04-19-2018, 12:06 | #1 (permalink) |
Freak Poster Join Date: Oct 2017
Member: 2773088 Status: Offline Thanks Meter: 24 | LG LS751 eMMC pinout request [Solved] Welcome to Octoplus Pro JTAG Software version 1.5.5. Started. Reader #0: Generic EMV Smartcard Reader 0 Model Settings: Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v1 Connecting... Sending loader... Failed. Model Settings: Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v2 Connecting... Sending loader... Failed. Model Settings: Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v3 Connecting... Sending loader... Failed. Model Settings: Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v4 Connecting... Sending loader... Failed. Model Settings: Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v5 Connecting... Sending loader... Failed. Model Settings: Interface : USB Core : Qualcomm MSM8916 Loader : QLoader_v6 Connecting... Sending loader... Failed. Last edited by Medusa Box; 04-20-2018 at 05:00. |
The Following User Says Thank You to pomgrapes For This Useful Post: |
04-19-2018, 12:41 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Unfortunately, currently we have only these USB loaders for MSM8916, which are present in Software. As soon as we will get new loaders, we will add the into the list in Software. We have no ISP eMMC pinout for this device at the moment. Maybe someone have and upload it here for You. Also if You have an experience in soldering, You can remove eMMC chip from PCB for repairing (programming), solder necessary wires directly to eMMC chip contacts (or use proper eMMC adapter for direct connection), do repair and then solder eMMC chip back to device's PCB. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
04-19-2018, 13:28 | #3 (permalink) | |
Member: 2773088 Status: Offline Thanks Meter: 24 | Quote:
04-19-2018, 13:39 | #4 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Quote:
04-19-2018, 14:20 | #5 (permalink) | |
https://mega.nz/#!KihEFS5J!JwZOmgpyH..._ya073BNRgahJ8 https://mega.nz/#!GnY2gLhA!HxaQ_vmgj...QKn25MIww0inZQ https://mega.nz/#!nrQgTDAD!Mv8aXeMT8...CTpSkCoI0y--Uo | |
04-19-2018, 14:25 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | This is BGA 221 package type. Just google "BGA 221 pinout" and You will find many pinout pictures for it. Also look here: http://forum.gsmhosting.com/vbb/f664.../#post13007680. |
04-19-2018, 16:24 | #7 (permalink) | |
Welcome to Octoplus Pro JTAG Software version 1.5.5. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31534D4201D34BD894A2D3 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.1 Product serial number : (hex) D34BD894 Manufacturing date : 10/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 697344 Number of sectors : 5242880 Device Manufacturer :lge Device Platform :msm8916 Build ID :LMY47V Display Build ID :HUSAM ABOHADI -T:772550157 Release ID :5.1.1 Device Model :LGLS751 Device Name :c90nas_spr_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :c90nas_spr_us-user 5.1.1 LMY47V 1532220536f4d release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/QN1SMB_19_04_2018_18_17_12.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. P00: GPT (00000000, 00000400) 512 KB P01: sbl1 (00000400, 00000400) 512 KB P02: tz (00000800, 00000400) 512 KB P03: hyp (00000C00, 00000400) 512 KB P04: rpm (00001000, 00000400) 512 KB P05: aboot (00001400, 00001000) 2048 KB P06: pad (00002400, 00000C00) 1536 KB P07: sbl1bak (00003000, 00000400) 512 KB P08: tzbak (00003400, 00000400) 512 KB P09: hypbak (00003800, 00000400) 512 KB P10: rpmbak (00003C00, 00000400) 512 KB P11: abootbak (00004000, 00001000) 2048 KB P12: misc (00005000, 00008000) 16 MB P13: persist (0000D000, 00008000) 16 MB P14: metadata (00015000, 00000400) 512 KB P15: modemst1 (00015400, 00000C00) 1536 KB P16: modemst2 (00016000, 00000C00) 1536 KB P17: laf (00016C00, 0000C000) 24 MB P18: boot (00022C00, 0000C000) 24 MB P19: recovery (0002EC00, 0000C000) 24 MB P20: fsg (0003AC00, 00000C00) 1536 KB P21: fsc (0003B800, 00000400) 512 KB P22: ssd (0003BC00, 00000400) 512 KB P23: DDR (0003C000, 00000400) 512 KB P24: sec (0003C400, 00000400) 512 KB P25: encrypt (0003C800, 00000400) 512 KB P26: eksst (0003CC00, 00000400) 512 KB P27: rct (0003D000, 00000400) 512 KB P28: sns (0003D400, 00004000) 8 MB P29: factory (00041400, 00010000) 32 MB P30: fota (00051400, 00010000) 32 MB P31: drm (00061400, 00004000) 8 MB P32: mpt (00065400, 00010000) 32 MB P33: modem (00075400, 00020000) 64 MB P34: persistent (00095400, 00001000) 2048 KB P35: carrier (00096400, 00014000) 40 MB P36: system (000AA400, 00500000) 2560 MB P37: cache (005AA400, 001C2000) 900 MB P38: userdata (0076C400, 006FC000) 3576 MB P39: grow (00E68400, 00027BDF) 79.48 MB https://mega.nz/#!TmBVWDgK!zYwWHAJJS...UJNEg8rhlbKtUE on top the pinout for the lg ls751 | |
04-20-2018, 05:00 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Thanks for the pinout picture, we will upload it into the Support Area. Also please make clear photo (without soldered wires) of phone's PBC where to solder wires and post it here. Here is ZV5 firmware for LS751: http://forum.gsmhosting.com/vbb/f664...l#post13089461. |
04-20-2018, 12:27 | #10 (permalink) | |
https://mega.nz/#!PrhS0KxC!Hw-uz_bp8...KpDDYsSdR9o9kU also is there anyway im going to be able to find zv7 firmware or higher i was talking to the *******r and he told me that it was zv7 and he flashed zv5 that is why it hardbricked? THANKS | |
04-20-2018, 12:57 | #11 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Yes, most likely device became "dead" because of downgrading firmware and now You need to write the same firmware version as was before (ZV7) or higher. Unfortunately, we don't have ZV7 or higher firmwares for this device model at the moment. Also, If You have the same device with ZV7 or higher firmware version, You can read out full flash from it and write into your device for repairing. |
