08-12-2018, 13:37 | #1 (permalink) |
Insane Poster Join Date: Feb 2015
Member: 2352776 Status: Offline Sonork: 100.1681383 Thanks Meter: 23 | LG H636 repair done, but still "dead" [Solved] Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H631 SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_H631_EMMC_R311MB.srf Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC HAG2e Page size : 512 B Block size : 512 B Block count : 30785536 Size : 14.68 GB (15032.00 MB) --------------------------------------------------------------- CID Info CID : 90014A4841473265050757A1384C72A5 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG2e Product revision : 0.7 Product serial number : (hex) 57A1384C Manufacturing date : 07/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/HAG2e_12_08_2018_12_31_45.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.5; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: sbl1 (00000400, 00000400) 512 KB P02: tz (00000800, 00000400) 512 KB P03: hyp (00000C00, 00000400) 512 KB P04: rpm (00001000, 00000400) 512 KB P05: aboot (00001400, 00001000) 2048 KB P06: pad (00002400, 00000C00) 1536 KB P07: sbl1bak (00003000, 00000400) 512 KB P08: tzbak (00003400, 00000400) 512 KB P09: hypbak (00003800, 00000400) 512 KB P10: rpmbak (00003C00, 00000400) 512 KB P11: abootbak (00004000, 00001000) 2048 KB P12: misc (00005000, 00008000) 16 MB P13: persist (0000D000, 00008000) 16 MB P14: metadata (00015000, 00000400) 512 KB P15: modemst1 (00015400, 00000C00) 1536 KB P16: modemst2 (00016000, 00000C00) 1536 KB P17: laf (00016C00, 0000C000) 24 MB P18: boot (00022C00, 0000C000) 24 MB P19: recovery (0002EC00, 0000C000) 24 MB P20: fsg (0003AC00, 00000C00) 1536 KB P21: fsc (0003B800, 00000400) 512 KB P22: ssd (0003BC00, 00000400) 512 KB P23: DDR (0003C000, 00000400) 512 KB P24: sec (0003C400, 00000400) 512 KB P25: encrypt (0003C800, 00000400) 512 KB P26: eksst (0003CC00, 00000400) 512 KB P27: rct (0003D000, 00000400) 512 KB P28: sns (0003D400, 00004000) 8 MB P29: factory (00041400, 00010000) 32 MB P30: fota (00051400, 00010000) 32 MB P31: drm (00061400, 00004000) 8 MB P32: mpt (00065400, 0000C000) 24 MB P33: modem (00071400, 00020000) 64 MB P34: persistent (00091400, 00001000) 2048 KB P35: pad2 (00092400, 00001000) 2048 KB P36: system (00093400, 00500000) 2560 MB P37: cache (00593400, 001C2000) 900 MB P38: userdata (00755400, 015C0000) 10.88 GB P39: grow (01D15400, 00009BDF) 19.48 MB Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_H631_EMMC_R311MB.srf". Write data verification is enabled. Writing GPT partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing hyp partition... Done. Writing rpm partition... Done. Writing aboot partition... Done. Writing pad partition... Done. Writing misc partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing sec partition... Done. Smart Repair is successfully complete. SW: 1.6.5; FW: 1.24. Disconnected. Last edited by Medusa Box; 08-14-2018 at 04:27. |
08-12-2018, 14:10 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Accordingly to your Software log, repair operation was performed successfully and correctly. If the device doesn't go into Download Mode, here can be two main reasons of this problem - device has HW issue (problem with eMMC chip, often occur with this device model) or boot loaders in SRF, which You have used for repairing, are not suitable (not compatible) with your phone revision (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to perform "Factory Repair" operation ("Factory repair" tab in Software) using the latest available original LG firmware (in "*.dz", "*.kdz" or "*.tot" format) for this device model. Post the result. |
08-13-2018, 23:12 | #3 (permalink) |
Member: 2352776 Status: Offline Sonork: 100.1681383 Thanks Meter: 23 | Now it's enter to download mode and flashing done success but it is stuck on LG logo and keep restarting |
The Following User Says Thank You to sadak89 For This Useful Post: |
08-14-2018, 04:27 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to write another firmwares (the same or higher versions). Also often this issue (stuck on LG logo and keep restarting) means, that device has HW problem(s). |
