05-21-2018, 09:46 | #1 (permalink) |
Freak Poster Join Date: Oct 2017
Member: 2773088 Status: Offline Thanks Meter: 24 | LG L33L repair question [Solved] Welcome to Octoplus Pro JTAG Software version 1.5.9. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 150100514E31534D4201A6B2D4B05243 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.1 Product serial number : (hex) A6B2D4B0 Manufacturing date : 05/1999 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/QN1SMB_21_05_2018_01_41_39.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. Last edited by Octopus box; 05-22-2018 at 08:13. |
05-21-2018, 09:58 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. As You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 1024.00 MB: Quote:
05-21-2018, 10:09 | #3 (permalink) | |
Member: 2773088 Status: Offline Thanks Meter: 24 | Quote:
Welcome to Octoplus Pro JTAG Software version 1.5.9. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.4V Bus Mode : 1 bit Bus speed : 10 MHz Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 150100514E31534D4201A6B2D4B05243 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.1 Product serial number : (hex) A6B2D4B0 Manufacturing date : 05/1999 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 32768 Kbytes Boot1 size : 25088 Kbytes Boot2 size : 25088 Kbytes RPMB size : 8192 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 4Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0xC1) 11000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/QN1SMB_21_05_2018_02_06_50.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. | |
05-21-2018, 10:51 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Yes, connection is still incorrect. Try to use 150 Ohm pull-up resistor between CMD and 2.8(9)V pins (not 1.8V pin), like on this picture: https://i.imgur.com/8qE1wzB.jpg. Post the result. |
05-21-2018, 11:00 | #5 (permalink) | |
05-21-2018, 11:11 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | We have tried to connect our LG LS665 right now with 150 Ohm resistor, and there is no any problems with connecting. Post here photos in high quality on how You have soldered wires and pull-up resistor, we will check. |
05-21-2018, 13:09 | #9 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
05-21-2018, 14:00 | #10 (permalink) |
Member: 2773088 Status: Offline Thanks Meter: 24 | can i use this emmc to repair the phone i already removed the first one it looks like it was a hardware issue. this is from a diffrent phone should i format it or erase it or just write the l33l firmware over it . Welcome to Octoplus Pro JTAG Software version 1.5.9. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.2V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31534D420148FFC05E3217 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.1 Product serial number : (hex) 48FFC05E Manufacturing date : 03/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 545792 Number of sectors : 4697088 Device Manufacturer :lge Device Platform :msm8916 Build ID :LRX21Y Display Build ID :LRX21Y Release ID :5.0.1 Device Model :LGL22C Device Name :y50c_trf_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :y50c_trf_us-user 5.0.1 LRX21Y L22CV10a.1421747164 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/QN1SMB_21_05_2018_05_47_09.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. P00: GPT (00000000, 00000400) 512 KB P01: sbl1 (00000400, 00000400) 512 KB P02: tz (00000800, 00000400) 512 KB P03: hyp (00000C00, 00000400) 512 KB P04: rpm (00001000, 00000400) 512 KB P05: aboot (00001400, 00001000) 2048 KB P06: pad (00002400, 00000C00) 1536 KB P07: sbl1bak (00003000, 00000400) 512 KB P08: tzbak (00003400, 00000400) 512 KB P09: hypbak (00003800, 00000400) 512 KB P10: rpmbak (00003C00, 00000400) 512 KB P11: abootbak (00004000, 00001000) 2048 KB P12: misc (00005000, 00008000) 16 MB P13: persist (0000D000, 00008000) 16 MB P14: metadata (00015000, 00000400) 512 KB P15: modemst1 (00015400, 00000C00) 1536 KB P16: modemst2 (00016000, 00000C00) 1536 KB P17: laf (00016C00, 0000C000) 24 MB P18: boot (00022C00, 0000C000) 24 MB P19: recovery (0002EC00, 0000C000) 24 MB P20: fsg (0003AC00, 00000C00) 1536 KB P21: fsc (0003B800, 00000400) 512 KB P22: ssd (0003BC00, 00000400) 512 KB P23: DDR (0003C000, 00000400) 512 KB P24: sec (0003C400, 00000400) 512 KB P25: encrypt (0003C800, 00000400) 512 KB P26: eksst (0003CC00, 00000400) 512 KB P27: rct (0003D000, 00000400) 512 KB P28: sns (0003D400, 00004000) 8 MB P29: factory (00041400, 00010000) 32 MB P30: fota (00051400, 00010000) 32 MB P31: drm (00061400, 00004000) 8 MB P32: modem (00065400, 00020000) 64 MB P33: system (00085400, 0047AC00) 2294 MB P34: cache (00500000, 000C8000) 400 MB P35: userdata (005C8000, 008BF000) 4.373 GB P36: grow (00E87000, 00008FDF) 17.98 MB |
05-21-2018, 14:16 | #11 (permalink) | |
05-22-2018, 08:09 | #12 (permalink) |
Member: 2773088 Status: Offline Thanks Meter: 24 | thanks a lot the repair was finished the problem was a hardware issue from the phone itself any emmc i put on the phone would give me the same reading and on another board it works perfectly just fine so i removed the orginal emmc and programmed it and soldered it back now it work just fine |
The Following User Says Thank You to pomgrapes For This Useful Post: |
