04-06-2017, 12:11 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: In Your Heart Age: 37
Member: 1759636 Status: Offline Sonork: 100.1591515 Thanks Meter: 785 | LG F500L Dead Boot Repair Done :) i Solve dead boot issue in LG F500L Done with medusa Watch Video https://www.youtube.com/watch?v=rALzqihoLRU Br WBGSM Last edited by Medusa Box; 04-06-2017 at 13:07. |
The Following 4 Users Say Thank You to WBGSM For This Useful Post: |
04-06-2017, 13:06 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Thanks for your good report and video instructions! |
The Following User Says Thank You to Medusa Box For This Useful Post: |
09-26-2017, 07:51 | #4 (permalink) |
Junior Member Join Date: Dec 2016 Location: Bataan
Member: 2661026 Status: Offline Thanks Meter: 1 | hello medusa team why does it always says ERROR[001]: Can not connect. No target device present. ive already check all the pin out and repeated it many times model: lg-f500l deadboot trying to revive with this procedure |
09-26-2017, 07:56 | #5 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. What Software version do You use exactly? Post here full Software log, not reduced. Also, please read and follow these rules: Medusa - GSM-Forum, http://forum.gsmhosting.com/vbb/f664...leted-2165828/. |
09-26-2017, 08:16 | #6 (permalink) |
Member: 2661026 Status: Offline Thanks Meter: 1 | hello team im using medusa pro 1.4.4 version tnx here is the log.. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H815 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_H815_EMMC.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. |
09-26-2017, 08:21 | #7 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Here are a few main possible reasons why the device not connected: 1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible (3-5 CM length). 6. For GND connection use more thicker wire. Check all of them and try to connect the device again. |
09-26-2017, 09:19 | #8 (permalink) |
Member: 2661026 Status: Offline Thanks Meter: 1 | is tthere any resistor to put in the isp adapter like 150 ohms 0r 300 omhs if theres any can you send me a pic ive already do the tuts youve said but still same prob.. |
09-26-2017, 09:26 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | For connecting H815 no need to use resistor; for F500L, please ask mr. WBGSM, as You can see above, he have connected and successfully repaired this device. |
09-20-2018, 04:28 | #14 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Here are a few main possible reasons why the device may not connect: 1. You have connected battery or USB cable. Before connecting the device You must disconnect the battery and the USB cable, and then connect the device without power, this is important! 2. Some wires are soldered incorrectly. Carefully check soldering of all wires. 3. In the process of soldering, the resistors were burned (damaged) by using soldering iron or the pin pads on the board to which wires were soldered were damaged. Need replace damaged resistors and restore the pin pads on the board. 4. The ends of wires that were soldered, had not been cleared. Wire, that comes complete with Medusa Pro Box, is covered with an insulator, so before soldering need to clean the ends of each wire. 5. Soldered wires are too long. Make each wire as short as possible (3-5 CM length). 6. For GND connection use more thicker wire. Check all of them and try to connect the device again. |
