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :b2l_att_us-user 5.0.2 LRX22G 151562013570b release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/008GE0_16_03_2018_15_10_11.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 00020000) 64 MB P02: sbl1 (00024000, 00000800) 1024 KB P03: rpm (00024800, 00000400) 512 KB P04: tz (00024C00, 00000400) 512 KB P05: sdi (00025000, 00000400) 512 KB P06: aboot (00025400, 00001000) 2048 KB P07: rpmb (00026400, 00000400) 512 KB P08: tzb (00026800, 00000400) 512 KB P09: abootb (00026C00, 00001000) 2048 KB P10: pad (00027C00, 00001000) 2048 KB P11: modemst1 (00028C00, 00001800) 3072 KB P12: modemst2 (0002A400, 00001800) 3072 KB P13: misc (0002BC00, 00008000) 16 MB P14: persist (00034000, 00010000) 32 MB P15: laf (00044000, 0000B000) 22 MB P16: boot (00050000, 0000B000) 22 MB P17: recovery (0005B000, 0000B000) 22 MB P18: fsg (00066000, 00001800) 3072 KB P19: fsc (00068000, 00000400) 512 KB P20: ssd (00068400, 00000400) 512 KB P21: DDR (0006C000, 00000400) 512 KB P22: encrypt (00070000, 00000400) 512 KB P23: rct (00070400, 00000400) 512 KB P24: drm (00074000, 00004000) 8 MB P25: sns (00078000, 00004000) 8 MB P26: factory (0007C000, 0000A000) 20 MB P27: fota (00086000, 00010000) 32 MB P28: sbl1b (00098000, 00000800) 1024 KB P29: mpt (00098800, 00010000) 32 MB P30: eksst (000A8800, 00000400) 512 KB P31: system (000AC000, 00400000) 2048 MB P32: cache (004AC000, 001C2000) 900 MB P33: userdata (0066E000, 00810400) 4.032 GB P34: grow (00E80000, 0000FFDF) 31.98 MB Please select file. Switched to boot area partition 1. Opening C:/Users/SIMO/Desktop/Toshiba eMMC 008GE0_16_03_2018_15_10_43.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 1.5.5; FW: 1.23. Switched to boot area partition 2. Opening C:/Users/SIMO/Desktop/Toshiba eMMC 008GE0_16_03_2018_15_11_00.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 1.5.5; FW: 1.23. Last edited by Medusa Box; 03-18-2018 at 13:43. |
The Following 2 Users Say Thank You to Medofficiel For This Useful Post: |
03-17-2018, 13:14 | #3 (permalink) | |
Member: 2548753 Status: Offline Thanks Meter: 256 | Quote:
https://www.4shared.com/file/gjmC-F8..._2018_11_.html | |
03-17-2018, 13:52 | #4 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | OK, we will patch it and will send You here to You write pathed "misc" partition back into the phone. Please read out Full flash from your device (connect the device, select "Full" option in Software and press "Read" button), it is better always to have full backup. |
03-17-2018, 14:57 | #5 (permalink) | |
03-17-2018, 16:00 | #6 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | OK, here is the patched "misk" partition for You: https://drive.google.com/file/d/1pw4...28pqn8fIp/view. Accordingly to Software log, the start address of "misk" partition on flash chip is 0002BC00 and length - 00008000. Quote:
1. Connect the device. 2. Select "Custom" option in Software. 3. Select "Hex block" type of data. 4. Set "Start: 0002BC00". 5. Set "Length: 00008000". 6. Press "Write" button, select "misk" partition file and write it. After writing of the patched "misk" partition, You shouldn't power the phone ON! If You will power on the phone, "misk" partition will be rebuilded by phone and Mcafee account will remain. So after writing the patched "misk" partition, You need to put the phone into Download (Emergency) Mode manually and re-flash it with the same firmware version, which is in the phone now, or with higher firmware version. After writing firmware, check, whether Mcafee account was removed. | |
03-17-2018, 16:16 | #7 (permalink) | |
03-17-2018, 16:49 | #8 (permalink) | |
but cant find the higher firmware please help Platform: LG Qualcomm Selected port: COM11 Selected model: D631 Reading info... Model ID: LG-D631 IMEI: 014087-00-087394-4 Android version: 5.0.2 Battery level: 89% SW Version: D63120d Mode: Emergency Initializing flash...OK SW version: LGD631AT-00-V20d-ATT-US-JUN-05-2015+0 Android version: 5.0.2 LAF Version: 1.1 Product ID: CT65S140824002126 IMEI: 014087-00-087394-4 Target operator: ATT Hardware: rev_10 Performed by 2.8.0 Software version. | |
The Following User Says Thank You to Medofficiel For This Useful Post: |
08-13-2018, 22:26 | #10 (permalink) | |
Freak Poster Join Date: Mar 2011 Location: 1st Direct Source
Member: 1537172 Status: Offline Thanks Meter: 65 | Link deleted, please reupload, i need patched misc partition Quote:
08-14-2018, 04:24 | #11 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | You can't use "misc" partition from another phone, this may lead to damage your device. Please read out "misc" partition and post here link, we will patch it and send You to write it. |
09-04-2018, 15:43 | #12 (permalink) | |
Member: 1537172 Status: Offline Thanks Meter: 65 | Misc Partition Quote:
https://mega.nz/#!FZImjAbD!ypZ6I2ifI...CHkooPX6fOkpnI Thanks | |
01-23-2019, 18:05 | #14 (permalink) | |
Freak Poster Join Date: Aug 2015 Location: Jamaica
Member: 2450214 Status: Offline Thanks Meter: 106 | Quote:
https://drive.google.com/file/d/1qFy...ew?usp=sharing | |
