07-23-2018, 12:35 | #1 (permalink) |
Insane Poster Join Date: Apr 2009
Member: 1005367 Status: Offline Thanks Meter: 0 | LG H901 dead boot repair question [Answered] Sending loader...OK. Loader successfully initialized. Device : CoreID_009690E1 Core : Qualcomm MSM8992 Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) Connect successful. --------------------------------------------------------------- SW: 1.6.4; FW: 1.24. Opening C:/Users/mahmoud/Desktop/H90120j_00_0712.kdz file... Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition pmic... Done. Writing partition sbl1... Done. Writing partition tz... Done. Writing partition sdi... Done. Writing partition hyp... Done. Writing partition rpm... Done. Writing partition aboot... Done. Writing partition sbl1bak... Done. Writing partition pmicbak... Done. Writing partition hypbak... Done. Writing partition tzbak... Done. Writing partition rpmbak... Done. Writing partition abootbak... Done. Writing partition sdibak... Done. Writing partition persist... Done. Writing partition sec... Done. Writing partition rct... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition raw_resources... Done. Writing partition raw_resourcesbak... Done. Writing partition factory... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition system... Done. Writing partition BackupGPT... Done. Writing is finished. SW: 1.6.4; FW: 1.24. Disconnected. Last edited by Medusa Box; 07-23-2018 at 12:44. |
07-23-2018, 12:46 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Try to use latest (higher) firmware versions (V30x) for "Factory Repair". Check here links: http://forum.gsmhosting.com/vbb/f664...olved-2423758/. |
07-24-2018, 05:17 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | You can download from here: https://lg-firmwares.com/lg-h901bk-firmwares/firmwares/. |
07-27-2018, 04:39 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | If all loaders on Software for this device CPU are not compatible for your device revision, You can try to repair this device via eMMC. Unfortunately not all necessary pins are present on phone's PCB for eMMC (ISP) connection. If You have enough experience in soldering, You can remove eMMC chip from PCB, solder necessary wires directly to eMMC chip contacts (or use proper eMMC adapter for direct connection), do repair and then solder eMMC chip back to device's PCB. Currently no another solution. |
07-28-2018, 04:10 | #7 (permalink) | |
Member: 1005367 Status: Offline Thanks Meter: 0 | Quote:
