12-13-2018, 10:12 | #1 (permalink) |
Freak Poster Join Date: Oct 2017
Member: 2773088 Status: Offline Thanks Meter: 24 | LG LS770 reset FRP question [Answered] Last edited by Medusa Box; 12-13-2018 at 10:24. |
12-13-2018, 10:55 | #3 (permalink) |
Member: 2773088 Status: Offline Thanks Meter: 24 | Welcome to Medusa Pro Software version 1.6.8. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 2.6V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QN1SMB Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 150100514E31534D4201B9E5FA62B227 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QN1SMB Product revision : 0.1 Product serial number : (hex) B9E5FA62 Manufacturing date : 11/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QN1SMB_13_12_2018_01_52_49.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.8; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: sbl1 (00000400, 00000400) 512 KB P02: tz (00000800, 00000400) 512 KB P03: hyp (00000C00, 00000400) 512 KB P04: rpm (00001000, 00000400) 512 KB P05: aboot (00001400, 00001000) 2048 KB P06: pad (00002400, 00000C00) 1536 KB P07: sbl1bak (00003000, 00000400) 512 KB P08: tzbak (00003400, 00000400) 512 KB P09: hypbak (00003800, 00000400) 512 KB P10: rpmbak (00003C00, 00000400) 512 KB P11: abootbak (00004000, 00001000) 2048 KB P12: misc (00005000, 00008000) 16 MB P13: persist (0000D000, 00008000) 16 MB P14: metadata (00015000, 00000400) 512 KB P15: modemst1 (00015400, 00000C00) 1536 KB P16: modemst2 (00016000, 00000C00) 1536 KB P17: laf (00016C00, 0000C000) 24 MB P18: boot (00022C00, 0000C000) 24 MB P19: recovery (0002EC00, 0000C000) 24 MB P20: fsg (0003AC00, 00000C00) 1536 KB P21: fsc (0003B800, 00000400) 512 KB P22: ssd (0003BC00, 00000400) 512 KB P23: DDR (0003C000, 00000400) 512 KB P24: sec (0003C400, 00000400) 512 KB P25: encrypt (0003C800, 00000400) 512 KB P26: eksst (0003CC00, 00000400) 512 KB P27: rct (0003D000, 00000400) 512 KB P28: sns (0003D400, 00004000) 8 MB P29: factory (00041400, 00010000) 32 MB P30: fota (00051400, 00010000) 32 MB P31: drm (00061400, 00004000) 8 MB P32: mpt (00065400, 0000C000) 24 MB P33: modem (00071400, 00020000) 64 MB P34: persistent (00091400, 00001000) 2048 KB P35: pad2 (00092400, 00001000) 2048 KB P36: carrier (00093400, 00014000) 40 MB P37: system (000A7400, 00500000) 2560 MB P38: cache (005A7400, 001C2000) 900 MB P39: userdata (00769400, 00700000) 3584 MB P40: grow (00E69400, 00026BDF) 77.48 MB Disconnected. |
12-13-2018, 11:28 | #5 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | If You want to reset Screen Lock, at first You can try to just do Hard Reset. If this will not help, You can try erase "userdata" and "encrypt" partitions. Don't forget to make (read) backups of these partitions before! |
