06-05-2018, 13:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2016 Location: Pakistan Age: 27
Member: 2665080 Status: Offline Thanks Meter: 63 | LG LS777 (ZVA) I unlock but this problem show [Answered] Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: Alcor Micro USB Smart Card Reader 2 Reader #3: Alcor Micro USB Smart Card Reader 3 Reader #4: FT SCR2000 0 Downloaded and installed file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 3.0V Bus Mode : 1 bit Bus speed : 8 MHz Connecting... Device : Hynix eMMC HAG4a2 Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 90014A484147346132A41FD470935431 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : HAG4a2 Product revision : 10.4 Product serial number : (hex) 1FD47093 Manufacturing date : 05/2001 --------------------------------------------------------------- CSD Info CSD : D02701328F5903FFFFFFFFE78A400017 CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG4a2_05_06_2018_17_10_53.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.5; FW: 1.23. Partition table was not found. Last edited by Medusa Box; 06-05-2018 at 14:51. |
The Following User Says Thank You to imeilock For This Useful Post: |
06-05-2018, 14:51 | #2 (permalink) | |||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. As You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 1024.00 MB: Quote:
Also, as I see from your Software log, You have set too high Voltage level: Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
06-14-2018, 07:28 | #4 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Welcome to Medusa Pro Software version 1.5.4. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Reader #2: FT SCR2000 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 2097152 Size : 1024.00 MB --------------------------------------------------------------- CID Info CID : 150100514531334D420D14509A2E340B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) 14509A2E Manufacturing date : 03/2001 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.0 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 0 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE13MB_14_06_2018_11_24_54.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.4; FW: 1.23. Partition table was not found. Partition table was not found. Partition table was not found. Partition table was not found. Partition table was not found. Partition table was not found. Partition table was not found. |
06-14-2018, 20:31 | #7 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Welcome to Medusa Pro Software version 1.4.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Reader #2: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420D14509A2E340B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) 14509A2E Manufacturing date : 03/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 7602176 Device Manufacturer : lge Device Platform : msm8937 Build ID : NRD90U Display Build ID : NRD90U Release ID : 7.0 Device Model : LG-LS777 Device Name : sf340_spr_us Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : sf340_spr_us-user 7.0 NRD90U 1801819032857 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_15_06_2018_00_21_50.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.9; FW: 1.22. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: tzbak (00033000, 00001000) 2048 KB P06: sbl1 (00034000, 00000800) 1024 KB P07: sbl1bak (00034800, 00000800) 1024 KB P08: rpm (00035000, 00000400) 512 KB P09: rpmbak (00035400, 00000400) 512 KB P10: devcfg (00035800, 00000400) 512 KB P11: devcfgbak (00035C00, 00000400) 512 KB P12: cmnlib (00036000, 00000400) 512 KB P13: cmnlibbak (00036400, 00000400) 512 KB P14: cmnlib64 (00036800, 00000400) 512 KB P15: cmnlib64bak (00036C00, 00000400) 512 KB P16: keymaster (00037000, 00000400) 512 KB P17: keymasterbak (00037400, 00000400) 512 KB P18: spare1 (00037800, 00000400) 512 KB P19: spare2 (00037C00, 00000400) 512 KB P20: persistent (00038000, 00000400) 512 KB P21: devinfo (00038400, 00000800) 1024 KB P22: spare3 (00038C00, 00003400) 6.5 MB P23: modemst1 (0003C000, 