Member: 231728
Thanks Meter: 2,103 | after I write partition GPT from full dump after I write partition GPT from full dump Quote:
Welcome to Medusa Pro Software version 1.6.3.
Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Reader #1: Alcor Micro USB Smart Card Reader 1
Reader #2: FT SCR2000 0
Reader #3: FT SCR2000 1
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : LG
Model : LS775
SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/LG_LS775_EMMC.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Unknown eMMC R1J96N
Page size : 512 B
Block size : 512 B
Block count : 30777344
Size : 14.68 GB (15028.00 MB)
CID Info
CID : 13014E52314A39364E109A4BC4E363DF
Manufacturer ID : 0X13
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4E
Product name : R1J96N
Product revision : 1.0
Product serial number : (hex) 9A4BC4E3
Manufacturing date : 06/2016
CSD Info
CSD : D07F01320F5903FFFFFFFFEF864000AD
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 80 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7675904 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/R1J96N_07_07_2018_18_15_28.bin.
Connect successful.
SW: 1.6.3; FW: 1.24.
Switched to General Purpose partition 1.
Erasing. Please wait... Done.
Opening F:/LG/LS775ZVB_03_____.tot file...
Signature OK.
Signature 2 OK.
Open file "F:/LG/LS775ZVB_03_____.tot".
Write data verification is enabled.
Writing. Please wait...
Switched to user area.
Writing partition PrimaryGPT...
Read/write verification error. Possible reasons: damaged or write protected eMMC.
Disconnected.
Model Settings:
Interface : eMMC
Brand : LG
Model : LS775
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/R1J96N_07_07_2018_18_16_36.bin.
Connect successful.
Disconnected.
Model Settings:
Interface : eMMC
Brand : LG
Model : LS775
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Not found
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/R1J96N_07_07_2018_18_16_57.bin.
Connect successful.
Smart report info:
Hash code: A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5A5 A5A5A5A5A5A5A5
Super block size : 0xA5A5A5A5 Bytes
Super page size : 0xA5A5A5A5 Bytes
Optima write size : 0xA5A5A5A5 Bytes
Number of banks : 0
Bank0 init bad block : 0
Bank0 runtime bad block : 0
Bank0 remain reserved block : 0
Max erase count : 0
Min erase count : 0
Avg erase count : 0
Read reclaim count : 0
Optimal trim size : 0xA5A5A5A5 Bytes
Max erase count (SCL) : 0
Min erase count (SCL) : 0
Avg erase count (SCL) : 0
Max erase count (MLC) : 0
Min erase count (MLC) : 0
Avg erase count (MLC) : 0
SW: 1.6.3; FW: 1.24. Partition table was not found.
Partition table is found from file F:/LG/LS775_356304073092070_07-07-2018_16-28-04.bin.
Don't forget to reconnect the device after writing to see changes.
Writting partitions. Please wait...
Writing partition GPT from F:/LG/LS775_356304073092070_07-07-2018_16-28-04.bin file... Done.
Writing is finished.
Reconnect the device to see changesDisconnected.
Model Settings:
Interface : eMMC
Brand : LG
Model : LS775
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/R1J96N_07_07_2018_18_18_36.bin.
Connect successful.
P00: GPT (00000000, 00000400) 512 KB
P01: sbl1 (00000400, 00000400) 512 KB
P02: tz (00000800, 00000400) 512 KB
P03: hyp (00000C00, 00000400) 512 KB
P04: rpm (00001000, 00000400) 512 KB
P05: aboot (00001400, 00001000) 2048 KB
P06: pad (00002400, 00000C00) 1536 KB
P07: sbl1bak (00003000, 00000400) 512 KB
P08: tzbak (00003400, 00000400) 512 KB
P09: hypbak (00003800, 00000400) 512 KB
P10: rpmbak (00003C00, 00000400) 512 KB
P11: abootbak (00004000, 00001000) 2048 KB
P12: misc (00005000, 00008000) 16 MB
P13: persist (0000D000, 00008000) 16 MB
P14: metadata (00015000, 00000400) 512 KB
P15: modemst1 (00015400, 00000C00) 1536 KB
P16: modemst2 (00016000, 00000C00) 1536 KB
P17: laf (00016C00, 0000C000) 24 MB
P18: boot (00022C00, 0000C000) 24 MB
P19: recovery (0002EC00, 0000C000) 24 MB
P20: recoverybak (0003AC00, 0000C000) 24 MB
P21: fsg (00046C00, 00000C00) 1536 KB
P22: fsc (00047800, 00000400) 512 KB
P23: ssd (00047C00, 00000400) 512 KB
P24: DDR (00048000, 00000400) 512 KB
P25: sec (00048400, 00000400) 512 KB
P26: encrypt (00048800, 00000400) 512 KB
P27: eksst (00048C00, 00000400) 512 KB
P28: rct (00049000, 00000400) 512 KB
P29: sns (00049400, 00004000) 8 MB
P30: factory (0004D400, 00010000) 32 MB
P31: fota (0005D400, 00005000) 10 MB
P32: drm (00062400, 00004000) 8 MB
P33: mpt (00066400, 00004000) 8 MB
P34: modem (0006A400, 00020000) 64 MB
P35: devinfo (0008A400, 00000800) 1024 KB
P36: pad1 (0008AC00, 00001400) 2560 KB
P37: persistent (0008C000, 00001000) 2048 KB
P38: pad2 (0008D000, 00003000) 6 MB
P39: carrier (00090000, 00014000) 40 MB
P40: system (000A4000, 0061E000) 3132 MB
P41: cache (006C2000, 001C2000) 900 MB
P42: userdata (00884000, 014D2000) 10.41 GB
P43: grow (01D56000, 00003FDF) 7.984 MB
Signature OK.
Signature 2 OK.
Writing partition PrimaryGPT... Done.
Writing partition sbl1... Done.
Writing partition tz... Done.
Writing partition hyp... Done.
Writing partition rpm... Done.
Writing partition aboot... Done.
Writing partition sbl1bak... Done.
Writing partition tzbak... Done.
Writing partition hypbak... Done.
Writing partition rpmbak... Done.
Writing partition abootbak... Done.
Writing partition persist... Done.
Writing partition metadata... Done.
Writing partition laf... Done.
Writing partition boot... Done.
Writing partition recovery... Done.
Writing partition recoverybak... Done.
Writing partition sec... Done.
Writing partition factory... Done.
Writing partition modem... Done.
Disconnected.
Model Settings:
Interface : eMMC
Brand : LG
Model : LS775
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/R1J96N_07_07_2018_18_20_38.bin.
Connect successful.
Disconnected.
