09-12-2018, 20:53 | #1 (permalink) |
Registered User Join Date: Aug 2003 Location: ALGERIA ,DZ
Member: 37521 Status: Offline Thanks Meter: 50 | LG LS450 Boot repaired but not power ON [Answered] I have repaired BOOT of an LG LS450 dead after downgrade from ZV7 to ZV5 boot repair was successfull but phone not power on or enter download mode even I use "SMART REPAIR" or use factory file ZV7 or ZV5 here is log of operation: by factory file: Parsing file... Opening E:/GSM02/GSM PHONES/LG/LS450/LS450ZV7_00.tot file... Signature OK. Signature 2 OK. File parsing finished. Open file "E:/GSM02/GSM PHONES/LG/LS450/LS450ZV7_00.tot". Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. #greenWriting partition modem... Done. #greenWriting partition sbl1... Done. #greenWriting partition tz... Done. #greenWriting partition rpm... Done. #greenWriting partition aboot... Done. #greenWriting partition sbl1bak... Done. #greenWriting partition tzbak... Done. #greenWriting partition rpmbak... Done. #greenWriting partition abootbak... Done. #greenWriting partition sec... Done. #greenWriting partition raw_resources... Done. #greenWriting partition raw_resourcesbak... Done. #greenWriting partition persist... Done. #greenWriting partition laf... Done. #greenWriting partition boot... Done. #greenWriting partition recovery... Done. #greenWriting partition recoverybak... Done. #greenWriting partition factory... Done. #greenWriting is finished. SW: 1.6.6; FW: 1.24. #blue by smart repair : Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS450 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS450_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H8G1e Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 90014A483847316505084EEBBD26A3C3 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G1e Product revision : 0.8 Product serial number : (hex) 4EEBBD26 Manufacturing date : 10/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H8G1e_12_09_2018_20_32_27.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.6; FW: 1.24. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 00020000) 64 MB P02: sbl1 (00024000, 00000400) 512 KB P03: tz (00024400, 00000800) 1024 KB P04: rpm (00024C00, 00000400) 512 KB P05: aboot (00025000, 00001000) 2048 KB P06: sbl1bak (00026000, 00000400) 512 KB P07: tzbak (00026400, 00000800) 1024 KB P08: rpmbak (00026C00, 00000400) 512 KB P09: abootbak (00027000, 00001000) 2048 KB P10: modemst1 (00028000, 00000C00) 1536 KB P11: modemst2 (00028C00, 00000C00) 1536 KB P12: ssd (00029800, 00000400) 512 KB P13: DDR (00029C00, 00000400) 512 KB P14: fsg (0002A000, 00000C00) 1536 KB P15: fsc (0002AC00, 00000400) 512 KB P16: sec (0002B000, 00000400) 512 KB P17: keystore (0002B400, 00000400) 512 KB P18: encrypt (0002B800, 00000400) 512 KB P19: eksst (0002BC00, 00000400) 512 KB P20: devinfo (0002C000, 00000800) 1024 KB P21: config (0002C800, 00000400) 512 KB P22: spare1 (0002CC00, 00003400) 6.5 MB P23: fota (00030000, 00003000) 6 MB P24: rct (00033000, 00000400) 512 KB P25: spare2 (00033400, 00000C00) 1536 KB P26: raw_resources (00034000, 00000800) 1024 KB P27: raw_resourcesbak (00034800, 00000800) 1024 KB P28: drm (00035000, 00003000) 6 MB P29: sns (00038000, 00003000) 6 MB P30: misc (0003B000, 00005000) 10 MB P31: carrier (00040000, 00014000) 40 MB P32: persist (00054000, 00004000) 8 MB P33: laf (00058000, 00008000) 16 MB P34: boot (00060000, 00008000) 16 MB P35: recovery (00068000, 00008000) 16 MB P36: recoverybak (00070000, 00008000) 16 MB P37: factory (00078000, 0000C000) 24 MB P38: mpt (00084000, 00004000) 8 MB P39: system (00088000, 00560000) 2752 MB P40: cache (005E8000, 001C2000) 900 MB P41: userdata (007AA000, 006E2000) 3524 MB P42: grow (00E8C000, 00003FDF) 7.984 MB Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS450_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing rpm partition... Done. Writing aboot partition... Done. Writing sbl1bak partition... Done. Writing tzbak partition... Done. Writing rpmbak partition... Done. Writing abootbak partition... Done. Writing ssd partition... Done. Writing DDR partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing sec partition... Done. Writing keystore partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing devinfo partition... Done. Writing config partition... Done. Writing spare1 partition... Done. Writing fota partition... Done. Writing rct partition... Done. Writing spare2 partition... Done. Writing raw_resources partition... Done. Writing raw_resourcesbak partition... Done. Writing drm partition... Done. Writing sns partition... Done. Writing misc partition... Done. Writing carrier partition... Done. Writing persist partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing recoverybak partition... Done. Writing factory partition... Done. Writing mpt partition... Done. Smart Repair is successfully complete. SW: 1.6.6; FW: 1.24. Disconnected. help please!!!!!! |
09-13-2018, 09:05 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Please, try to write full flash into your device, after check whether it will power ON, besides make sure that battery is charrged. |
09-27-2018, 07:00 | #6 (permalink) | |||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Quote:
