12-17-2018, 19:11 | #1 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | LG LS991 write verification error. But connect OK [Answered] Welcome to Medusa Pro Software version 1.7.0. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : LS991 SRF : C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_LS991_EMMC_032G74.srf Voltage : 2.0V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 11010030333247373400316D903782E3 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) 316D9037 Manufacturing date : 08/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/032G74_17_12_2018_19_05_49.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.0; FW: 1.24. P00: GPT (00000000, 00008000) 16 MB P01: modem (00008000, 0002B000) 86 MB P02: pmic (00038000, 00000400) 512 KB P03: sbl1 (00038400, 00000800) 1024 KB P04: tz (00038C00, 00000800) 1024 KB P05: sdi (00039400, 00000400) 512 KB P06: hyp (00039800, 00000400) 512 KB P07: rpm (00039C00, 00000400) 512 KB P08: aboot (0003A000, 00001000) 2048 KB P09: sbl1bak (0003B000, 00000800) 1024 KB P10: pmicbak (0003B800, 00000400) 512 KB P11: tzbak (0003BC00, 00000800) 1024 KB P12: hypbak (0003C400, 00000400) 512 KB P13: rpmbak (0003C800, 00000400) 512 KB P14: abootbak (0003CC00, 00001000) 2048 KB P15: sdibak (0003DC00, 00000400) 512 KB P16: limits (0003E000, 00000400) 512 KB P17: devinfo (0003E400, 00000400) 512 KB P18: apdp (0003E800, 00000400) 512 KB P19: msadp (0003EC00, 00000400) 512 KB P20: dpo (0003F000, 00000400) 512 KB P21: spare1 (0003F400, 00000C00) 1536 KB P22: misc (00040000, 00008000) 16 MB P23: persist (00048000, 00010000) 32 MB P24: modemst1 (00058000, 00000C00) 1536 KB P25: modemst2 (00058C00, 00000C00) 1536 KB P26: fsg (00059800, 00000C00) 1536 KB P27: fsc (0005A400, 00000400) 512 KB P28: ssd (0005A800, 00000400) 512 KB P29: keystore (0005AC00, 00000400) 512 KB P30: DDR (0005B000, 00001000) 2048 KB P31: sec (0005C000, 00000400) 512 KB P32: encrypt (0005C400, 00000400) 512 KB P33: eksst (0005C800, 00000400) 512 KB P34: rct (0005CC00, 00000400) 512 KB P35: persistent (0005D000, 00001000) 2048 KB P36: spare2 (0005E000, 00002000) 4 MB P37: laf (00060000, 00018000) 48 MB P38: boot (00078000, 00014000) 40 MB P39: recovery (0008C000, 00014000) 40 MB P40: drm (000A0000, 00004000) 8 MB P41: sns (000A4000, 00004000) 8 MB P42: mpt (000A8000, 00010000) 32 MB P43: eri (000B8000, 00004000) 8 MB P44: raw_resources (000BC000, 00002000) 4 MB P45: raw_resourcesbak (000BE000, 00002000) 4 MB P46: operatorlogging (000C0000, 00008000) 16 MB P47: carrier (000C8000, 00014000) 40 MB P48: felica (000DC000, 00004000) 8 MB P49: factory (000E0000, 00017000) 46 MB P50: spare3 (000F7000, 00001000) 2048 KB P51: fota (000F8000, 00005000) 10 MB P52: spare4 (000FD000, 00003000) 6 MB P53: system (00100000, 0085E000) 4.184 GB P54: cache (0095E000, 00268000) 1232 MB P55: userdata (00BC6000, 02E72000) 23.22 GB P56: grow (03A38000, 00005FDF) 11.98 MB Repairing from file "C:/Program Files/Octoplus Pro JTAG Software/firmwareFolder/LG_LS991_EMMC_032G74.srf". Write data verification is enabled. Writing GPT partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. PLEASE WHAT IS THE PROBLEM OR SOLUTION TO THIS Last edited by Medusa Box; 12-18-2018 at 06:07. |
12-18-2018, 06:05 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