00000C00) 1536 KB P24: modemst2 (0003CC00, 00000C00) 1536 KB P25: mcfg (0003D800, 00002000) 4 MB P26: fsc (0003F800, 00000400) 512 KB P27: ssd (0003FC00, 00000400) 512 KB P28: fsg (00040000, 00000C00) 1536 KB P29: spare4 (00040C00, 00003400) 6.5 MB P30: dsp (00044000, 00008000) 16 MB P31: ftm (0004C000, 00004000) 8 MB P32: misc (00050000, 00004000) 8 MB P33: drm (00054000, 00004000) 8 MB P34: sns (00058000, 00004000) 8 MB P35: fota (0005C000, 00005000) 10 MB P36: sec (00061000, 00000400) 512 KB P37: keystore (00061400, 00000400) 512 KB P38: rct (00061800, 00000400) 512 KB P39: encrypt (00061C00, 00000400) 512 KB P40: eksst (00062000, 00000400) 512 KB P41: apdp (00062400, 00000400) 512 KB P42: msadp (00062800, 00000400) 512 KB P43: dpo (00062C00, 00000400) 512 KB P44: DDR (00063000, 00000400) 512 KB P45: spare5 (00063400, 00000C00) 1536 KB P46: boot (00064000, 00010000) 32 MB P47: laf (00074000, 00010000) 32 MB P48: lafbak (00084000, 00010000) 32 MB P49: recovery (00094000, 00010000) 32 MB P50: recoverybak (000A4000, 00010000) 32 MB P51: factory (000B4000, 0001C000) 56 MB P52: raw_resources (000D0000, 00002000) 4 MB P53: raw_resourcesbak (000D2000, 00002000) 4 MB P54: persist (000D4000, 00010000) 32 MB P55: mpt (000E4000, 00004000) 8 MB P56: carrier (000E8000, 00014000) 40 MB P57: system (000FC000, 00740000) 3712 MB P58: cache (0083C000, 00268000) 1232 MB P59: userdata (00AA4000, 0127AFDE) 9.24 GB |
06-14-2018, 20:59 | #8 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 7602176 Device Manufacturer : lge Device Platform : msm8937 Build ID : NRD90U Display Build ID : NRD90U Release ID : 7.0 Device Model : LG-LS777 Device Name : sf340_spr_us Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : sf340_spr_us-user 7.0 NRD90U 1801819032857 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_15_06_2018_00_54_08.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.9; FW: 1.22. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: tzbak (00033000, 00001000) 2048 KB P06: sbl1 (00034000, 00000800) 1024 KB P07: sbl1bak (00034800, 00000800) 1024 KB P08: rpm (00035000, 00000400) 512 KB P09: rpmbak (00035400, 00000400) 512 KB P10: devcfg (00035800, 00000400) 512 KB P11: devcfgbak (00035C00, 00000400) 512 KB P12: cmnlib (00036000, 00000400) 512 KB P13: cmnlibbak (00036400, 00000400) 512 KB P14: cmnlib64 (00036800, 00000400) 512 KB P15: cmnlib64bak (00036C00, 00000400) 512 KB P16: keymaster (00037000, 00000400) 512 KB P17: keymasterbak (00037400, 00000400) 512 KB P18: spare1 (00037800, 00000400) 512 KB P19: spare2 (00037C00, 00000400) 512 KB P20: persistent (00038000, 00000400) 512 KB P21: devinfo (00038400, 00000800) 1024 KB P22: spare3 (00038C00, 00003400) 6.5 MB P23: modemst1 (0003C000, 00000C00) 1536 KB P24: modemst2 (0003CC00, 00000C00) 1536 KB P25: mcfg (0003D800, 00002000) 4 MB P26: fsc (0003F800, 00000400) 512 KB P27: ssd (0003FC00, 00000400) 512 KB P28: fsg (00040000, 00000C00) 1536 KB P29: spare4 (00040C00, 00003400) 6.5 MB P30: dsp (00044000, 00008000) 16 MB P31: ftm (0004C000, 00004000) 8 MB P32: misc (00050000, 00004000) 8 MB P33: drm (00054000, 00004000) 8 MB P34: sns (00058000, 00004000) 8 MB P35: fota (0005C000, 00005000) 10 MB P36: sec (00061000, 00000400) 512 KB P37: keystore (00061400, 00000400) 512 KB P38: rct (00061800, 00000400) 512 KB P39: encrypt (00061C00, 00000400) 512 KB P40: eksst (00062000, 00000400) 512 KB P41: apdp (00062400, 00000400) 512 KB P42: msadp (00062800, 00000400) 512 KB P43: dpo (00062C00, 00000400) 512 KB P44: DDR (00063000, 00000400) 512 KB P45: spare5 (00063400, 00000C00) 1536 KB P46: boot (00064000, 00010000) 32 MB P47: laf (00074000, 00010000) 32 MB P48: lafbak (00084000, 00010000) 32 MB P49: recovery (00094000, 00010000) 32 MB P50: recoverybak (000A4000, 00010000) 32 MB P51: factory (000B4000, 0001C000) 56 MB P52: raw_resources (000D0000, 00002000) 4 MB P53: raw_resourcesbak (000D2000, 00002000) 4 MB P54: persist (000D4000, 00010000) 32 MB P55: mpt (000E4000, 00004000) 8 MB P56: carrier (000E8000, 00014000) 40 MB P57: system (000FC000, 00740000) 3712 MB