09-27-2011, 15:39 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | lg gt540 unable to write flash i repair gt540 boot with medusa but unable to write flash file i try version 10 and version 20 with octopus after repair boot but flashing start and give earror here is the log of repairing Selected device model: LG GT540 Connecting. Please wait... MI: RTCK reaction time 126 ns. Detected Core ID: 203C00E1 VREF level : 2.34 V CPU : Qualcomm MSM7227 Core ID : 203C00E1 MI: P15,C0,C0: 0x41069265 MI: Loading server. MI: Starting server. MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x0000007F. MI: Detailed server caps: FLASH, CFG, ECC, BASE, WDOG, DWP, SAFEW MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0x0055ECBC. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 0000007F Flash device: Samsung 512Mb Flash ID : 0000ECBC Page size : 2048 bytes Block size : 64 pages (128 Kb) Block count: 4096 Flash size : 512 Mb MI: Setting configuration: 0xAAD400DA, 0x0044747E, 0x0000000D MI: Configuration done. Opening "C:\Program Files\GsmServer\Medusa\Firmware\LG_GT540_Repair.mf " file... Erasing BOOT section. Please wait... Done Erasing FIRMWARE section. Please wait... Done Writting BOOT section. Please wait... Done Writting APPBOOT section. Please wait... Done Writting APPFOTA section. Please wait... Done Disconnected Repair done. can u provide full dump..? br |
09-27-2011, 15:50 | #2 (permalink) |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | here is the flashing log Platform: LG Qualcomm Selected port: COM88 Selected model: GT540 Phone model: GT540 Mode: Emergency Opening "GT540AT-00-V10c-ARB-XX-SEP-02-2010.oct"... > OK Writing Firmware... Checking partition... > OK Write Bootloaders: No Writing AMSS...> Failed! ------------------------------------------------------ Platform: LG Qualcomm Selected port: COM90 Selected model: GT540 Phone model: GT540 Mode: Emergency -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM90 Selected model: GT540 Phone model: GT540 Mode: Emergency Opening "GT540AT-00-V20e-BAL-XXX-MAR-22-2011.oct"... > OK Writing Firmware... Checking partition...> OK Write Bootloaders: No Writing AMSS... > Failed! |
09-27-2011, 16:00 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. To fully resurrect the phone after repairing of phone's boot, please carefully perform the next steps with Octopus Box LG software: 1. Disconnect the cable, reconnect the battery, manually put phone into emergency mode (press and hold "Vol+"+"Vol-"+"Power" and connect the cable). It is very IMPORTANT to put the phone into Emergency mode MANUALLY! 2. Then You need to select "Write boot loaders" option and write "GT540-FOR-UNLOCK-new-boot" firmware from the support area. 3. If the error occurs during writing (AMSS or another part of firmware), YOU MANDATORY NEED to disconnect the cable, reconnect the battery, MANUALLY put phone into emergency mode (press and hold "Vol+"+"Vol-"+"Power"), connect the cable and repeat the procedure of firmware writing. Also it is very IMPORTANT to put the phone into Emergency mode MANUALLY! 4. After writing of firmware will finished, please make repairing of phone's security, fix IMEI, repair NVM and unlock phone. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
09-27-2011, 17:09 | #4 (permalink) |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | done thanks Selected model: GT540 Phone model: GT540 Mode: Emergency Opening "GT540-FOR-UNLOCK.oct"...9/27/2011 8:31:43 PM > OK Writing Firmware... Checking partition...9/27/2011 8:31:44 PM > OK Write BootLoaders: Yes Writing QCSBL...9/27/2011 8:31:44 PM > OK Writing AMSS...9/27/2011 8:32:25 PM > OK Writing ZImage...9/27/2011 8:32:29 PM > OK Writing FWUA...9/27/2011 8:32:30 PM > OK Writing System...9/27/2011 8:37:29 PM > OK Finalizing...9/27/2011 8:37:34 PM > OK Writing Firmware done! To finish the operation please power on phone and wait 3 minutes Welcome to Octopus Box LG Software version 1.9.3 -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM101 Selected model: GT540 Mode: Normal Phone model: GT540 SW Version: GT540-M76XX-V20c-DEC-16-2010-XX IMEI: 355614-04-122224-0 Bluetooth address: 5C:173F:CA:41 Checking security...OK Fixing IMEI... New IMEI: 352166-04-400429-2 Reading security area...OK Backup saved to "GT540-355614041222240_27-09-2011_21-06-00.sec" Writing security area...OK IMEI successfully fixed! Rebooting phone... -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM11 Selected model: GT540 Phone not detected. Please try again. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM11 Selected model: GT540 Phone not detected. Please try again. -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM106 Selected model: GT540 Mode: Normal Phone model: GT540 SW Version: GT540-M76XX-V20c-DEC-16-2010-XX IMEI: 352166-04-400429-2 Bluetooth address: 5C:173F:CA:41 Checking security...OK Unlocking... Reading security area...OK Backup saved to "GT540-352166044xxxxxx_27-09-2011_21-07-17.sec" Writing security area...OK Phone successfully unlocked! Rebooting phone... -------------------------------------------------------------------------------- Platform: LG Qualcomm Selected port: COM106 Selected model: GT540 Mode: Normal Phone model: GT540 SW Version: GT540-M76XX-V20c-DEC-16-2010-XX IMEI: 352166-04-xxxxxx Bluetooth address: 5C:173F:CA:41 Repairing NVM... Repairing NVM complete. Rebooting phone... br |
The Following User Says Thank You to c_ahmad79 For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
