02-09-2017, 00:29 | #1 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2452030 Status: Offline Sonork: www.sonork.com Thanks Meter: 0 | Lg G4 H810 AT&T repair boot ??? and method boot repair with MedusaPro in menu supports for MEDUSA PRO i can find H810 module i find H815 and other ?? some body here can help me ??? PLZ because im going to buy MedusaPro for this Problem |
02-09-2017, 07:41 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. You can try to repair this phone via USB. To repair this phone via USB, try to do the following: 1. Install the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Select "USB" interface option in Software. 3. Select "Device (Core) : Qualcomm MSM8992". 4. Connect the phone in "Qualcomm...9008" Mode to PC. 5. Press "Connect" button. 6. When device will be connected successfully, make Erase Full flash (select "Full" option in Software and press "Erase" button). 7. Re-connect the device and make Factory Repair using the latest original LG firmware for this phone model (in "*.tot" or "*.kdz" format). 8. Disconnect the phone and try to put it into Download Mode (disconnect the cable, re-connect the battery, press and hold "Vol+" button and connect USB cable). To repair phone via eMMC, try to do the following: 1. Install the latest Medusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Download and install SRF (Smart Repair File) for H811 ("Download *.srf" button in Software). 3. Select LG H811 in the Software list (model will appear in Software list after SFR installation). 4. Solder all necessary eMMC wires accordingly to the pinout picture ("Help" or "Pinout" button in Software). eMMC pinout of H810 is similar to pinout of H811. 5. Connect the device to box and press "Connect" button. 6. When device will be connected successfully, make Erase Full flash (select "Full" option in Software and press "Erase" button). 7. Re-connect the device and make Factory Repair using the latest original LG firmware for this phone model (in "*.tot" or "*.kdz" format). 8. Disconnect the phone and try to put it into Download Mode (disconnect the cable, re-connect the battery, press and hold "Vol+" button and connect USB cable). Also, look here: http://forum.gsmhosting.com/vbb/f664...fisrt-2165917/, http://forum.gsmhosting.com/vbb/f664.../#post12310837, http://forum.gsmhosting.com/vbb/f664...ision-2155833/, http://forum.gsmhosting.com/vbb/f664...error-2176061/. |