P58: cache (0083C000, 00268000) 1232 MB P59: userdata (00AA4000, 0127AFDE) 9.24 GB P60: grow (01D1EFDE, 00000001) 512 b Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing aboot partition... Done. Writing abootbak partition... Done. Writing tz partition... Done. Writing tzbak partition... Done. Writing sbl1 partition... Done. Writing sbl1bak partition... Done. Writing rpm partition... Done. Writing rpmbak partition... Done. Writing devcfg partition... Done. Writing devcfgbak partition... Done. Writing cmnlib partition... Done. Writing cmnlibbak partition... Done. Writing cmnlib64 partition... Done. Writing cmnlib64bak partition... Done. Writing keymaster partition... Done. Writing keymasterbak partition... Done. Writing spare1 partition... Done. Writing spare2 partition... Done. Writing persistent partition... Done. Writing devinfo partition... Done. Writing spare3 partition... Done. Writing mcfg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing fsg partition... Done. Writing spare4 partition... Done. Writing dsp partition... Done. Writing ftm partition... Done. Writing misc partition... Done. Writing drm partition... Done. Writing sns partition... Done. Writing fota partition... Done. Writing sec partition... Done. Writing keystore partition... Done. Writing rct partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing DDR partition... Done. Writing spare5 partition... Done. Writing boot partition... Done. Writing laf partition... Done. Writing lafbak partition... Done. Writing recovery partition... Done. Writing recoverybak partition... Done. Writing factory partition... Disconnected. |
06-15-2018, 04:42 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Accordingly to your Software log, repair process was performed successfully and correctly. If the device doesn't go into Download Mode, here can be two main reasons of this problem - device has HW issue or boot loaders in SRF, that You have used for repairing, could be not suitable (not compatible) with your phone (boot loaders are older (has lower version) than should be in your phone, thus the phone can't go into Download Mode because of enabled boot downgrade protection). Try to find original firmware (the same version as was in the device before or higher version) and do "Factory Repair". |
06-17-2018, 11:26 | #10 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420D14509A2E340B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) 14509A2E Manufacturing date : 03/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 7602176 Device Manufacturer :lge Device Platform :msm8937 Build ID :NRD90U Display Build ID :NRD90U Release ID :7.0 Device Model :LG-LS777 Device Name :sf340_spr_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :sf340_spr_us-user 7.0 NRD90U 17297201850b6 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_17_06_2018_14_52_26.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.1; FW: 1.23. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: tzbak (00033000, 00001000) 2048 KB P06: sbl1 (00034000, 00000800) 1024 KB P07: sbl1bak (00034800, 00000800) 1024 KB P08: rpm (00035000, 00000400) 512 KB P09: rpmbak (00035400, 00000400) 512 KB P10: devcfg (00035800, 00000400) 512 KB P11: devcfgbak (00035C00, 00000400) 512 KB P12: cmnlib (00036000, 00000400) 512 KB P13: cmnlibbak (00036400, 00000400) 512 KB P14: cmnlib64 (00036800, 00000400) 512 KB P15: cmnlib64bak (00036C00, 00000400) 512 KB P16: keymaster (00037000, 00000400) 512 KB P17: keymasterbak (00037400, 00000400) 512 KB P18: spare1 (00037800, 00000400) 512 KB P19: spare2 (00037C00, 00000400) 512 KB P20: persistent (00038000, 00000400) 512 KB P21: devinfo (00038400, 00000800) 1024 KB P22: spare3 (00038C00, 00003400) 6.5 MB P23: modemst1 (0003C000, 00000C00) 1536 KB P24: modemst2 (0003CC00, 00000C00) 1536 KB P25: mcfg (0003D800, 00002000) 4 MB P26: fsc (0003F800, 00000400) 512 KB P27: ssd (0003FC00, 00000400) 512 KB P28: fsg (00040000, 00000C00) 1536 KB P29: spare4 (00040C00, 00003400) 6.5 MB P30: dsp (00044000, 00008000) 16 MB P31: ftm (0004C000, 00004000) 