09-19-2018, 11:29 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 40
Member: 144643 Status: Offline Thanks Meter: 32 | LG LS777 Android build info not read [Answered] Last edited by Medusa Box; 09-19-2018 at 13:15. |
09-19-2018, 13:15 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. At first please post here full Software log, not screenshot, we will check, whether device is connected correctly. |
09-19-2018, 14:21 | #3 (permalink) |
Member: 144643 Status: Offline Thanks Meter: 32 | Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 150100514531334D420DF3569A6E44A9 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) F3569A6E Manufacturing date : 04/2001 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 32768 Kbytes Boot1 size : 25088 Kbytes Boot2 size : 25088 Kbytes RPMB size : 24576 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0xC8) 11001000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + High Speed timings in boot operation RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_19_09_2018_14_20_32.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.7; FW: 1.24. |
09-19-2018, 15:18 | #4 (permalink) | ||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | As You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 1024.00 MB: Quote:
