01-29-2018, 17:33 | #1 (permalink) |
Junior Member Join Date: Jan 2016 Location: Mirpurkhas Sindh Pakistan
Member: 2515866 Status: Offline Thanks Meter: 20 | LG LS991 Dead Boot Repair Successfully Done by Great Tool Started. Reader #0: FT SCR2000 0 Reader #1: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB --------------------------------------------------------------- CID Info CID : 110100303332473734003BB4551992FF Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) 3BB45519 Manufacturing date : 09/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1048576 Number of sectors : 8773632 Device Manufacturer : lge Device Platform : msm8992 Build ID : LMY47D Display Build ID : LMY47D Release ID : 5.1 Device Model : LG-H811 Device Name : p1_tmo_us Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : p1_tmo_us-user 5.1 LMY47D 15229154978c9 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/032G74_29_01_2018_20_25_03.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.3; FW: 1.21. P00: GPT (00000000, 00008000) P01: modem (00008000, 0002B000) P02: pmic (00038000, 00000400) P03: sbl1 (00038400, 00000800) P04: tz (00038C00, 00000800) P05: sdi (00039400, 00000400) P06: hyp (00039800, 00000400) P07: rpm (00039C00, 00000400) P08: aboot (0003A000, 00001000) P09: sbl1bak (0003B000, 00000800) P10: pmicbak (0003B800, 00000400) P11: tzbak (0003BC00, 00000800) P12: hypbak (0003C400, 00000400) P13: rpmbak (0003C800, 00000400) P14: abootbak (0003CC00, 00001000) P15: sdibak (0003DC00, 00000400) P16: limits (0003E000, 00000400) P17: devinfo (0003E400, 00000400) P18: apdp (0003E800, 00000400) P19: msadp (0003EC00, 00000400) P20: dpo (0003F000, 00000400) P21: spare1 (0003F400, 00000C00) P22: misc (00040000, 00008000) P23: persist (00048000, 00010000) P24: modemst1 (00058000, 00000C00) P25: modemst2 (00058C00, 00000C00) P26: fsg (00059800, 00000C00) P27: fsc (0005A400, 00000400) P28: ssd (0005A800, 00000400) P29: keystore (0005AC00, 00000400) P30: DDR (0005B000, 00001000) P31: sec (0005C000, 00000400) P32: encrypt (0005C400, 00000400) P33: eksst (0005C800, 00000400) P34: rct (0005CC00, 00000400) P35: persistent (0005D000, 00001000) P36: spare2 (0005E000, 00002000) P37: laf (00060000, 00018000) P38: boot (00078000, 00014000) P39: recovery (0008C000, 00014000) P40: drm (000A0000, 00004000) P41: sns (000A4000, 00004000) P42: mpt (000A8000, 00010000) P43: eri (000B8000, 00004000) P44: raw_resources (000BC000, 00002000) P45: raw_resourcesbak (000BE000, 00002000) P46: operatorlogging (000C0000, 00008000) P47: carrier (000C8000, 00014000) P48: felica (000DC000, 00004000) P49: factory (000E0000, 00017000) P50: spare3 (000F7000, 00001000) P51: fota (000F8000, 00005000) P52: spare4 (000FD000, 00003000) P53: system (00100000, 0085E000) P54: cache (0095E000, 00268000) P55: userdata (00BC6000, 02E72000) P56: grow (03A38000, 00005FDF) Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf". Write data verification is enabled. Writing GPT partition... Done. Writing pmic partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing sdi partition... Done. Writing hyp partition... Done. Writing aboot partition... Done. Writing limits partition... Done. Writing devinfo partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing spare1 partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing fsg partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing keystore partition... Done. Writing DDR partition... Done. Writing sec partition... Done. Writing encrypt partition... Done. Writing eksst partition... Done. Writing rct partition... Done. Writing persistent partition... Done. Writing laf partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing raw_resources partition... Done. Smart Repair is successfully complete. SW: 1.4.3; FW: 1.21. Disconnected. Last edited by Medusa Box; 01-30-2018 at 06:40. |
The Following User Says Thank You to asad.rana For This Useful Post: |