8 MB P32: misc (00050000, 00004000) 8 MB P33: drm (00054000, 00004000) 8 MB P34: sns (00058000, 00004000) 8 MB P35: fota (0005C000, 00005000) 10 MB P36: sec (00061000, 00000400) 512 KB P37: keystore (00061400, 00000400) 512 KB P38: rct (00061800, 00000400) 512 KB P39: encrypt (00061C00, 00000400) 512 KB P40: eksst (00062000, 00000400) 512 KB P41: apdp (00062400, 00000400) 512 KB P42: msadp (00062800, 00000400) 512 KB P43: dpo (00062C00, 00000400) 512 KB P44: DDR (00063000, 00000400) 512 KB P45: spare5 (00063400, 00000C00) 1536 KB P46: boot (00064000, 00010000) 32 MB P47: laf (00074000, 00010000) 32 MB P48: lafbak (00084000, 00010000) 32 MB P49: recovery (00094000, 00010000) 32 MB P50: recoverybak (000A4000, 00010000) 32 MB P51: factory (000B4000, 0001C000) 56 MB P52: raw_resources (000D0000, 00002000) 4 MB P53: raw_resourcesbak (000D2000, 00002000) 4 MB P54: persist (000D4000, 00010000) 32 MB P55: mpt (000E4000, 00004000) 8 MB P56: carrier (000E8000, 00014000) 40 MB P57: system (000FC000, 00740000) 3712 MB P58: cache (0083C000, 00268000) 1232 MB P59: userdata (00AA4000, 0127AFDE) 9.24 GB P60: grow (01D1EFDE, 00000001) 512 b Opening C:/Users/imeil/Desktop/LS777ZV8_06.tot file... Signature OK. Signature 2 OK. Open file "C:/Users/imeil/Desktop/LS777ZV8_06.tot". Write data verification is enabled. Writing. Please wait... Writing partition PrimaryGPT... Done. Writing partition modem... Done. Writing partition aboot... Done. Writing partition abootbak... Done. Writing partition tz... Done. Writing partition tzbak... Done. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition rpm... Done. Writing partition rpmbak... Done. Writing partition devcfg... Done. Writing partition devcfgbak... Done. Writing partition cmnlib... Done. Writing partition cmnlibbak... Done. Writing partition cmnlib64... Done. Writing partition cmnlib64bak... Done. Writing partition keymaster... Done. Writing partition keymasterbak... Done. Writing partition mcfg... Done. Writing partition dsp... Done. Writing partition sec... Done. Writing partition apdp... Done. Writing partition msadp... Done. Writing partition boot... Done. Writing partition laf... Done. Writing partition lafbak... Done. Writing partition recovery... Done. Writing partition recoverybak... Done. Writing partition factory... Done. Writing partition raw_resources... Done. Writing partition raw_resourcesbak... Done. Writing partition persist... Done. Writing partition system... Done. Writing is finished. SW: 1.6.1; FW: 1.23. |
06-17-2018, 11:32 | #11 (permalink) |
Member: 2665080 Status: Offline Thanks Meter: 63 | Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS777 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE13MB Page size : 512 B Block size : 512 B Block count : 30535680 Size : 14.56 GB (14910.00 MB) --------------------------------------------------------------- CID Info CID : 150100514531334D420D14509A2E340B Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE13MB Product revision : 0.13 Product serial number : (hex) 14509A2E Manufacturing date : 03/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7626752 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : a3e00000 bytes Device sector size : 512 bytes Partition offset : 1032192 Number of sectors : 7602176 Device Manufacturer :lge Device Platform :msm8937 Build ID :NRD90U Display Build ID :NRD90U Release ID :7.0 Device Model :LG-LS777 Device Name :sf340_spr_us Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :sf340_spr_us-user 7.0 NRD90U 17297201850b6 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/QE13MB_17_06_2018_15_26_08.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.1; FW: 1.23. