06-09-2018, 14:07 | #1 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Pakistan Hyderabad Age: 40
Member: 117640 Status: Offline Sonork: 100.1580505 Thanks Meter: 62 | LG LS676 Dead Boot Repair Successully Done Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q316BB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 15010051333136424202148DDC726453 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q316BB Product revision : 0.2 Product serial number : (hex) 148DDC72 Manufacturing date : 06/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q316BB_07_06_2018_17_29_52.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.8; FW: 1.23. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 00020000) 64 MB P02: sbl1 (00024000, 00000400) 512 KB P03: tz (00024400, 00000800) 1024 KB P04: rpm (00024C00, 00000400) 512 KB P05: aboot (00025000, 00001000) 2048 KB P06: sbl1bak (00026000, 00000400) 512 KB P07: tzbak (00026400, 00000800) 1024 KB P08: rpmbak (00026C00, 00000400) 512 KB P09: abootbak (00027000, 00001000) 2048 KB P10: modemst1 (00028000, 00000C00) 1536 KB P11: modemst2 (00028C00, 00000C00) 1536 KB P12: ssd (00029800, 00000400) 512 KB P13: DDR (00029C00, 00000400) 512 KB P14: spare3 (0002A000, 00000C00) 1536 KB P15: fsc (0002AC00, 00000400) 512 KB P16: sec (0002B000, 00000400) 512 KB P17: keystore (0002B400, 00000400) 512 KB P18: encrypt (0002B800, 00000400) 512 KB P19: eksst (0002BC00, 00000400) 512 KB P20: devinfo (0002C000, 00000800) 1024 KB P21: config (0002C800, 00000400) 512 KB P22: spare1 (0002CC00, 00003400) 6.5 MB P23: fota (00030000, 00003000) 6 MB P24: rct (00033000, 00000400) 512 KB P25: spare2 (00033400, 00000C00) 1536 KB P26: raw_resources (00034000, 00000800) 1024 KB P27: raw_resourcesbak (00034800, 00000800) 1024 KB P28: drm (00035000, 00003000) 6 MB P29: sns (00038000, 00003000) 6 MB P30: misc (0003B000, 00005000) 10 MB P31: fsg (00040000, 00000C00) 1536 KB P32: spare4 (00040C00, 00003400) 6.5 MB P33: persist (00044000, 00004000) 8 MB P34: carrier (00048000, 00014000) 40 MB P35: laf (0005C000, 0000C000) 24 MB P36: boot (00068000, 00008000) 16 MB P37: recovery (00070000, 00008000) 16 MB P38: recoverybak (00078000, 00008000) 16 MB P39: factory (00080000, 0000C000) 24 MB P40: mpt (0008C000, 00004000) 8 MB P41: system (00090000, 005DC000) 3000 MB P42: lafbak (0066C000, 0000C000) 24 MB P43: cache (00678000, 001C2000) 900 MB P44: userdata (0083A000, 014E4FDE) 10.45 GB P45: grow (01D1EFDE, 00000001) 512 b Opening C:/Users/Niaz Khan/Downloads/LS676ZV9_02_2.tot file... Signature OK. Signature 2 OK. Open file "C:/Users/Niaz Khan/Downloads/LS676ZV9_02_2.tot". Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition sbl1... Done. Writing partition tz... Done. Writing partition rpm... Done. Writing partition aboot... Done. Writing partition sbl1bak... Done. Writing partition tzbak... Done. Writing partition rpmbak... Done. Writing partition abootbak... Done. Writing partition sec... Done. Writing partition rct... Done. Writing partition raw_resources... Done. Writing partition raw_resourcesbak... Done. Writing partition misc... Done. Writing partition misc... Done. Writing partition persist... Done. Writing partition laf... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition recoverybak... Done. Writing partition factory... Done. Writing partition BackupGPT... Done. Writing is finished. SW: 1.5.8; FW: 1.23. Disconnected. |
The Following 2 Users Say Thank You to Niaz Hussain For This Useful Post: |
08-15-2018, 08:33 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. SRF for this device model has been send us by Mr. Pijush Das, so You can download it from the folder "USER UPLOADED SRF (NOT TESTED)" via "Download *.srf" button in Software. |