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002C000) 88 MB P02: aboot (00030000, 00001000) 2048 KB P03: abootbak (00031000, 00001000) 2048 KB P04: tz (00032000, 00001000) 2048 KB P05: tzbak (00033000, 00001000) 2048 KB P06: sbl1 (00034000, 00000800) 1024 KB P07: sbl1bak (00034800, 00000800) 1024 KB P08: rpm (00035000, 00000400) 512 KB P09: rpmbak (00035400, 00000400) 512 KB P10: devcfg (00035800, 00000400) 512 KB P11: devcfgbak (00035C00, 00000400) 512 KB P12: cmnlib (00036000, 00000400) 512 KB P13: cmnlibbak (00036400, 00000400) 512 KB P14: cmnlib64 (00036800, 00000400) 512 KB P15: cmnlib64bak (00036C00, 00000400) 512 KB P16: keymaster (00037000, 00000400) 512 KB P17: keymasterbak (00037400, 00000400) 512 KB P18: spare1 (00037800, 00000400) 512 KB P19: spare2 (00037C00, 00000400) 512 KB P20: persistent (00038000, 00000400) 512 KB P21: devinfo (00038400, 00000800) 1024 KB P22: spare3 (00038C00, 00003400) 6.5 MB P23: modemst1 (0003C000, 00000C00) 1536 KB P24: modemst2 (0003CC00, 00000C00) 1536 KB P25: mcfg (0003D800, 00002000) 4 MB P26: fsc (0003F800, 00000400) 512 KB P27: ssd (0003FC00, 00000400) 512 KB P28: fsg (00040000, 00000C00) 1536 KB P29: spare4 (00040C00, 00003400) 6.5 MB P30: dsp (00044000, 00008000) 16 MB P31: ftm (0004C000, 00004000) 8 MB P32: misc (00050000, 00004000) 8 MB P33: drm (00054000, 00004000) 8 MB P34: sns (00058000, 00004000) 8 MB P35: fota (0005C000, 00005000) 10 MB P36: sec (00061000, 00000400) 512 KB P37: keystore (00061400, 00000400) 512 KB P38: rct (00061800, 00000400) 512 KB P39: encrypt (00061C00, 00000400) 512 KB P40: eksst (00062000, 00000400) 512 KB P41: apdp (00062400, 00000400) 512 KB P42: msadp (00062800, 00000400) 512 KB P43: dpo (00062C00, 00000400) 512 KB P44: DDR (00063000, 00000400) 512 KB P45: spare5 (00063400, 00000C00) 1536 KB P46: boot (00064000, 00010000) 32 MB P47: laf (00074000, 00010000) 32 MB P48: lafbak (00084000, 00010000) 32 MB P49: recovery (00094000, 00010000) 32 MB P50: recoverybak (000A4000, 00010000) 32 MB P51: factory (000B4000, 0001C000) 56 MB P52: raw_resources (000D0000, 00002000) 4 MB P53: raw_resourcesbak (000D2000, 00002000) 4 MB P54: persist (000D4000, 00010000) 32 MB P55: mpt (000E4000, 00004000) 8 MB P56: carrier (000E8000, 00014000) 40 MB P57: system (000FC000, 00740000) 3712 MB P58: cache (0083C000, 00268000) 1232 MB P59: userdata (00AA4000, 0127AFDE) 9.24 GB P60: grow (01D1EFDE, 00000001) 512 b Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS777_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing aboot partition... Done. Writing abootbak partition... Done. Writing tz partition... Done. Writing tzbak partition... Done. Writing sbl1 partition... Done. Writing sbl1bak partition... Done. Writing rpm partition... Done. Writing rpmbak partition... Done. Writing devcfg partition... Done. Writing devcfgbak partition... Done. Writing cmnlib partition... Done. Writing cmnlibbak partition... Done. Writing cmnlib64 partition... Done. Writing cmnlib64bak partition... Done. Writing keymaster partition... Done. Writing keymasterbak partition... Done. Writing spare1 partition... Done. Writing spare2 partition... Done. Writing persistent partition... Done. Writing devinfo partition... Done. Writing spare3 partition... Done. Writing mcfg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing fsg partition... Done. Writing spare4 partition... Done. Writing dsp partition... Done. Writing ftm partition... Done. Writing misc partition... Done. Writing drm partition... Done. Writing sns partition... Done. Writing fota partition... Done. Writing sec partition... Done. Writing keystore partition... Done. Writing rct partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing DDR partition... Done. Writing spare5 partition... Done. Writing boot partition... Done. Writing laf partition... Done. Writing lafbak partition... Done. Writing recovery partition... Done. Writing recoverybak partition... Done. Writing factory partition... Disconnected. |
06-17-2018, 14:02 | #13 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | You have witten too old firmware version (ZV8). You should write the same (ZVA) or higher firmware version. |
06-18-2018, 12:45 | #15 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | At the moment, we don't have ZVA or higher firmware for this device model. You can make request here, maybe someone have and will upload for You: http://forum.gsmhosting.com/vbb/f664...15/index8.html. |
